Old Sep 03, 2011, 01:57 PM
10AE is offline
Find More Posts by 10AE
Georgetown IN
Joined Jul 2010
Turnigy G15 fix
Just wanted to post this, may save someone some money some day:
I installed a Turnigy G15 in my PZ P47D. It performed well, but would over heat and start to seize after about 4 minutes of flight. I took it apart and found that 3 of the magnets were sticking up about 2mm, whereas all the others were fully inserted into the motor can. As the motor warmed, I suppose the heat caused just enough expansion/contraction in the magnets and/or motor can to make the magnets touch the back of the motor (the part that bolts to the motor mount). Of course, once they made contact, the temps went through the roof and the motor seized. The 3 magnets were clearly discolored from the heat.
I used a small flat blade screwdriver to push magnets in even with the others, and now the motor is fine. I put a few drops of medium CA on them to hopefully prevent them from moving around again.
Hopefully no one else has this trouble, but if you do.......
10AE is offline Find More Posts by 10AE
Old Sep 09, 2011, 10:13 AM
flyingfred is offline
Find More Posts by flyingfred
flyingfred's Avatar
Joined Jun 2004
Hi, thats a bad thing. Magnets lost his magneticpower at heats about 80 grad celsius. better try to get new ones.
flyingfred is offline Find More Posts by flyingfred
Mini-HowTo Turnigy 9X 'resistor fix' ilektron Radios 43 Oct 23, 2015 01:36 PM
Discussion GF Force G15 35-48 DBono99 Power Systems 28 Sep 29, 2011 07:58 PM
Discussion g15 motor with 4s kraftydotcom Power Systems 1 May 11, 2011 07:59 PM
Wanted Turnigy G15 Brushless Outrunner 950kv Big Fran Aircraft - Electric - Power Systems (FS/W) 0 Jan 21, 2011 06:23 PM
Sold Turnigy 3000mAh 3S 40C Lipo Pack Need funds To Fix RC Jet, Please Help Dimarazumov Aircraft - Electric - Batteries & Chargers (FS/W) 4 Mar 27, 2010 05:27 PM
