Old Sep 02, 2011, 11:19 PM
Javage is offline
Find More Posts by Javage
Joined Aug 2011
Help!
Cordless drill RPMs for starting nitro motor
Hey guys, I have the HPI Rotostart for my nitros; but would rather use a cordless drill w/ Starter wand.
What RPM range should I look for, most seem to max out around 1,000-1,200. Is that enough?
Most have many clutch settings so I don't think over-spinning would be an issue.
Javage is offline Find More Posts by Javage
Old Sep 03, 2011, 08:00 AM
mredzadventure is offline
Find More Posts by mredzadventure
Kowalski !.....Options
mredzadventure's Avatar
USA, MI, Hastings
Joined Jan 2007
I don't think a drill is going to have enough RPM's to do the job I tried and it didn't work with my drill. A reversible air drill might do it but there expensive.
mredzadventure is offline Find More Posts by mredzadventure
Old Sep 03, 2011, 12:18 PM
Javage is offline
Joined Aug 2011
Kinda what I was thinking, I have a corded drill that I used before and it worked but not sure how fast it spun...
I know some guys use the cordless drills but just not sure on the specs their using.
Old Sep 03, 2011, 12:31 PM
Majortomski is offline
Find More Posts by Majortomski
dusty bible = dirty life
Majortomski's Avatar
Oklahoma City OK USA Where fakts still exist even if they are ignored
Joined Aug 2000
Well when u consider that a single flip will start a properly set up engine then its not the rpm but are the conditins right to start in the engine p
Majortomski is offline Find More Posts by Majortomski
Old Sep 03, 2011, 01:31 PM
Javage is offline
Joined Aug 2011
So if my engines are in good condition and RPM isnt much of a deal breaker, shoild I look at a certain voltage(12v, 14v,18v?) or should any of those have enough torque?
Current motors are 4.6 HPI Savage and 3.0 HPI.
Old Sep 03, 2011, 02:54 PM
USA, MI, Hastings
Joined Jan 2007
Nitro truck engines don't have a prop swinging in front of them. It did not work with my HPI 18ss. I need to replace my Roto starter, I thought a drill would work. I don't know if having a flywheel and clutch on the front makes a difference.
I needed a bit more power to get it done. I am going to replace my Roto starter. It is also a good idea to sin it fast when your burning all the left over fuel at the end of the day. You finger would fall off trying to flip the prop on a plane to clear out all the old fuel.
Old Sep 04, 2011, 01:11 PM
Duster_360 is offline
Find More Posts by Duster_360
Texas
Joined Aug 2006
This is what Sullivan (makes Tiger Drives for nitro engines) says -
"Q: What can I use to drive it?
A: Due to the high efficiency gear design and ratios that we use most engines can be started with a wide variety of devices. The 7/32" hex shaft that is used to drive the starters can be spun with a standard hand held starter (such as a Hi-Tork), or any cordless drill or similar device."
I've used my 14.4v Dewalt cordless drill using its higher speed setting.
Duster_360 is offline Find More Posts by Duster_360
Old Sep 04, 2011, 02:51 PM
USA, MI, Hastings
Joined Jan 2007
I tried it direct using the wand for my HPI and it was not fast enough I think the key on the tiger drive is the gearing. I used an electric drill that plugs in to the wall. I thought it would work but it still not fast enough.
Old Sep 05, 2011, 11:05 AM
Javage is offline
Joined Aug 2011
See here is my deal, I've succesfully used a corded drill to start my savage 4.6 and have personally seen others start their nitros using unknown type of cordless drill. So in my experience it can be done, I just didnt want to over do it, which seems unlikely if the drill has a clutch setting?
Old Sep 05, 2011, 06:07 PM
USA, MI, Hastings
Joined Jan 2007
I don't think you will over do it. The roto starts move at a good pace.
Old Sep 12, 2011, 12:59 PM
nicoyenny is offline
Find More Posts by nicoyenny
globemaster
nicoyenny's Avatar
USA, CA, Cypress
Joined Jun 2008
I have started my Savage X 4.6 with a cordless drill, no problems.
nicoyenny is offline Find More Posts by nicoyenny
Old Dec 05, 2011, 01:03 PM
Javage is offline
Joined Aug 2011
Just an update, I got a cheapo 18v battery powered drill from Harbor Freight a while back, it has the torque to spin but not the speed. O well I needed a cordless drill for around the house anyways
Old Dec 07, 2011, 07:05 PM
kstornado is offline
Find More Posts by kstornado
Joined Dec 2011
I have a black@decker 18v walmart deluxe that I started my first nitro with (sh.28) without a hitch.. the drill was cheap specs on it are 0-650/min(rpm).
since then its been bump box all the way
kstornado is offline Find More Posts by kstornado
Old Dec 27, 2011, 12:46 AM
htmlhuh is offline
Find More Posts by htmlhuh
Joined Oct 2011
If it can be pull started I'm sure it can be drill started. I could be wrong though. Won't know until you try. I've always used bump starters or starter boxes. I want to try out the tiger drive system. Gunna do some research on them first. Seems like its worth the investment.
htmlhuh is offline Find More Posts by htmlhuh
Old Dec 29, 2011, 10:57 PM
usmc_VTOL_mech is offline
Find More Posts by usmc_VTOL_mech
hotrod builder
usmc_VTOL_mech's Avatar
United States, TX, Arlington
Joined Jun 2007
I use my 18 volt dewalt drill as my primary starter for all my savages with roto-start. (4 of em) never had a problem before ...just gotta turn the clutch down to 2 or 3
usmc_VTOL_mech is offline Find More Posts by usmc_VTOL_mech
Sold Snapon cordless drill HYDROJERRY Cars - Cars and Parts (FS/W) 0 Aug 13, 2011 06:33 PM
Sold Snapon cordless drill HYDROJERRY Boats (FS/W) 0 Aug 13, 2011 06:30 PM
Discussion Cordless Drill Motor And Drive For Your Sub aquadeep Submarines 76 May 26, 2009 10:18 AM
[Query] Can Cordless Drill as Nitro Starter? Super_Hornet Fuel Heli Talk 10 Apr 30, 2005 05:32 AM
[Query] Can Cordless Drill as Nitro Starter? Super_Hornet Engines 2 Apr 25, 2005 10:00 AM
