Old Sep 03, 2011, 03:39 PM
racin06 is offline
Find More Posts by racin06
United States, IN, Indianapolis
Joined Dec 2006
Extreme Flight 88" Edge 540T Electric - Maiden and 2nd Flight Videos
My friend Rob maidened his Extreme Flight 88" Edge 540T today at our club field. Below is the setup, along with videos of the two flights and some photos. Doesn't my 72" 3DHS Extra 330SC (8S powered) look small compared to the 88" Edge ? Anyway, what a great flying airplane! We love the large electrics!
Setup -
- Hacker A80-10 180 kV Motor
- Mejzlik 26 x 15E Carbon Prop
- Castle Creations 160A HV ESC
- 2 x Sky Lipo 2S 1300mAh lipos (connected direct to receiver)
- Spektrum AR9110 Receiver
- Hitec HS-7950TH Servos x 4
- 4 x Sky Lipo 5S 4400mAh 40C lipos (10S 8800mAh)
- JR 11X Transmitter
Weights -
- Airframe without lipos - 16.65 lbs.
- Lipos - 5.05 lbs.
- AUW - 21.72 lbs.
Power, Current, Voltage at WOT -
- 4423 Watts
- 117.5 Amps
- 37.64 Volts (3.764 Volts per Cell)
Power Loading - 203.64 Watts/lb.
Maiden Flight - Electric Powered Extreme Flight 88" Edge 540T - September 3, 2011 (5 min 20 sec)
Second Flight - Electric Powered Extreme Flight 88" Edge 540T - September 3, 2011 (4 min 18 sec)
racin06 is offline Find More Posts by racin06
Old Sep 03, 2011, 03:46 PM
Irg is online now
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
looks great!
that seems like a ton of battery? lots of people are flying the 89 slick on 12s 5000. I would imagine you could push your flight times to ten minutes almost?
Irg is online now Find More Posts by Irg
Old Sep 03, 2011, 04:09 PM
racin06 is offline
Joined Dec 2006
Thanks. My friend Rob spoke to Kyle at Aero Model who recommended a 10S setup between 6000 - 10000mAh for the 88" Edge using the Hacker A80-10 motor. Yes, flight times should be around the 8 - 10 min. range.
Old Sep 03, 2011, 04:41 PM
Irg is online now
Irg
Irg
Irg's Avatar
Joined Apr 2009
how is the balance? looks like the packs are right against the wing tube.
Old Sep 03, 2011, 04:51 PM
robw0000 is offline
Find More Posts by robw0000
Indianapolis
Joined Dec 2010
Balance
Balance required 2 clicks of elevator trim. Notice the (2) 1300 mah Batteries behind the wing tube.
robw0000 is offline Find More Posts by robw0000
Old Sep 03, 2011, 04:53 PM
Irg is online now
Irg
Irg
Irg's Avatar
Joined Apr 2009
what I was really after was, how does it respond to the 45 inverted upline test? sink, climb, stay the same?
Old Sep 03, 2011, 05:01 PM
robw0000 is offline
Indianapolis
Joined Dec 2010
Stays the same.
Old Sep 03, 2011, 06:49 PM
JaseTheAce is online now
Find More Posts by JaseTheAce
Fly hard, land soft ;)
JaseTheAce's Avatar
Joined Mar 2011
Lookin' awesome
JaseTheAce is online now Find More Posts by JaseTheAce
Old Sep 03, 2011, 06:54 PM
racin06 is offline
Joined Dec 2006
Yes...the balance was neutral on the 45 degree test, as well as just rolling to inverted...no elevator required.
Discussion 88" Extreme Flight Edge (Maiden video added) JaseTheAce 3D Flying 167 Jul 07, 2014 10:27 PM
Build Log Extreme Flight 60" Edge 540T EXP - Build/Fly/Video FlopGun 3D Flying 249 Apr 16, 2012 10:46 AM
Discussion I just won an Extreme Flight Edge 540T ognolman 3D Flying 18 Aug 07, 2011 06:58 PM
