Old Feb 08, 2013, 04:51 PM
John.G is offline
Find More Posts by John.G
love to fly, hate to crash
John.G's Avatar
Fort Erie Ont. Canada
Joined Jan 2005
Looks great so far spudandcat, John
John.G is offline Find More Posts by John.G
Old Feb 08, 2013, 05:35 PM
GhostStone is offline
Find More Posts by GhostStone
Soli Deo Gloria
GhostStone's Avatar
United States, IN, Fort Wayne
Joined Jan 2012
Looks really great! Nice work.
GhostStone is offline Find More Posts by GhostStone
Old Feb 08, 2013, 06:20 PM
baconflyer is offline
Find More Posts by baconflyer
cheapskate extroardinairé
United States, CA, Marin
Joined Jul 2011
Originally Posted by spudandcat View Post
Ok fellas
got the decals on but haven't decided what squadron to make her yet
will get there sooner or later, tore my calf at work so I can't hardly move
to get out to fly.
here she is , getting there slowly
seeyas spud
nice work, she's a beauty! I'm considering buying one of these. would you mind telling me what the foam is? don't want to order it and then find that it's eps or something. hope that leg heals soon!
baconflyer is offline Find More Posts by baconflyer
Old Feb 08, 2013, 06:55 PM
John.G is offline
John.G's Avatar
Joined Jan 2005
What do you think about this motor
Any one running this motor in their Windrider Hurricane as I have one coming.
Turnigy Aerodrive SK3 - 3548- 1100kv
Specs.
Turns: 8T
Voltage: 3~4S Lipoly
RPM/V: 1050kv
Internal resistance: 0.016 Ohm
Max Loading: 50A
Max Power: 820W
Shaft Dia: 5.0mm
Bolt holes: 25mm
Bolt thread: M3
Weight: 176g
Motor Plug: 3.5mm Bullet Connector
Thanks, John
Old Feb 08, 2013, 07:25 PM
GiusedtoBe is offline
Find More Posts by GiusedtoBe
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
Its EPO and high quality EPO at that. Think they are sold out though. May have to look for one on the trader.
Alan
GiusedtoBe is offline Find More Posts by GiusedtoBe
Old Feb 09, 2013, 10:15 AM
JMAH is offline
Find More Posts by JMAH
2 Cor 5.21
JMAH's Avatar
Tennessee
Joined Jul 2009
Specs.
Turns: 8T
RPM/V: 1050kv
Max Loading: 50A
Max Power: 820W
Shaft Dia: 5.0mm
Bolt holes: 25mm
Bolt thread: M3
Weight: 176g
Thanks, John
My thought is that it depends on the prop you intend to use. I prefer a 3-blader for more scale appearance, which drives me to lower kV motors (I've got a .32-class motor(4248) that goes 600 kV) in mine. I get a nice turn-of-speed with it spinning an MAS 12x8x3. If you're going for speed, however, the 2-blader on the higher kV motor is the ticket. And Turnigy seems to be a fairly inexpensive and good option.
Jeff
JMAH is offline Find More Posts by JMAH
Old Feb 09, 2013, 05:14 PM
spudandcat is offline
Find More Posts by spudandcat
Australia, NSW, Lavington
Joined Jul 2005
Specs.
Turns: 8T
RPM/V: 1050kv
Max Loading: 50A
Max Power: 820W
Shaft Dia: 5.0mm
Bolt holes: 25mm
Bolt thread: M3
Weight: 176g
Thanks, John
Hiya John, that motor will bolt straight in , I use a 35-48 900 kv though on 4s with a 9x7x3 but have used a 12x6 and 11x7 with the same motor in a hyperion 109e. I reckon the 1100 kv would be alright with 3s but would draw more amps.
The low kv and 4s setup keeps the amps on mine down to 30ish A static, which means esc and batt both stay nice and cool.
Thanks all for nice comments , it does look a bit rougher in the flesh and isn't quite the beauty like some of the works of art I have seen posted in this forum,
but it flys so well !! and looks good in the air.
HH have discontinued their Hurri as well sadly, pity its hard for not so "popular"
kites to get a run, but I suppose we live in a consumer market. I'd better get my building board out and learn how to build from plans again.
seeyas spud
spudandcat is offline Find More Posts by spudandcat
Old Feb 09, 2013, 05:51 PM
John.G is offline
John.G's Avatar
Joined Jan 2005
Thanks guys for the info as I am hoping to run a 3 cell pack but if I have to I do have a couple 4 cell packs I can use. I am hoping to be able to run a HL 11-10-3 prop but will have to see what numbers I pull when everything is plugged in. I don't run my stuff hard as I like to fly scale as I find it more of a challange than screaming around the sky with the left stick all the way to the stop.
Its funny as a lot of guys I fly with comment, you fly so smooth how do you do it, my answer, I use all the controls, ailerons, elevator rudder and throttle and what ever else is on the plane in a scale fashion. I have my 3-D/sport planes to get crazy with but find scale flight more my style of flying. John
Old Feb 14, 2013, 08:30 PM
ltc is offline
ltc
Find More Posts by ltc
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
Originally Posted by GiusedtoBe View Post
Its EPO and high qaulity EPO at that. Think they are sold out though. May have to look for one on the trader.
Alan
They appear on this page....
http://202.81.254.107/windrider_com_...uct.asp?id=164
Not sure if it was a cached page or not.
ltc is offline Find More Posts by ltc
Old Feb 16, 2013, 06:32 PM
W. X. Davis is offline
Find More Posts by W. X. Davis
W. X. Davis's Avatar
United States, OH, Reynoldsburg
Joined May 2004
Kewl .
Woody
W. X. Davis is offline Find More Posts by W. X. Davis
Old Feb 17, 2013, 10:40 AM
Lancer31 is offline
Find More Posts by Lancer31
Joined Jun 2005
Thanks, Woody!
I have the big, bright white LEDS for the landing lights, and have ordered the little 3mm white one for the tail light. You have to be careful wiring these, as different LEDs require different voltages, so need different resistors.
Lancer31 is offline Find More Posts by Lancer31
Old Feb 28, 2013, 07:33 AM
John.G is offline
John.G's Avatar
Joined Jan 2005
Ok so I am using my wifes hotglue gun and it holds well but is there a secret to keeping the glue from stringing and oozing out? My wife says you just remove the strings of glue after using it once cooled. I am using a blade to remove the excess glue but think epoxy is much cleaner to use. John
Old Feb 28, 2013, 08:04 AM
Lancer31 is offline
Joined Jun 2005
I would use UHU POR cement.
Since it a lot less messy, as well as time critical. Personally, I would think of a hot-melt glue gun for art&craft type work, where you just want to stick some stuff together where the fit is not critical, and you probably will just throw the whole thing away, anyhow.
Of course, it is a matter of personal choice.
Old Feb 28, 2013, 10:49 AM
TLMARK is online now
Find More Posts by TLMARK
The faster the better!
TLMARK's Avatar
Southern England
Joined Jan 2009
Seconded works very well
TLMARK is online now Find More Posts by TLMARK
Discussion Brian Taylor 60 size Hawker Hurricane build thread rcozstyle Scale Kit/Scratch Built 73 Nov 02, 2011 02:20 PM
Build Log VQ Hawker Hurricane 40 size build ***MAIDENED!!!!!!!!!!!! CarreraGTSCS Electric Warbirds 82 Jun 25, 2011 11:38 PM
Discussion Brian Taylor 60 size Hawker Hurricane build thread rcozstyle Australia 0 Apr 11, 2009 04:41 AM
Build Log Hawker Hurricane build 30" ws - Adrian Britton design - Fellside CNC cut RAFster Scale Kit/Scratch Built 31 Jan 29, 2007 08:31 PM
Discussion HAWKER HURRICANE 48" Vagabond324 Scale Kit/Scratch Built 19 Nov 30, 2006 08:50 AM
