Old Sep 06, 2012, 09:51 PM
v8truckin is online now
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
WMartin,
PZV2 are the latest updated retracts from FMS and most now are using those rather than using the eflites. PZV2 were not avail. at the time so eflite 60-120 were used. So depending on you, you can choose to use either. PZV2 can be purchased from RC-Castle, not sure if BH is shipping em in their planes.
Plastic oleo struts do not indicate planes version but rather strut version. If the oleo strut has a plastic housing then it is the v1.5 strut, if it is all aluminum then it is the latest updated v2 strut. Some planes such as Aros "Redtail" was shipped with v2 struts, while others may not have been.
Black and red esc wire connects to any open channel or y-cable to a channel.
I know it may sound confusing but it's actually simple.
v8truckin is online now Find More Posts by v8truckin
Old Sep 06, 2012, 10:37 PM
jdm2ner is offline
Find More Posts by jdm2ner
flying is everything
jdm2ner's Avatar
United States, FL, Hollywood
Joined Oct 2010
ok so im thinking of buying this plane i just want to know what are the must upgrades and fixs on this plane before i buy it?
jdm2ner is offline Find More Posts by jdm2ner
Old Sep 06, 2012, 10:57 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
One "Must" is make sure what you order, and get, IS a V2 upgraded one!
This greatly reduces the things you will 'need' to do. To almost zero....
So far it seems only Aros's blue version was that one.
But check and confirm before buying.
PeterVRC is offline Find More Posts by PeterVRC
Old Sep 06, 2012, 11:30 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
v2 All aluminum Oleo struts and PZV2 retracts which are both avail. from Rc-castle. If your v2 plane doesn't already come with em
Other than the above 2 nothing more is really needs just optional
Optional upgrades:
60-120 eflite retracts
BM Edition Ace of Iron (Once you see it you'll want it)
Esc Bec (if doing prop mod although stock should be fine)
Separate ext. Bec
Old Sep 07, 2012, 12:35 AM
Aaron Wallace is offline
Find More Posts by Aaron Wallace
Aaron Wallace's Avatar
San Diego
Joined Oct 2006
Originally Posted by dambit View Post
There is no need to adjust the thrust line. Mine has almost no deflection and tracks perfectly. Just make sure everything is tight and it'll be fine.
Why do people have to fiddle with stuff when they openly admit they have no idea about it. Not meant as an offence, just thought it needed saying.
dambit,
No offense taken and believe me I want to fiddle with things as little as possible (well, OK, I did get one of Brandon's Aces Of Iron pilots and am doing a very little amount of painting like the exhaust). However, the nose / cowl sure appears to be cut for the spinner backplate to fit with the traditional down and right thrust and if it that was not the intent then the nose / spinner alignment is wayyyyy off! And the wing fit is wayyyy off also so I will likely need to do some sanding of the wing roots. I had none of these issues with my 1400mm P-51. I think the basic design is good but quality control is not satisfactory yet. I appreciate all the information and any and all suggestions. Maybe I will fly it before adding right thrust and if it tracks ok then I can treat it as cosmetic. The wings are another story. Anyone with any good info on this?
Aaron
Aaron Wallace is offline Find More Posts by Aaron Wallace
Old Sep 07, 2012, 03:07 AM
brandonmoon is online now
Find More Posts by brandonmoon
Fly & Have Fun..Enjoy the Ride
brandonmoon's Avatar
United States, AZ, Gilbert
Joined Mar 2009
Brandon Moon custom modified "Aces of Iron" Pilot figure 1/7th scale
Here are pictures of Mr. Aaron Wallace's modified Aces of Iron Pilot figure I did for him and he sent me today.
Thanks Aaron for sending me those He definately looks ready for some serious flight duty
brandonmoon is online now Find More Posts by brandonmoon
Old Sep 07, 2012, 03:59 AM
dambit is offline
Find More Posts by dambit
Most people are stupid!
dambit's Avatar
Australia, QLD, Gold Coast
Joined Oct 2011
Aaron, maybe upload a picture or two so that we have a reference to compare to. Then we will know if it's ok or bad QC.
dambit is offline Find More Posts by dambit
Old Sep 07, 2012, 08:43 AM
wmartin817 is offline
Find More Posts by wmartin817
Grounded in NC
Joined Aug 2012
Originally Posted by v8truckin View Post
WMartin,
Thanks V8, that is very helpful.
Does anyone have any idea why my flaps would work in the downward direction but wont go back up? I'm using a DX8 but cant see any settings that would affect this performance.
bill
wmartin817 is offline Find More Posts by wmartin817
Old Sep 07, 2012, 09:23 AM
Grounded in NC
Joined Aug 2012
Can anyone tell me if this is the new alum oleo struts that I need to order..it doesnt specify.
Old Sep 07, 2012, 09:27 AM
Grounded in NC
Joined Aug 2012
WMartin,
But what is does it do once connected to the Rx? All usual channels are taken so this would plug into an Aux.
Old Sep 07, 2012, 09:34 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
yes those are them and just to make certain, in the comments section when placing order specific that you want the latest version struts.
Old Sep 07, 2012, 09:35 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
just plug it into the aux or y-cable it to an existing channel.
Old Sep 07, 2012, 09:38 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
bill
I don't have a DX8, but do have a spektrum Dx6i. if you go into the flaps menu (flaps should have its own menu) adjust the travel for the up position to 100% or opposite. I'm thinking its not getting full travel input from the flaps sub trim menu.
Menu should be similar to this, but don't mess with the elevator portion just the flaps.
Here's what my radio menu looks like
http://ironcreek.net/dx6i/dx6i_rf4_plane_flaps.jpg
Dx8
http://static.rcgroups.net/forums/at...g?d=1327365374
Old Sep 07, 2012, 10:06 AM
Grounded in NC
Joined Aug 2012
Thanks V8, I'm just not sure what it does for me...ie what controls on the plane will it affect. Seems like everything is already spoken for.
Old Sep 07, 2012, 10:22 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
It won't affect anything.
Sold NEW FMS 57" P-51 Mustang with upgrades godofthunder77 Aircraft - Electric - Airplanes (FS/W) 11 Sep 14, 2011 02:55 PM
Sold NEW FMS 57" P-51 Mustang with upgrades godofthunder77 Aircraft - Fuel - Airplanes (FS/W) 2 Sep 04, 2011 01:41 PM
Sold FMS/Airfield P-51 Mustang V6 - Newest Version w/ tail retract, nav lights, more: BNF Roswalt Aircraft - Electric - Airplanes (FS/W) 9 May 25, 2011 11:08 AM
For Sale Guillows North American P-51 Mustang SupaMan Aircraft - Electric - Airplanes (FS/W) 0 Jan 04, 2010 09:38 PM
For Sale Guillows North American P-51 Mustang SupaMan Aircraft - Fuel - Airplanes (FS/W) 0 Jan 04, 2010 09:07 PM
