I hate to say this but balsa for the gears is not the ideal material. Despite what appears to be pretty darn good craftsmanship there's just no way for balsa to hold the degree of accuracy of shape for efficiently transferring the power. You're going to find that they run lumpy and with more drag than you can afford. Gears need to be precision cut and evenly and smoothly sided for them to work well. If you look at how they work the sides need to closely follow a circular path shape so the teeth engage smoothly and hand off the load to the next tooth in line in a smooth manner. And in light of that your home made gears are just not going to do the job I'm afraid.
Looking at the Small Parts online catalog here's what I would suggest you need to make the front end transfer box. In this case I'm showing a 1:1 ratio. But there's much to be said for making it a slight step up ratio. For a 1:1 ratio you would want to get two of these gears or similar; http://www.smallparts.com/acetal-deg...rowse=16414721 For a build up ratio maybe get one of the above then one of these; http://www.smallparts.com/acetal-deg...rowse=16414721 These both require that you use 1/4 shaft material. Get some aluminium rod for this or thick wall ALLOY (not K&S, it's way too soft) tubing for the shafts. Small Parts has this 6061-T6 alloy which would work perfectly. http://www.smallparts.com/dp/B000FMZ...sp_dp_g2c_asin Then you also order 4 of these bearings to use for supporting the two shafts; http://www.smallparts.com/kilian-dia...ed=0.25+inches All this may seem counter to what I said before about having to keep things light. But this is just about as light as you can manage and still not use up much of the rubber's power in just trying to connect the output of the motor up to the props. In this case efficiency trumps saving a few grams. The use of the delrin/acetal plastic gears and the aluminium shafting is a serious nod to keeping the weight down. The use of the flanged ball bearings is a nod at tolerating the weight to achieve as low a gear box friction loss as practical. What I foresee the drive train looking like is a single motor connected to the gears in the nose which hide just behind the nose bubble. The motor sitting about in the middle or slightly low in the fuselage. The output from the gear box will connect to a drive shaft (think carbon tubing here) via universal joints at each end to the pulley which drives belts that extend out into the wings to drive the props. The center pulley cluster as well as the nacelle pulleys can use small diameter shafts and get away with plain brass bearings as a result. Just provide a way to get in and flush them clean then re-oil them from time to time. |
| Thread Tools | |
| Discussion B-24 ? anyone? Anywhere? B-24 Liberator? | Sgtmonkeynads | Electric Warbirds | 6 | Feb 08, 2013 03:12 PM |
| Anyone done a 90" Jack Stafford B-24 Liberator? | Randall Miller | Scale Electric Planes | 21 | Mar 26, 2010 11:18 PM |
| Discussion Jack Stafford B-24D Strawberry B_tch Kit | GPutt33 | Fuel Warbirds | 3 | Jan 15, 2008 03:41 PM |
| Discussion Choosing first balsa kit Guillows B-24D or B-17G or P-38-L | salat | Electric Plane Talk | 24 | Jul 25, 2007 03:47 AM |
| Pics. of my Big B-24 Liberator !!!! | speedo | Scale Electric Planes | 15 | May 21, 2007 04:37 PM |
