Old Dec 05, 2012, 07:50 PM
joerayy is offline
Find More Posts by joerayy
I make crashing look easy..
Canada, ON, Hamilton
Joined Nov 2012
ditto !
Originally Posted by v8truckin View Post
Welcome! Best photo I could find of a head on view, but also a great pic all in all.
joerayy is offline Find More Posts by joerayy
Old Dec 05, 2012, 07:53 PM
joerayy is offline
Joined Nov 2012
Aaron, neat idea. What size magnet and approx position on the door? Middle or outer edge ? thx
Originally Posted by Aaron Wallace View Post
I put small magnets on the leading edge of the inner gear doors as suggested by an earlier post and it works great to keep the doors closed better.
Aaron
Old Dec 05, 2012, 07:55 PM
Aros.MotionRC is offline
Find More Posts by Aros.MotionRC
Shameful Warbirdaholic.
Aros.MotionRC's Avatar
Maple Valley, WA
Joined Apr 2006
Love that head on photo v8!
Aros.MotionRC is offline Find More Posts by Aros.MotionRC
Site Sponsor
Old Dec 05, 2012, 08:00 PM
jdm2ner is offline
Find More Posts by jdm2ner
flying is everything
jdm2ner's Avatar
United States, FL, Hollywood
Joined Oct 2010
this is where i put mine at
jdm2ner is offline Find More Posts by jdm2ner
Old Dec 05, 2012, 08:09 PM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
JD,
Thanks for the pic. Exactly where im going to add mine. You never had a problem with them opening with magnets using the stock servos?
v8truckin is offline Find More Posts by v8truckin
Old Dec 05, 2012, 08:11 PM
jdm2ner is offline
jdm2ner's Avatar
Joined Oct 2010
JD,
no never did they opend just fine
Old Dec 05, 2012, 09:10 PM
joerayy is offline
Joined Nov 2012
Thx for the pic, JD.. I'll be placing mine in the same spot.
Old Dec 05, 2012, 09:24 PM
Aaron Wallace is offline
Find More Posts by Aaron Wallace
Aaron Wallace's Avatar
San Diego
Joined Oct 2006
That is exactly where I put mine. Servos have no problem with them. OK... I stripped a grub screw (Allen set screw) that secures the pin that goes into the retract. How do I get that out without damaging things?
Aaron
Aaron Wallace is offline Find More Posts by Aaron Wallace
Old Dec 06, 2012, 01:00 PM
jlkitz is offline
Find More Posts by jlkitz
Doctorfoamy on Youtube
jlkitz's Avatar
United States, TX, Denton
Joined Sep 2011
Prop failure....???
The following video shows what I think was an inflight prop failure, or possibly a hub or firewall failure. This is a V1 plane with V2 upgrades (wing spars, struts, e-retracts).
What I initially thought was sound coming from the main gear door (which failed to retract due to a stripped servo) ended up being a serious vibration that caused a catastrophic prop/hub/firewall failure in flight at full power. You can hear the entire prop assembly self destruct just before my second pass.
If I could find the prop blades, I might be able to tell if it was the firewall letting go as the blades would be damaged from being pivoted into the plastic cowl. Otherwise, it looks as if I either had a blade break or come loose, or my hub was cracked and came apart during flight.
As a note, I had just finished a very successful flight with this plane about 30 minutes before and greased the landing. Nothing appeared to be broken during that flight, but I do remember hearing the vibration starting to make noise.
I have parts coming via BH and RC-Castle - Hong Kong express shipping. I just hope that the motor did not somehow play a role as I am not replacing it at this time.
Any arm-chair quarterbacks out there want to give this one a guess.....???
(be sure to click on the video "gear" symbol and change the resolution to 720p..)
Prop Failure in Flight - FMS 1700mm P-51 Mustang.mp4 (3 min 15 sec)
jlkitz is offline Find More Posts by jlkitz
Old Dec 06, 2012, 01:40 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Could it have been that your prop assembly was out of balance. I notice vibration on mine if it's out of balance and sounds differently. I land and balance it out and its whisk smooth again.
Sorry about that, but at least she's looking pretty good. You pulled that save off really well some ppl would've panic and bit the dust.
Old Dec 06, 2012, 02:05 PM
godofthunder77 is offline
Find More Posts by godofthunder77
godofthunder77's Avatar
Vermilion, OH
Joined Aug 2010
http://youtu.be/AnhpSMwvFWE
I would have to agree with V8. I had to balance mine with clay on the inside of the prop hub. It runs a lot better and very little vibration. Before there was a substantial amount of vibration.
godofthunder77 is offline Find More Posts by godofthunder77
Old Dec 06, 2012, 02:48 PM
ryramZ is offline
Find More Posts by ryramZ
Your Pilot Ryan
ryramZ's Avatar
United States, IN, South Bend
Joined Nov 2008
P-51B model give away. just like their page on facebook.
http://www.facebook.com/FMSmodel
ryramZ is offline Find More Posts by ryramZ
Old Dec 06, 2012, 02:49 PM
San Diego
Joined Oct 2006
I hope that it was just the prop out of balance because that is an easy fix. Did the firewall have sufficient adhesive with the fuselage? One of my landing gear mounting wells was not even glued in at all! Good save!
Aaron
Old Dec 06, 2012, 03:35 PM
Babadush is offline
Find More Posts by Babadush
Babadush's Avatar
United States, VA, Richmond
Joined Aug 2012
What about the people that already liked their page?
Babadush is offline Find More Posts by Babadush
Old Dec 06, 2012, 04:28 PM
Maple Valley, WA
Joined Apr 2006
How exactly are you guys balancing these props? Good save, btw!
Site Sponsor
Sold NEW FMS 57" P-51 Mustang with upgrades godofthunder77 Aircraft - Electric - Airplanes (FS/W) 11 Sep 14, 2011 02:55 PM
Sold NEW FMS 57" P-51 Mustang with upgrades godofthunder77 Aircraft - Fuel - Airplanes (FS/W) 2 Sep 04, 2011 01:41 PM
Sold FMS/Airfield P-51 Mustang V6 - Newest Version w/ tail retract, nav lights, more: BNF Roswalt Aircraft - Electric - Airplanes (FS/W) 9 May 25, 2011 11:08 AM
For Sale Guillows North American P-51 Mustang SupaMan Aircraft - Electric - Airplanes (FS/W) 0 Jan 04, 2010 09:38 PM
For Sale Guillows North American P-51 Mustang SupaMan Aircraft - Fuel - Airplanes (FS/W) 0 Jan 04, 2010 09:07 PM
