Old Sep 10, 2011, 08:04 AM
W. X. Davis is offline
Find More Posts by W. X. Davis
W. X. Davis's Avatar
United States, OH, Reynoldsburg
Joined May 2004
Hey Bettsmums,
Do you think that the motor your using will swing a 11 1/2" - 12" prop ?
Woody
W. X. Davis is offline Find More Posts by W. X. Davis
Old Sep 10, 2011, 11:56 AM
ryramZ is offline
Find More Posts by ryramZ
Your Pilot Ryan
ryramZ's Avatar
United States, IN, South Bend
Joined Nov 2008
You guys using a servo reverser for the flaps? I will probably just flip mine.
ryramZ is offline Find More Posts by ryramZ
Old Sep 10, 2011, 12:28 PM
the Swamp Fox is offline
Find More Posts by the Swamp Fox
the Swamp Fox's Avatar
Wadmalaw Island ,SC
Joined Dec 2003
I will just orient them the same way .. like so : L L (if possible) does it say that in the manual ?
Parts trickling in almost daily ... time to get going !
quoting Jeff:
My opinion of Windrider is unchanged, I will buy any warbird you offer sight unseen
I hear ya ... Ming,,,we need more warbirds !
These are defintely some nice models (SBD under bed ) ...
take care all ,
-H
the Swamp Fox is offline Find More Posts by the Swamp Fox
Old Sep 10, 2011, 12:31 PM
ryramZ is offline
Your Pilot Ryan
ryramZ's Avatar
Joined Nov 2008
Doesn't say. Look at the pockets they are like the ailerons.
Old Sep 10, 2011, 12:37 PM
Wadmalaw Island ,SC
Joined Dec 2003
ahhh so they are ... can't believe you made me get off the couch ! Ok,,diff model manual says orient flap servo same way... for some reason that was stuck in my mind . So yep servo reverse, use 2 channels on rx, ( flip it if it'll work) or perhaps those auto slow flap servos Jeff has on the way move in different directions .
Headsup rc is fast ! Have everything now except a few small things... like a servo reverse Y harness now
take care all ,
H
Old Sep 10, 2011, 12:40 PM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
I picked mine up from the post office yesterday morning 9 days after clearing US Customs in NY (which is about 1 hour away!). This plane has the smoothest EPO I've ever seen. It looks awesome. I have to put in a few late nights to have her ready for the NEAT Fair this coming week! Looks like she goes together pretty quickly. I have a light kit ready for her.
What size lipo does she require to balance well? I think I'm going to use a Monster Power 15 on her.
What a beautiful model.
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Sep 10, 2011, 01:59 PM
jhspring is offline
Find More Posts by jhspring
Oh no, not again!
jhspring's Avatar
United States, LA, Carencro
Joined Dec 2005
Glad you finally got yours, Mike. Ming says that with a 3S 3300 he still needed 40g of nose weight. Maybe try a 4000? The MP 15 is a great motor, wish I had one left to use.
Ry, Henry, we went through that with the SBD. Ming designed the pockets to face the same way b/c he uses a glider radio that allows you to droop the ailerons, so it's not a problem. I have a couple of reversing Y's, but they are kind of bulky and fuse space is at a real premium in this model, so I think I will just re-cut one of the servo pockets.
Ry, you were right, I have a 4-5 mm spinner gap, plus the spinner is a couple of mm too small. I think I will just glue a ring of soft balsa to the nose and sand it down, kill 2 birds with one stone.
All I need is a little unsupervised (read honey-dos) time.
Jeff
jhspring is offline Find More Posts by jhspring
Old Sep 10, 2011, 02:52 PM
Spyro37 is offline
Find More Posts by Spyro37
WIFE HAND LAUNCHED MY PLANES!
Spyro37's Avatar
Joined Jun 2009
Nothing glued yet, except the guns.
Just paint job.
My camera is not showing the right color. The first picture is pretty close, Khaki brown.
Spyro37 is offline Find More Posts by Spyro37
Old Sep 10, 2011, 03:31 PM
Wadmalaw Island ,SC
Joined Dec 2003
That looks fantastic spyro !
Glad she found you safe ,Mike !
Hurricane balance,,, Every hurri model I've had ,,same deal. Short nose moment makes it a challenge to get correct cg ,, I dislike adding "dead weight " I have a 3300 in there now but haven't mocked it up... will try to get everything as far forward as possible...
take care
Old Sep 10, 2011, 03:38 PM
Spyro37 is offline
Spyro37's Avatar
Joined Jun 2009
take care
I guess the " short nose" is a plus for my Hurri.
My power plant is 4 cell set-up.
-Spyro
Old Sep 10, 2011, 04:08 PM
bettsmums is offline
Find More Posts by bettsmums
bettsmums's Avatar
Jacksonville, FL
Joined Jan 2006
Large Prop
Originally Posted by W. X. Davis View Post
Hey Bettsmums,
Woody
I have the same motor in a different plane and it is turning a two blade APC electric 12-8 with a 4S 3300 LiPo. It is pulling nearly 60 amps at full throttle. The plane also has a lot of cooling air for the motor, speed control and battery. I need to fly the hurricane and see how warm the motor, speed control and battery get before I know how far I can push the setup. I guess I also need to remove the motor and add the single washer behind the let upper mounting ear to get the thrust offset.
bettsmums is offline Find More Posts by bettsmums
Old Sep 10, 2011, 04:30 PM
Matt Halton is offline
Find More Posts by Matt Halton
Wannabe B-26 pilot!
Matt Halton's Avatar
Southwold, Suffolk, UK.
Joined Nov 2002
Looks great Spyro, thanks for posting the pics, so of you guys are moving fast on your Hurri's!
Ming is definitely an EPO magician, and I too would buy any further warbird kits he produces, but most definitely a Typhoon (p.l.e.a.s.e.....!!!! )
Matt
Matt Halton is offline Find More Posts by Matt Halton
Old Sep 10, 2011, 04:47 PM
Spyro37 is offline
Spyro37's Avatar
Joined Jun 2009
Matt
Thanks Matt.
I'm just bored, I was not gonna build this beauty yet, but decided to do some paint job .
Yes, indeed, Ming's foam planes are ALL nice and flies Great, not like the typical mass produced boxed RTF's planes (or Ready To Fix).
Spyro
Old Sep 10, 2011, 04:59 PM
Wannabe B-26 pilot!
Joined Nov 2002
Thanks Matt.
Spyro
LOL, never a truer word said in jest!
Matt
Old Sep 10, 2011, 07:00 PM
jhspring is offline
Oh no, not again!
jhspring's Avatar
Joined Dec 2005
Spyro, yours looks very nice indeed. Gonna look great in the air.
Been puttering a bit with mine. Long back story, but the Cliff Notes version is that I finally got my upstairs computer back on line and spent some time with my Hurricane Explored cd. Wow, wish I could upload some of the pics. There are 18 pages of cockpit photos, 3 different Hurris. I found one perfect pic of the downward facing ID lights, stop light configuration, green/yellow/red. Not all Hurris had them, one has a centre red and two blanked off panels, others have none at all. There are in a very awkward place to install, solid foam everywhere, but I think I have a plan.
Lots of good pics of the flaps. Full down must be 85 degrees, like the Spit and the inboard flaps run right up to the radiator. In most pics on the ground the radiator shutter is open, might have to make one. Anyway, flaps. In the kit, no inner flaps, max deflection 40 degrees. Decided I would have to redo them, so am playing with that. I think it must be a genetic defect: if there is an easy way to do things and a hard way, I am drawn to the hard way like a moth to a candle. Hope I decide it's worth it.
Since I have my new wheels, made bushings, and put the wheels on the struts. They operate fine, have enough clearance in the wells, so good to go. Doesn't show, but they have the diamond tread pattern that I see on the photos of current Hurris. At 2.5" they should be okay for grass. I see what Ming means about the struts. I wanted to tweak them to get them centred better and the strut bent like a pretzel. Apparently this batch didn't get tempered. I won't dare to fly without replacing mine.
Slow, but puttering. Jeff
Discussion Brian Taylor 60 size Hawker Hurricane build thread rcozstyle Scale Kit/Scratch Built 73 Nov 02, 2011 02:20 PM
Build Log VQ Hawker Hurricane 40 size build ***MAIDENED!!!!!!!!!!!! CarreraGTSCS Electric Warbirds 82 Jun 25, 2011 11:38 PM
Discussion Brian Taylor 60 size Hawker Hurricane build thread rcozstyle Australia 0 Apr 11, 2009 04:41 AM
Build Log Hawker Hurricane build 30" ws - Adrian Britton design - Fellside CNC cut RAFster Scale Kit/Scratch Built 31 Jan 29, 2007 08:31 PM
Discussion HAWKER HURRICANE 48" Vagabond324 Scale Kit/Scratch Built 19 Nov 30, 2006 08:50 AM
