Old Jun 28, 2012, 02:50 AM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Airimony.... (no that is not Chinese for Alimony... just alimony for aircraft).
PeterVRC is offline Find More Posts by PeterVRC
Old Jun 28, 2012, 02:53 AM
brandonmoon is online now
Find More Posts by brandonmoon
Fly & Have Fun..Enjoy the Ride
brandonmoon's Avatar
United States, AZ, Gilbert
Joined Mar 2009
LOL..ok...got it....good call
brandonmoon is online now Find More Posts by brandonmoon
Old Jun 28, 2012, 09:25 PM
slopoke13 is offline
Find More Posts by slopoke13
United States, TN, Oneida
Joined Oct 2011
Just got mine today from BH, this thing is HUGE. Ordered the blue nose 1400 also. I'll maiden it tomorrow, build date on it was this month and the gear cycle fine.
slopoke13 is offline Find More Posts by slopoke13
Old Jun 29, 2012, 11:05 AM
scribble007 is offline
Find More Posts by scribble007
United States, CA, Yosemite Lakes
The differences I notice from my (supposed v2) retracts Is you have the grub screw access hole. My trunions were metal. The slot where you can see the spring is the same. But the wheel well looks like its just foam on yours? With a few plastic mounting locations. My entire wheel well is a large plastic insert into the foam. And I have the functional yet useless micro switches.
And the little wire used to keep the wheel skirt next to the oleo has that U bend in it. That so one can adjust it so it closes tightly to the wheel well?
The REAL question is. What does the PCB on the inside look like on the inside.
scribble007 is offline Find More Posts by scribble007
Old Jun 29, 2012, 12:22 PM
jvanantwerp is offline
Find More Posts by jvanantwerp
John V
Joined May 2011
You're correct, the wheel well is mostly foam except for a mounting plate for the gear door and servo.
Hopefully I won't have enough trouble with the gear to make it necessary to dig out the PCB
I will say it is fairly robust mechanically. When I added the EMS sequencer I had the switches backward so it raised the mains on top of the gear doors. Other that some whining in the main gear motor while it tried to push through the door there was no damage to anything.
- John
jvanantwerp is offline Find More Posts by jvanantwerp
Old Jun 29, 2012, 12:52 PM
Joined Mar 2009
Well I'm now thourghly confused on how the Mod # Sequence goes about these retracts, But I don't think the retracts in any of the latest planes we all have or have seen, are actually the V2's that FMS is refering too.
I got this from Austin at FMS yesterday explaining the modification needed for the actual V2 retract...which looks to be longer than the ones I've seen so far and the ones that are on and came with my "Red Tails" Mustang, which are exactly like what is posted above on "jvanantwerp" Red Tails" Mustang
I think the first 2 attempts and types we've seen are and were V1 and V1.5 (which had the Micro Switch on it on the V1.5) (Both V1 and V1.5 had metal trunions as well)
It would be interesting and I'm very currious to actually see a "V2" retract they are talking about?
Old Jun 29, 2012, 01:20 PM
Lol, I too am confused as to what and if there are different version numbers for the retracts.
besides out side appearances. No way to really know. And the only ones that actually look different are the metal ones. Wonder what FMS refers to them internally in their system?
@jvanantwerp,
You said they are fairly robust. Could you tell me if you have any side to side turning play in the wheel? Both My mains were so loose that I had a good 15-20 degrees of rotation on the direction the wheel was facing (like a cars front wheels turning when one turns the steering wheel)
Made take offs a nightmare till it was up on step. Eventually causing it to strafe sideways into a curb.
Old Jun 29, 2012, 01:55 PM
Joined Mar 2009
Alot of that side to side play is in the strut and not in the retract unit itself. Check the grub screw that is in the slot where th spring is and make sure it is not screwed in too deep? If so?.... back it out a bit as it acts like a guide and aids in keeping the strut from that twisting motion...it works a lot better if its actually protuding a little beyond the slot is what i've found out....be sure to use some blue loctite though. Also check the 3 grub screws at the trunion and base leg of the strut itself. This should help correct some of that.
Old Jun 29, 2012, 02:34 PM
ronht is offline
Find More Posts by ronht
ronht
Joined Sep 2009
I got the Yellow version last week from BH. No damage and my retracts sound more like the version before or a mix of the Red Tail version pictures above as I have the micro switches. I've installed an ICE ESC and BEC set to 4.9v and so far after 10 flights (knock on wood) I haven't had any issues with anything.
The only criticism of the aircraft I have is that it seems a lot slower and lacking in the power department than I was expecting from watching some of the videos on YouTube. I'm using the 6s 4000 mah 25c Blitzworks batteries BH had matched up to the airplane, so maybe that's the problem, I don't know. I have some GenAce batteries on the way. It just seems like I need more than 3/4 throttle to comfortably maintain level flight leaving little to no extra power for anything else. I have to dive a good bit to get enough speed to get it to loop without falling out on top, is that the experience you guys have been having?
Ron
ronht is offline Find More Posts by ronht
Old Jun 29, 2012, 02:45 PM
I only have a few flights on mine but I can fly comfortably at half throttle, maybe a bit more. But most of the guys on here did the V8 prop mod which gives it a substantial increase in speed but also bumps up WOT amps from 76ish to 92ish IIRC.
And I think another issue is, bigger planes appear slower then a smaller plane going the same speed.
Old Jun 29, 2012, 03:11 PM
ronht is offline
ronht
Joined Sep 2009
Thanks, I'll give that a try. One of my problems may be that I'm used to big gas airplanes which generally fly a whole lot faster.
Old Jun 29, 2012, 08:50 PM
ronht is offline
ronht
Joined Sep 2009
Did the V8 Prop Mod today and went out and ran two more batteries through it - WOW what a difference, it's a whole different animal now!
Thanks for the tip
Old Jun 29, 2012, 09:55 PM
Joined Mar 2009
Here is what I was talking about with the grub screw and that twisting action many of us are experiencing in the strut
Old Jun 29, 2012, 10:17 PM
Joined Oct 2011
Are you guys running the prop mod with the stock esc? I feel she is a bit slow also, feels like a flying brick when you get below 3/4 throttle. Crashed mine on the maiden, but she's fixed now.
Sold NEW FMS 57" P-51 Mustang with upgrades godofthunder77 Aircraft - Electric - Airplanes (FS/W) 11 Sep 14, 2011 02:55 PM
Sold NEW FMS 57" P-51 Mustang with upgrades godofthunder77 Aircraft - Fuel - Airplanes (FS/W) 2 Sep 04, 2011 01:41 PM
Sold FMS/Airfield P-51 Mustang V6 - Newest Version w/ tail retract, nav lights, more: BNF Roswalt Aircraft - Electric - Airplanes (FS/W) 9 May 25, 2011 11:08 AM
For Sale Guillows North American P-51 Mustang SupaMan Aircraft - Electric - Airplanes (FS/W) 0 Jan 04, 2010 09:38 PM
For Sale Guillows North American P-51 Mustang SupaMan Aircraft - Fuel - Airplanes (FS/W) 0 Jan 04, 2010 09:07 PM
