Old Sep 01, 2012, 12:22 PM
brandonmoon is offline
Find More Posts by brandonmoon
Fly & Have Fun..Enjoy the Ride
brandonmoon's Avatar
United States, AZ, Gilbert
Joined Mar 2009
Originally Posted by Lenop View Post
Just received my v2 retracts (with yellow lettering on them) and they are a bit higher compared to the v1's so they do not completely fit. Anyone else had the same problem?
There is a PDF file that FMS published with and for those on Raymond's site @ RC-Castel that show you what you have to do and modify to get those to fit
brandonmoon is offline Find More Posts by brandonmoon
Old Sep 01, 2012, 11:49 PM
jlkitz is offline
Find More Posts by jlkitz
Doctorfoamy on Youtube
jlkitz's Avatar
United States, TX, Denton
Joined Sep 2011
1 year flying experience
Originally Posted by BRAND X View Post
I really want this plane but don't like digging holes. My current flying experience is with a PZ T-28(50-60 flights) and PZ P-47(28 flights). Is this plane too big a jump for a 1st year pilot?
I bought the 1700mm FMS Mustang with one year of RC flying experience. My previous planes were Parkzone F4U, Parkzone P47, and Parkzone Extra 300. Once you have mastered how to fly a pattern, how to line up a landing and how to set up a nice stable glide one final, you will be fine with the FMS 1700. In truth, it is more stable and less affected by the wind. If you dial in about 70% D/R and 30% Expo, you will find that the plane actually flys like it is on a rail.
I even bought the DuraFly 1100mm P-51 Frankie so that I could fly smaller fields while enjoying the stability of this design..but the 1700mm is easier to takeoff, easier to land and is more "scale" in its flying characteristics.
Advice for the 1700 mm Mustang
- takeoff and land on a flat surface with lots of room to the left of takeoff so that the torque pull doesn't put you into the weeds. You can hold rudder all you want .....anything above half throttle on takoff makes the bird hook to the left. I have viewed many of the videos made by the guys that frequent this forum and have seen that torque management during takeoff and landing is a common issue. Unless you want to spend most of your life repairing gears, struts, cracks in the wing...take off and land it on pavement for your first dozen flights. Practice the gradual application of power while holding the nose up and avoiding a prop strike.
- keep 25 to 30% throttle on while setting up your landing glide. Fly a landing profile that brings the plane from a fairly high altitude with full flaps to a level flight just above the runway. Keep the nose pointed slightly down and the speed slightly up while flying this profile to avoid a tip stall. Fly a landing approach that puts you level at 1-2 feet...then reduce the throttle to set it down on your mains. Many people crash this plane by gliding without throttle on final, and then hitting full throttle low to the ground when they choose to go-around. When flying low and slow, the torque of the 4-blade prop can be a killer as many of these planes roll left, power stall the wing and cartwheel.
- others are correct in stating that a cheaper plane is better for learning, but that statement is because the cost of the smaller airframe...not that the smaller plane is easier to fly, because in fact it may not be. If you are like me and have spent your first year flying 5-15 flights per week while learning how to fly in various conditions with a variety of planes, then you should be ready for this bird.
I took this video 12 months after flying my first RC aircraft, and after having flown the 1700 Mustang about 8-10 times. From here, I'll let you be the judge of your own training and skills because your 1700mm Mustang has the ability to easily fly just as scale and stable as this.
FMS 1700mm P-51 Mustang at Texas Motor Speedway.m2t (4 min 49 sec)
jlkitz is offline Find More Posts by jlkitz
Old Sep 02, 2012, 06:32 AM
dambit is offline
Find More Posts by dambit
Most people are stupid!
dambit's Avatar
Australia, QLD, Gold Coast
Joined Oct 2011
Also, on take off, use copious amounts of right rudder! you forgot to mention rudder management.
dambit is offline Find More Posts by dambit
Old Sep 03, 2012, 02:35 AM
Aaron Wallace is offline
Find More Posts by Aaron Wallace
Aaron Wallace's Avatar
San Diego
Joined Oct 2006
Nobody else has had wing fit issues? I just wanted to ask again before I sand the wing roots.
Aaron
Aaron Wallace is offline Find More Posts by Aaron Wallace
Old Sep 03, 2012, 02:50 AM
Joined Mar 2009
Aaron
Nope, but I'm not sure I would recomend doing that? There is going to be a small gap visible at the bottom,just because of the way the foam fits together, but if you sand it to try and tighten it up you may end up with misaligned wing bolt and hole locations between the wing and the fuselage....could make matters worse?
Old Sep 03, 2012, 03:49 AM
San Diego
Joined Oct 2006
Thanks Brandon. I checked the wing bolt alignment and it looks like I can take off a little from the center portion where it appears to buldge out a bit. The wing rod tube ends are already recessed so that will not be an issue. If it were not so bad I would leave it. Maybe I can take a photo and post it here first.
Thanks again.
Aaron
Old Sep 03, 2012, 02:08 PM
vilhelmsson is offline
Find More Posts by vilhelmsson
Sweden, Skåne County, Malmö
Joined May 2012
Hi, also got bad alignment 2mm front and 3-4mm rear, got bended aluminum tube for wing rod what version ?
vilhelmsson is offline Find More Posts by vilhelmsson
Old Sep 03, 2012, 02:23 PM
Joined May 2012
Hi, just figured out that i got the new retracts V2, also the ribon cable is replaced with better cables and conectors.
Are there som flexible filler i can use i the gap?
Got this one from Lindinger Austria 419€ at my doorstep :-)
Anders
Old Sep 03, 2012, 06:26 PM
BRAND X is offline
Find More Posts by BRAND X
Name brands compare me...Why?
BRAND X's Avatar
United States, NJ
Joined Feb 2012
So my advice would be to get the 1400mm version first to practice on take-off's and landings even though the 1700mm version really flies better and more stable in windy conditions. Heck, it's the best, smoothest and powerful looking plane I have ever flew, love it!
Thanks for the opinions...I currently fly the P-47 with a G25 on 4S with a four blade prop so I do understand torque. The powers that be (wife) likes the red tail so I won't let her down! It's on order and now I have a lot of posts to read. Is there a short list anywhere?
BRAND X is offline Find More Posts by BRAND X
Old Sep 03, 2012, 06:59 PM
San Diego
Joined Oct 2006
Again on the thrust alignment. Down and right is obviously designed into it but, mine seems to have the down but no right thrust. I am thinking that I should put some washers between the motor and the motor mount on the left side. There is a lot of torque in this plane. Anyone else have this issue?
Aaron
Old Sep 03, 2012, 07:11 PM
Joined Mar 2009
That might be good to try...I was going to do that also, But just hadn't got arround to it yet. It will also require realigning the nose cowl piece a bit ...as I also looked at doing that a while back
Old Sep 04, 2012, 12:45 AM
FieldofDreamsFlyer is offline
Find More Posts by FieldofDreamsFlyer
Field of Dreams Flyer
FieldofDreamsFlyer's Avatar
United States, CA, LA
Joined Sep 2004
Nice P-51B in this video
Merlin Madness Pt. I (3 min 2 sec)
FieldofDreamsFlyer is offline Find More Posts by FieldofDreamsFlyer
Old Sep 04, 2012, 01:05 AM
rlgdestroyu is offline
Find More Posts by rlgdestroyu
rlgdestroyu's Avatar
United States, WA, Everett
Joined Oct 2011
Originally Posted by twiztidbowler View Post
These flew right over my house. Live right next to Paine field in Everett WA. Great place to be to watch rare warbirds, paul allens collection is just one of them based here. Those planes were from Historic flight museum.
rlgdestroyu is offline Find More Posts by rlgdestroyu
Old Sep 04, 2012, 04:24 AM
San Diego
Joined Oct 2006
Brandon,
I think that the reason that my cowl / spinner alignment is off is because the cowl is aligned for the right thrust but, the motor mount does not have it. I think that once I put some washers on the motor mount it will all line up better.
The wing I have not figured out yet.
Aaron
Old Sep 04, 2012, 05:02 AM
dambit is offline
dambit's Avatar
Joined Oct 2011
Today I weighted up the plane to 5kg flying weight (bigger battery). Much better tracking and not as floaty. It also sinks nicely on approach as the extra inertia doesn't let it balloon when a wind gust hits it. I'm thinking it could still be a bit better, so I will try it with a flying weight of 5.5kg next time.
I'll be sure to grease the landing though as I don't want to bust the gear.
Sold NEW FMS 57" P-51 Mustang with upgrades godofthunder77 Aircraft - Electric - Airplanes (FS/W) 11 Sep 14, 2011 03:55 PM
Sold NEW FMS 57" P-51 Mustang with upgrades godofthunder77 Aircraft - Fuel - Airplanes (FS/W) 2 Sep 04, 2011 02:41 PM
Sold FMS/Airfield P-51 Mustang V6 - Newest Version w/ tail retract, nav lights, more: BNF Roswalt Aircraft - Electric - Airplanes (FS/W) 9 May 25, 2011 12:08 PM
For Sale Guillows North American P-51 Mustang SupaMan Aircraft - Electric - Airplanes (FS/W) 0 Jan 04, 2010 10:38 PM
For Sale Guillows North American P-51 Mustang SupaMan Aircraft - Fuel - Airplanes (FS/W) 0 Jan 04, 2010 10:07 PM
