Oct 10, 2012, 10:11 PM
United States, CA
Joined Dec 2010
Actually it's very simple. Weight prop blades individually and add like weights opposite of ea. blade. or closest as possible. Or just slap em on without weighing em end result is the same. Once blades are on the backplate, put setup in a balancer and blow/spin prop in forward thrust direction. If the same blade constantly keeps dropping to the bottom this is the heavy balde. You can tell once it starts to slow down that a heavy blade reaches the 12 o'clock position it will quickly drop to the bottom and rock back and forth, this signifies heavy blade is the bottom blade. Add tape, glue, ca, etc. to the bottom outer edge of the backplate opposite the heavy blade. Keep doing this until the prop spins freely and doesn't land with the same blade on the bottom. Add spinner and valance again in the same matter 95% of time it will stay balanced. However incase ot doesn't balance and you do have to rebalance mark a line that intersects on the bckplate and spinner so that when/if you remove the spinner it is reattached to the balanced position. Wheeeew! Gotta catch my breath 4th I had to explain this process in the past wk. Hope it helps and hope u guys understand as ita hard to explain via txt.
