Old Sep 02, 2011, 09:00 AM
RcCreator is offline
Find More Posts by RcCreator
Joined Dec 2010
BEVRC.com Easy Diversity just 15$
Hi, I did buy this easy diversity system from bevrc and I do not know how to run/install it. There is nearly no information on the homepage itself and I was just wondering if anybody has instructions/ a guide on how to solder the rssi wires from a 1.3Ghz bevrc videoreceiver.
Thanks, RC Creator
RcCreator is offline Find More Posts by RcCreator
Old Sep 02, 2011, 09:03 AM
saucisse is offline
Find More Posts by saucisse
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Looks a lot like this :
http://www.rangevideo.com/index.php?...roducts_id=216
saucisse is offline Find More Posts by saucisse
Old Sep 02, 2011, 09:08 AM
man2000me is offline
Find More Posts by man2000me
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
No kidding. Looks almost the same.
man2000me is offline Find More Posts by man2000me
Old Sep 02, 2011, 09:31 AM
ecampos is offline
Find More Posts by ecampos
FPVEEE ED
ecampos's Avatar
Quebec, Canada
Joined Jul 2010
Both do the same job... RSSI based diversity. They compare RSSI voltages between 2 RX's and switch to the strongest one. The only difference is the firmware. 15$ is very cheap !! Can be easily done with Arduino with less than 20 lines of code But we still need to know if both systems support those rx's which RSSI voltage is reversed, high=strongest low=weakest.
ecampos is offline Find More Posts by ecampos
Old Sep 02, 2011, 09:51 AM
Coyote64 is offline
Find More Posts by Coyote64
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
How do you do this with anarduino ? Please elaborate
Coyote64 is offline Find More Posts by Coyote64
Old Sep 02, 2011, 09:53 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Another knock off of this one: http://www.rcgroups.com/forums/showthread.php?t=1169075
And again completely inferior. You MUST USE CIRCULAR POLARIZATION OR IT WILL NOT WORK! It uses RSSI to select the proper RX. RSSI does not account for multipath fading and therefore you need to minimize it's effects.
Also, there is NOTHING easy about this unit.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Sep 02, 2011, 10:03 AM
octane81 is offline
Find More Posts by octane81
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
Better go with EagleTree diversity , a bit more expensive... but PLUG & PLAY !
octane81 is offline Find More Posts by octane81
Old Sep 02, 2011, 10:31 AM
ecampos is offline
FPVEEE ED
ecampos's Avatar
Quebec, Canada
Joined Jul 2010
ET diversity is video based not RSSI... Alex's diversity and tracker works good I've reproduced his system once and have been very satisfied with the results. Now, concerning Arduino, you need to read both RSSI's trough Arduino's analog pins and compare them... I'm working on a tracker that will use RSSI diversity and MAX7456 to display RSSI strength and direction (arrow for right-left for now... i still need to work on the up-down feature) on your groundstation screen/goggles so you can follow the arrow to get your plane right where the RSSI strength is the strongest... Some Arduino or C/C++ programming experience is needed and basic electronic skills (other than MAX7456 breakout). I'll post some pics and source code soon. In the meanwhile, you can check http://www.rcgroups.com/forums/showthread.php?t=1298192
Old Sep 02, 2011, 02:25 PM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Alex is right, forget diversity and tracking, CP ruled them !
renatoa is online now Find More Posts by renatoa
Old Sep 09, 2011, 05:15 AM
Joined Dec 2010
Easy Diversity
I got my Easy Diversity System today. With it I ordered a Vx (another one I bought at BEVRC was already lying around. First thing I noticed was, that also the two Vx looked the same, they did have a totally different inside.
1st: find the RSSI Pin
Description:
Description:
2nd: Solder the GROUND and RSSI to the Receiver
Description:
Description:
3rd: Solder the connecting wire to the Easy Diversity
Description:
Description:
This step was a little tricky cause I did not know which spots to solder it onto and the image on the BEVRC page is not in high res. so I had to guess.
Finally I ended up soldering it to the right connectors. Ground is (on the 3sided pins) The first from the Board and RSSI the last, leaving the middle one empty.
To put it all in a nutshell, it is pretty simple and works good as well, switching does not really effect the video image, which is good.
Old Oct 11, 2011, 07:17 AM
kienzle is offline
Find More Posts by kienzle
Joined Apr 2011
did someone know where i can find the rssi pin of a RC805 RX ?
regards
sven
kienzle is offline Find More Posts by kienzle
Old Oct 11, 2011, 07:59 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I have been playing with this diversity (well actually the RangeVideo one). It works ok so long as you scale your RSSI's with a potentiometer and buffer them with a capacitor. You also need to use circular polarization on both ends for it to work.
The only problem I can't seem to fix is the latency. it takes about 5 seconds for this unit to switch after the video turns to garbage.
-Alex
Old Oct 11, 2011, 08:01 AM
kienzle is offline
Joined Apr 2011
so RC305 and RC805 have the same RSSI Pin?
thx
Old Oct 12, 2011, 01:09 PM
kienzle is offline
Joined Apr 2011
did no one know where the rssi pin is of the rc805 RX ??? Platine number is RC308_110227 Rev:02
thx
Old Oct 12, 2011, 06:21 PM
Mieciu is offline
Find More Posts by Mieciu
Poland
Joined Feb 2011
I used mini jack sockets for rssi signals (inner is RSSI, outer is GND, middle - leave it blank)
Mine works great
bevrc_diversity.avi (2 min 27 sec)
With Lawmate receivers connect rssi from RX1 to rssi2 input and vice versa.
Mieciu is offline Find More Posts by Mieciu
Rave Bevrc.com bushpilotx1 Vendor Talk 1 Mar 29, 2012 10:16 PM
Discussion New FPV plane from BEVrc.com rclab1 FPV Aircraft 2 Aug 01, 2011 08:35 PM
Alert problems with easy OSD and online store bevrc.com guy1a FPV Talk 0 Jun 07, 2011 06:49 AM
Discussion Hacking bevrc.com 1.2GHz 200mW for 1280MHz? FpvKiwi DIY Electronics 7 May 26, 2011 09:53 PM
Discussion Hacking bevrc.com 1.2GHz 200mW for 1280MHz? FpvKiwi FPV Talk 0 May 22, 2011 01:36 PM
