Edmonton Alberta Canada
Joined Jul 2005
The torque of the two motors would be combined. Balanced motors would virtually negate any losses from a thrust bearing and an unbalanced motor would still reduce frictional losses, though to a lesser extent. |
carbondale il
Joined Jan 2007
Freefright, I have to admit your math is way beyond my comprehension. Question: are counter rotating propellers absolutely necessary - the two on the right spinning clockwise and the two on the left counterclockwise ( or the other way around ) ?
Joined Jul 2005
As to the direction of rotation of the props, the concern is primarily the torque effect on roll axis. Because the torque is applied at a distance from the center of mass, the net effect is less than it would be from a centrally mounted single propeller. There will be trimming differences between counter and non-counter rotating props but if you want the path of flight to vary as the props wind down, keeping them going the same direction would give a more familiar trimming experience |
carbondale il
Joined Jan 2007
I've settled on building a 27" wing-span Liberator powered by four independent 3 1/2" diameter plastic propellers. I've taken four 5" propellers and have cut the tips off, rounded the new tips a little and balanced them. I'm going to use four motor sticks which will extend aft beyond the wing's trailing edge with hopefully a loop each of 1/8" rubber. I haven't settled on the motor stick's length yet. From what I understand that is allowed in the competition regulations. I have the plan copied to size. The next step is to convert the plan, which is for a much larger RC plane, to free flight. I am not, any time in the near future, spending $200. for a micro chain and sprocket single rubber motor drive train. This is still going to be fun.
Kevin, the issue seems to be that you went from trying to do it with simple home made solutions that were just not adequite to jumping right into the whole "buy it" theme. But in between there's room for making your own drive train items from scratch. Oh sure, they won't be the toothed belting like you were looking at. But with a bit of care and experimenting everyday inexpensive materials can be adapted to suit. The key is to figure out what sort of loads each part carries and pick your experimental ideas based on what you feel will work. Then if it doesn't you look at some other material and try that.
This manner of thinking was the basis of some early posts suggesting that you turn your own pulleys from laminated balsa "plywood" and finish the surface to create light but true running pulleys or drive drums. Such work is well within the ability of a home hobby shop. You just need to set up a small motor or use a Dremel rotary tool as a light duty part time wood lathe. From there music wire and brass tubing for the drives and bearings along with some selected low friction plastics would complete what would be a useable drive train. |
| Thread Tools | |
| Discussion B-24 ? anyone? Anywhere? B-24 Liberator? | Sgtmonkeynads | Electric Warbirds | 6 | Feb 08, 2013 03:12 PM |
| Anyone done a 90" Jack Stafford B-24 Liberator? | Randall Miller | Scale Electric Planes | 21 | Mar 26, 2010 11:18 PM |
| Discussion Jack Stafford B-24D Strawberry B_tch Kit | GPutt33 | Fuel Warbirds | 3 | Jan 15, 2008 03:41 PM |
| Discussion Choosing first balsa kit Guillows B-24D or B-17G or P-38-L | salat | Electric Plane Talk | 24 | Jul 25, 2007 03:47 AM |
| Pics. of my Big B-24 Liberator !!!! | speedo | Scale Electric Planes | 15 | May 21, 2007 04:37 PM |
