Old Sep 05, 2011, 12:19 AM
Eric Hd is offline
Find More Posts by Eric Hd
Joined Jan 2006
Help!
HK Parkjet EDF
Hi all,
I posted this in the micro EDF section but no answer:
I just got this little thing from a friend and thought it would make a great conversion to EDF. Probably should run on 3S, 1000-1300 mha.
What would be a suitable Fan/motor set up for this? Flying weight is announced at 190gr (6.7oz) on a pusher set up.
http://www.hobbyking.com/hobbyking/s...kJet_KIT_.html
Can anyone help? After doing a bit of research, I think this might do: http://www.hobbyking.com/hobbyking/s...ed_199_8W.html
What do you think?
Eric
Eric Hd is offline Find More Posts by Eric Hd
Old Sep 05, 2011, 01:30 AM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
yup, that fan on 3S should be good for you. how you plan to mount it..........tail or pod?
by the way, that link doesn't work. can you take pics for us instead?
Rich
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Sep 05, 2011, 02:42 AM
Eric Hd is offline
Joined Jan 2006
Sorry about the link, don't know what happened:
About mounting, don't know yet... will think about it when I get the fan!
Eric
Old Sep 05, 2011, 02:54 PM
Joined Jan 2009
looks like you'll need to do a rear podded application. you can get a pod real cheap from Ken Sparks @ www.parkplastics.com. another supplier is Gary at Efflux RC. of course, you can also make one yourself. it's not that difficult. that's how I would do it anyway. attach a pylon to that rear section of wood and put a pod back there.
you could also mount the fan closer to the fuselage, but the slipstreaming around the fuselage may upset the airflow into the fan, especially at higher AOA's. it's up to you how you do it, but those are your two options.
Rich
Old Sep 06, 2011, 01:25 PM
Eric Hd is offline
Joined Jan 2006
I'll probably mount it on a small CF moulded pylon.
Thanks for the link,
Eric
Jetset44 F-14 Parkjet converted to Twin EDF FL62 Foamy EDFs 781 Aug 10, 2015 08:36 AM
Help! HK Parkjet EDF Eric Hd Micro EDF Jets and Power Systems 1 Sep 05, 2011 02:09 PM
Discussion HK Parkjet MKII motor mount Azuro Flying Wings 1 Jul 29, 2011 03:29 PM
Discussion HK F35 or HK F18 as first EDF? cloaked Foamy EDFs 3 Apr 10, 2011 10:32 PM
Discussion Kit Bashin' the ParkJet from HK goldguy Flying Wings 10 Jan 03, 2011 09:03 AM
