Sep 05, 2011, 03:00 PM
ITALY
Joined Aug 2006
I'm usign fy21-ap with osd ap117 and what i can say it is fantastic. In RTH you can put away your radio.....
Originally Posted by al1242
I have used both and the Guardian wins hands down. The RTH home works on my skywalker with all default settings using the Guardian. I had problems with my Fy-20A getting it level, I never got it to work right in Pitch control, I had the ailerons only going thru it. They Fy-20A helped with RTH but you had to tweak all the settings in the OSD to make the turns stable. With the Guardian you can get the plane trimmed out in level flight, go into the ET OSD menu to reset level flight and it is perfect level flight from then on.
On hand launch I have full stabilization on with heading hold and give several clicks of up elevator trim. You can just give it a toss and it will climb nice and level, no stick input required. I am very impressed with how well the Guardian works, especially with RTH. You can even set it up so you have no stabilization during normal flight and it only kicks in for RTH, many options compared to an add on FY-20A for half the price.
