Old Oct 21, 2012, 08:48 PM
BRAND X is offline
Find More Posts by BRAND X
Name brands compare me...Why?
BRAND X's Avatar
United States, NJ
Joined Feb 2012
Has anyone softened the springs inside the strut? They seem to be rather stiff.
BRAND X is offline Find More Posts by BRAND X
Old Oct 21, 2012, 10:04 PM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
I tried it on my P51 and they did work fine, did bottom out a few times on harder landings. Decided I liked the stock springs compression better. You may have to try a few different springs as I had a few and can remember the exact specs.
Also I think the P47 is a lil heavier so going to a softer spring maybe similar or worse for that particular plane.
v8truckin is offline Find More Posts by v8truckin
Old Oct 21, 2012, 10:07 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
You can usually cut off some coil to soften oleo springs. Most usually have a fair bit of compression already when just assembled to full extension, so there is coil to spare.
The cut end best to go against the oleo leg (lower) end then.
Remove the locator pin so you can calculate how much 'more' spring there is than required in there as it comes. eg It might be something like 5mm to 10mm 'too long' (or even more).
Best to do small cut-offs.... like 1/4 turn or 1/2 turn.... re-assemble and test them on the aircraft's weight. Then adjust/cut more as required.... and go around that loop again.
Of course you don't really want to ever end up with the spring shorter than the 'pushrod gap' of the extended length! But you might only need as little as 5mm longer than that gap.
PeterVRC is offline Find More Posts by PeterVRC
Old Oct 21, 2012, 10:13 PM
PeterVRC is offline
Joined Nov 2006
Or you could always 'upgrade' to quality struts... like these, or whichever ones in their list are the best fit.
It is not hard to mod them DOWN in length, from 10mm to 15mm shorter is easy. So you aim for LONGER ones, if none are exactly right as they come. (springs can be softened by cutting too).
http://www.hobbyking.com/hobbyking/s...161mm_2pc.html
Old Oct 21, 2012, 10:22 PM
brandonmoon is offline
Find More Posts by brandonmoon
Fly & Have Fun..Enjoy the Ride
brandonmoon's Avatar
United States, AZ, Gilbert
Joined Mar 2009
Those struts wont fit the tires and cause problems in the wheel well when retracted....Already been there
brandonmoon is offline Find More Posts by brandonmoon
Old Oct 21, 2012, 11:04 PM
Sandancer is offline
Find More Posts by Sandancer
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
Originally Posted by ronht View Post
First of all, I absolutely love this airplane, however, I'm still pulling my hair out over landing gear problems.
These are Version 2 struts on V2 retracts. The retracts are flawless now, but I keep having problems with the struts breaking and rotating where they start to angle out around the wheel.
I've tightened and lock-tited the allen screws on the bottom, and still have a problems with strut rotating or becoming lose at that point and breaking the plastic housing. What I'd do to see that part in metal to give the extra support needed to the one allen screw on the bottom.
My latest effort is to use zip ties to attempt to give the area more support. BTW, none of my landings have been hard, I think it's the repeated unevenness of the grass runway at our field that's causing most of this.
Am I the only one seeing this problem? What are you guys doing out there to address this?
Thanks in advance for any input you have. I would really like to be able to fly this aircraft more than 2 or three flights without having to fix the landing gear.
I thought FMS solved this problem with these "V2" struts? The only way you're going to solve this problem is to have them welded!
Gary
Sandancer is offline Find More Posts by Sandancer
Old Oct 21, 2012, 11:34 PM
PeterVRC is offline
Joined Nov 2006
That was why I mentioned to check the other struts in the list.
I don't know the wheel size, but 70mm or 80mm would do?
Surely they can be made to fit.... you can usually modify base items to suit needs by adding/modding stuff.
http://www.hobbyking.com/hobbyking/s..._Pin_2pc_.html
http://www.hobbyking.com/hobbyking/s...168mm_2pc.html
Old Oct 22, 2012, 12:57 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Anyone have a spare tailwheel and retract they wanna get rid of? Broke my trunnion and of course the spares I have don't work on this retract because it's thinner retract. BH is out of stock and don't wanna wait 2-3wka for HK shipping. I've got a spare 1400/1450mm tailwheel and retract and may give that a try.
Old Oct 22, 2012, 01:20 AM
Joined Mar 2009
Those work fine...that's actually what I have in my origional FF Mustang for the tail wheel. You may have to modify the servo horn and mount bracket just a bit, but they work great and mine is still hold on strong today
Old Oct 22, 2012, 08:02 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Did you use the 1450mm wire? It isn't curved towards the rear like the 1.7m ,but is rather straight down. I was figuring I could swap the wheel assembly out and into the 1450mm tailwheel retract.
Old Oct 22, 2012, 01:25 PM
brosho is offline
Find More Posts by brosho
Craig
brosho's Avatar
Los Angeles, CA.
Joined Aug 2010
Brandonmoon
Now all you have to do is make the crew members who sit on the wing as the P-51 is taxi'ng to the runway. LOL Do anyone know exactly why the crew members would sit out on the left wing of the Warbirds when the planes were on their way out to the runway? Was it because it was near impossible for the pilots to see the runway when on the ground?
brosho is offline Find More Posts by brosho
Old Oct 22, 2012, 05:13 PM
Joined Mar 2009
Yup swaped out the wheel assy.
Old Oct 22, 2012, 05:21 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Cool! My cockpit should be delivered today so imma start on the detailing and hopefully have it done by wknd.
Old Oct 23, 2012, 01:05 AM
Joined Mar 2009
Originally Posted by brosho View Post
Brandonmoon
That is absolutely correct....The P-51 crews did that also
Old Oct 23, 2012, 05:15 AM
Joined Mar 2009
Here are pictures of the bottom two speakers (3 in.) on the Mustang for the Benedini sound system addition...With and without speaker grills. There will be 2 more smaller visaton (2 in.) speakers behind the exhaust stacks when they arrive
Sold NEW FMS 57" P-51 Mustang with upgrades godofthunder77 Aircraft - Electric - Airplanes (FS/W) 11 Sep 14, 2011 02:55 PM
Sold NEW FMS 57" P-51 Mustang with upgrades godofthunder77 Aircraft - Fuel - Airplanes (FS/W) 2 Sep 04, 2011 01:41 PM
Sold FMS/Airfield P-51 Mustang V6 - Newest Version w/ tail retract, nav lights, more: BNF Roswalt Aircraft - Electric - Airplanes (FS/W) 9 May 25, 2011 11:08 AM
For Sale Guillows North American P-51 Mustang SupaMan Aircraft - Electric - Airplanes (FS/W) 0 Jan 04, 2010 09:38 PM
For Sale Guillows North American P-51 Mustang SupaMan Aircraft - Fuel - Airplanes (FS/W) 0 Jan 04, 2010 09:07 PM
