Old Sep 04, 2011, 12:17 PM
nalby is offline
Find More Posts by nalby
Professional Toothpick maker
nalby's Avatar
USA, NY, New Hampton
Joined Jan 2005
How many watts should I be looking for to power this plane? I'm planning on using the tacon 32-770 which should be the same as the eflight and mp32. I was planning on using the masterairscrew 3 blade.
11x7x3 gives me about 319w at 30a at 11.1v 6.5 - 11 min flight
12x8x3 gives me about 360w at 35.4a at 11.1v 5 - 9min flight on 3s3300 25c ( according to eCalc )
nalby is offline Find More Posts by nalby
Old Sep 04, 2011, 01:43 PM
Matt Halton is offline
Find More Posts by Matt Halton
Wannabe B-26 pilot!
Matt Halton's Avatar
Southwold, Suffolk, UK.
Joined Nov 2002
Just dropped in here to subscribe. Still waiting for mine to show up, but the info here has been very interesting.
Matt
Matt Halton is offline Find More Posts by Matt Halton
Old Sep 04, 2011, 02:03 PM
Spyro37 is offline
Find More Posts by Spyro37
WIFE HAND LAUNCHED MY PLANES!
Spyro37's Avatar
Joined Jun 2009
Paint.
Just picked these from Lowe's. $4 paint per can, non reflective camo paint cans. The forest green (first can) was a bit darker than I wanted. Just sprayed them on a cardboard, color should be a bit lighter on a white foam.
-Spyro
Edited 2 hours later:
Oh no, just checked the cardboard paint job. It has that "powdery" finish. Rubbed it, & some powder goes on my skin. But did not really ruin the paint. Wiped it with paper towel, to wipe off the powdery layer, paint stayed OK...
Spyro37 is offline Find More Posts by Spyro37
Old Sep 04, 2011, 03:05 PM
Lexta is online now
Find More Posts by Lexta
Lexta's Avatar
Victoria BC Canada
Some Hurricane details from the New Zealand Based Hurri.
Lexta is online now Find More Posts by Lexta
Old Sep 04, 2011, 04:03 PM
jhspring is offline
Find More Posts by jhspring
Oh no, not again!
jhspring's Avatar
United States, LA, Carencro
Joined Dec 2005
Spyro, I have been looking at those paints for my Lancaster. Have you tried sealing them with Clearcoat to stop the powdering? I think all flat paints tend to flake a bit when rubbed. Wrt to lights, the landing lights in the wing LE are white as is the light on the rudder. The wingtip lights are red/port, green/starboard and should be steady. Flashing lights didn't come into play until the Grimes beacon in the 50's. There should also be a white light on top of the fuse, just in front of the antenna mast, and a series of 3 downward-facing ID lights (red/yellow/green) on the fuse.
Do you find windex better than rubbing alcohol for getting the mould release agent off? I emailed HobbyPartz about the Monster series and they plan to carry them as soon as they can get some, that's why they are still on the web site. I grabbed 2 10's and a 15 then last time they came in, wish I had had the sense to grab a 32 at the same time. I noticed that even ERC (the manufacturer) is out-of-stock at the moment.
Nalby, I think you might be a little light on power. We don't have the figures for flying weight, but I looked up Ming's recommended power combo and he is calling for something around 450W.
Hey Matt, glad you're here. Can't wait to see what you do with yours.
Regards,
Jeff
jhspring is offline Find More Posts by jhspring
Old Sep 04, 2011, 06:03 PM
Spyro37 is offline
Spyro37's Avatar
Joined Jun 2009
Jeff, thanks on your response regarding the light. Everything is now clear to me.
regarding the powder issue, you're totally right, most flat paint does that. I was afraid that it could get worse, but I was able to wipe them off without actually affecting the finish. And I thought about the clear coat as well, I believe I saw one from Lowe's (clear coat but not glossy) Satin finish. I want to avoid glossy paint on this project. The cool thing with this specific CAMO paint, is you can rub the paint where the 2 colors meet with paper towel, and they blend, like I used a paint brush which I don't have.
The Scorpion Can is 46mm length. My monster is 50mm length. Haven't actually checked if I need some "tweeking". I don't want to have too much clearance between the spinner and the fuselage nose.
-Spyro
Old Sep 04, 2011, 07:17 PM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
Good thread Jeff. Mine cleared customs in NY on 8/31 bit it still hasn't arrived. Just as well, still cleaning up from the hurricane for the new Hurricane.
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Sep 04, 2011, 07:22 PM
jhspring is offline
Oh no, not again!
jhspring's Avatar
Joined Dec 2005
Spyro, I think 50 mm should be okay. That's what all the motors I am looking at run.
Mike, glad you're high and dry. How badly did your little creek flood? We are sitting with Lee and the river is in my backyard right now, but of course I am on stilts.
Regards,
Jeff
Old Sep 04, 2011, 07:33 PM
bettsmums is offline
Find More Posts by bettsmums
bettsmums's Avatar
Jacksonville, FL
Joined Jan 2006
Firewall to spinner clearance.
The stock firewall is 54mm from the front of the fuselage. If you use a Dubro three bladed spinner it is dished about 2mm so you get a little extra space. There is not enough ground clearance for a 13 inch propeller. Even a 12 inch might be pushing it unless you fly from a hard surface.
bettsmums is offline Find More Posts by bettsmums
Old Sep 04, 2011, 07:38 PM
the Swamp Fox is offline
Find More Posts by the Swamp Fox
the Swamp Fox's Avatar
Wadmalaw Island ,SC
Joined Dec 2003
and now there's another hurricane after the first hurricane,,,hope to see mings hurricane before this next hurricane ,,,
Where did you get your lights,Jeff?
I had the old Curtek set,I regret selling now. I'm going port/starboard/landingx2/1 on the rudder as you have done.
For power I have the Scorpion,,,,a little $$$ but comes with a handsome carrying case
take care all ~
the Swamp Fox is offline Find More Posts by the Swamp Fox
Old Sep 04, 2011, 07:39 PM
ryramZ is offline
Find More Posts by ryramZ
Your Pilot Ryan
ryramZ's Avatar
United States, IN, South Bend
Joined Nov 2008
http://www.headsuprc.com/servlet/the...lectric/Detail
I'm thinking about this 480 motor, it's 475 watts and looks like it will swing the 11 inch props ok. I'll need stand offs but I have it laying around. Curious what you all think.
This is my next choice. 25 size
ryramZ is offline Find More Posts by ryramZ
Old Sep 04, 2011, 07:58 PM
Spyro37 is offline
Spyro37's Avatar
Joined Jun 2009
"Do you find windex better than rubbing alcohol for getting the mould release agent off?"
Jeff, Windex works better on my experience. But I don't want to be biased with my own opinion. This was also an advise by a well experienced builder that does all kinds of detail work from a Scratch Build to "re-detailing" ARF planes or kits. His RC lab is an amazing science room.
-Spyro.
Old Sep 04, 2011, 08:31 PM
Tom Hunt is offline
Find More Posts by Tom Hunt
got any foam to bash?
Tom Hunt's Avatar
Lake Grove,LI, NY
Joined Aug 2000
=CarreraGTSCS;19228613 Just as well, still cleaning up from the hurricane for the new Hurricane.
You Mean KATIA?
Tom Hunt is offline Find More Posts by Tom Hunt
Old Sep 04, 2011, 08:41 PM
ryramZ is offline
Your Pilot Ryan
ryramZ's Avatar
Joined Nov 2008
Bueller?
Old Sep 04, 2011, 09:58 PM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
One day I will be able to say "me too!"... for now reading along with hope in my heart.
JimNM is offline Find More Posts by JimNM
Discussion Brian Taylor 60 size Hawker Hurricane build thread rcozstyle Scale Kit/Scratch Built 73 Nov 02, 2011 02:20 PM
Build Log VQ Hawker Hurricane 40 size build ***MAIDENED!!!!!!!!!!!! CarreraGTSCS Electric Warbirds 82 Jun 25, 2011 11:38 PM
Discussion Brian Taylor 60 size Hawker Hurricane build thread rcozstyle Australia 0 Apr 11, 2009 04:41 AM
Build Log Hawker Hurricane build 30" ws - Adrian Britton design - Fellside CNC cut RAFster Scale Kit/Scratch Built 31 Jan 29, 2007 08:31 PM
Discussion HAWKER HURRICANE 48" Vagabond324 Scale Kit/Scratch Built 19 Nov 30, 2006 08:50 AM
