Old Sep 02, 2011, 01:38 PM
madptj is offline
Find More Posts by madptj
United Kingdom, England, Walthamstow
Joined Jun 2011
Help!
Alternative brushed motors for cheap stock 380's
Hello guy's.
I've recently got hold of really cheap racing boat called EP RACING BOAT "VICTORY" (costed me less than 25)
So painted the hull made it look nice as well replaced stock 7.2 1800mah NiMh with 11.1 5000mah lipo. Performance is great boat runs well exept. motors are melting down. So i have added two 6cm fans next each motor to cool them down. Still after runs temperature is too high. So the question is: what type of motors could i use instead of stock 380's. I would like them to bee able to handle 11.1 volts
madptj is offline Find More Posts by madptj
Old Sep 02, 2011, 01:58 PM
madptj is offline
Joined Jun 2011
HERE IS A VIDEO OF ONE OF THE RUNS
EP Racing Boat "Victory" after few modifications (1 min 59 sec)
Old Sep 02, 2011, 02:07 PM
pompebled is online now
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Mad,
The issue with your 380 running hot isn't really the higher Voltage (though I'd use smaller props to keep the temperature low(er)), but the increased runtime, which is about three times as long as with the stock 1800mAh.
The brushed motors have an efficiency of about 70% max, the rest of the electric energy is converted into heat.
Grab a 30W soldering iron and plug it in, you get an idea of the heat produced.
It 'll take more than a few fans to keep your motors cool, watercooling the can and adding brushtabcooling is the way to go if you want to keep the motors working.
Permanent overheating damages the magnets which will lose their power, ruining your motors.
This is the simplest version, a coil (not very efficient) and tubing soldered onto the connecting tabs:
If you want to add cooling coils, you'll have to alter the motormounts to make that possible, a bulkhead style mount like this gives you room for the coil, or a cooling jacket:
Make sure the slots on the front of the motor are not blocked by the motormount, the airflow through the armature is cruicial to the motor.
If you want a 'fancy', but highly efficient cooling, go for a jacket, like the one on this 700BB:
Regards, Jan.
pompebled is online now Find More Posts by pompebled
Old Sep 02, 2011, 02:29 PM
madptj is offline
Joined Jun 2011
WCS is a great idea, but as you can see i am very limited in space in a boat, by which i mean motor mounts are really cramped
Old Sep 03, 2011, 05:28 AM
Sneek, Netherlands.
Joined May 2004
Hi Mad,
Hence my suggestion to make a new motormount, bulkhead style, which give you ample room for whatever type of cooling you have in mind.
Keep in mind, you're modifying a toy, which was never intended for great speeds or long runtimes, so you'll have to alter these things.
Regards, Jan.
Old Sep 03, 2011, 11:44 AM
mfr02 is offline
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
If the motors were really 6 volt types that the manufacturers fitted to get a performance boost by cutting into the safety margin, then adding an extra 50% will certainly take them well out of their comfort zone. There are speed 400s rated for the higher voltage, and, with shopping around, types with a winding intended for higher performance. The bearings and brushes might well withstand the higher RPM as well.
A smaller diameter prop will help - it will let the motor spin faster, and will push back a faster stream of water, and since every action has an equal and opposite reaction, will result in a higher forward speed.
Just having a fan to cool the motors will do nothing unless there is some way to let the hot air out, and replacement cool air in. If the boat flips, these air holes will show the other problem - the holes are a way in for water. This is the advantage of water cooling - cold water in from the outside world, hot water back out.
mfr02 is offline Find More Posts by mfr02
Old Sep 04, 2011, 12:42 AM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
Melting Motors
There are some 380/400 size motors designed for the small rc cars and trucks, that should work. Also use the correct speed control, as that can effect things to. The comment on trying to upgrade a toy is right on!
CaptCB is offline Find More Posts by CaptCB
Old Sep 04, 2011, 11:31 AM
jmolwitz is offline
Find More Posts by jmolwitz
Straight up is all I ask
Fairfield Ct USA
Joined Apr 2002
You look ready for brushless power never look back .
jmolwitz is offline Find More Posts by jmolwitz
Old Mar 18, 2016, 06:56 AM
Rotbusch is offline
Find More Posts by Rotbusch
Joined Mar 2016
Upgrade to nitro
Hello I have a very similar boat, with 380 brushed motors. I am in the doing of upgrading to a .21 nitro engine. 1.9 horsepower is a little overkill, but it's the smallest engine for my 1:8 buggy I had. I am using one of the stock shafts. The one with the counter clockwise prop.
U might want do do something similar.
Ask if there are any questions.
Rotbusch is offline Find More Posts by Rotbusch
Sold alternative mk esc's for sale cheap 30.00 shipped flyer_dad Aircraft - Electric - Multirotor (FS/W) 1 Aug 28, 2011 08:44 PM
Sold 24g Brushless Motors and Esc , Flight simulator , Servos, Brushed esc's and motors jkelley05 Non R/C Items (FS/W) 8 Jul 09, 2011 10:17 AM
Question One 15a esc for 2 stock 380 motors? silvermansteve Power Systems 4 Sep 21, 2009 02:04 AM
Question Drop-in brushed motor upgrade for stock 380 in FlyZone Cessna 182? Boidster Beginner Training Area (Aircraft-Electric) 6 Aug 26, 2008 04:20 PM
Sold New Multiplex Brushed ESCs for 380 & 400 motors Reduced both for $11 shipped Twmaster Aircraft - Electric - Power Systems (FS/W) 4 Apr 14, 2008 12:23 PM
