Old Sep 04, 2011, 01:40 PM
racin06 is offline
Find More Posts by racin06
United States, IN, Indianapolis
Joined Dec 2006
Hacker A80-10 powered Extreme Flight 88" Edge 540T - Maiden and 2nd flight videos
Yesterday, my friend Rob maidened his Extreme Flight 88" Edge 540T at our club field. Below is the setup and other data, along with videos of the two flights.
Setup -
- Hacker A80-10 180 kV Motor
- Mejzlik 26 x 15E Carbon Prop
- Castle Creations 160A HV ESC
- 2 x Sky Lipo 2S 1300mAh lipos (connected direct to receiver)
- Spektrum AR9110 Receiver
- Hitec HS-7950TH Servos x 4
- 4 x Sky Lipo 5S 4400mAh 40C lipos (10S 8800mAh)
- JR 11X Transmitter
Weights -
- Airframe without lipos - 16.65 lbs.
- Lipos - 5.05 lbs.
- AUW - 21.72 lbs.
Power, Current, Voltage at WOT -
- 4423 Watts
- 117.5 Amps
- 37.64 Volts (3.764 Volts per Cell)
Power Loading - 203.64 Watts/lb.
Maiden Flight - Electric Powered Extreme Flight 88" Edge 540T - September 3, 2011 (5 min 20 sec)
Second Flight - Electric Powered Extreme Flight 88" Edge 540T - September 3, 2011 (4 min 18 sec)
racin06 is offline Find More Posts by racin06
Old Sep 04, 2011, 11:02 PM
flyrobert1 is offline
Find More Posts by flyrobert1
flyrobert1's Avatar
United States, GA, Macon
Joined Feb 2009
Nice flying I'm doing a similar set up
flyrobert1 is offline Find More Posts by flyrobert1
Old Sep 05, 2011, 02:01 PM
DominicM is offline
Find More Posts by DominicM
DominicM
DominicM's Avatar
Fleet, Hampshire, UK.
Joined May 2003
Nice. 2nd best motor I've ever owned. It's bullet proof unlike the A60 which is truly shocking.
DominicM is offline Find More Posts by DominicM
Old Sep 06, 2011, 11:35 AM
enormat is offline
Find More Posts by enormat
Mats
Joined Feb 2010
What flight times do you get with the setup?
Mats
enormat is offline Find More Posts by enormat
Old Sep 11, 2011, 06:54 PM
rhampton is offline
Find More Posts by rhampton
USA, FL, Clearwater
Joined Dec 2007
your only using a 10s setup on this big plane?
rhampton is offline Find More Posts by rhampton
Old Sep 12, 2011, 04:23 AM
Jocke is offline
Find More Posts by Jocke
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
Looking good !
Jocke is offline Find More Posts by Jocke
Old Sep 19, 2011, 02:14 PM
racin06 is offline
Joined Dec 2006
Sorry for the late reply. Yes, 10s is plenty of power and was recommended by Kyle with Hacker's U.S. distributor, Aero Model.
Flight times are in the 10 minute range.
Old Dec 27, 2011, 03:01 PM
sharkyh2o is offline
Find More Posts by sharkyh2o
sharkyh2o's Avatar
Canada, ON, Arnprior
Joined Sep 2011
Mount
What motor mount did you use?
sharkyh2o is offline Find More Posts by sharkyh2o
Old Jan 11, 2012, 01:08 PM
wrjames38 is offline
Find More Posts by wrjames38
" I only fly Davebuilt"
wrjames38's Avatar
north county san diego
Joined Jan 2011
New Q80 setup...light!!!
I like the red....nice plane!
How about 18.5lbs AUW with 5000 watts.....270 watts/lb
http://www.rcgroups.com/forums/showthread.php?t=1570418
wrjames38 is offline Find More Posts by wrjames38
Discussion 88" Extreme Flight Edge (Maiden video added) JaseTheAce 3D Flying 167 Jul 07, 2014 11:27 PM
Discussion Extreme Flight 88" Edge 540T Electric - Maiden and 2nd Flight Videos racin06 3D Flying 8 Sep 03, 2011 07:54 PM
Discussion I just won an Extreme Flight Edge 540T ognolman 3D Flying 18 Aug 07, 2011 07:58 PM
