Old Jan 05, 2013, 03:35 PM
I. Klemetti is offline
Find More Posts by I. Klemetti
Taken Lightly
I. Klemetti's Avatar
Pietarsaari, Finland
Joined Mar 2003
I made new leading edges for the rudder and elevators from balsa. The tail feathers are basically completed now. I tried them on and they made the fuselage look more like a Junkers fuselage.
ilkka
I. Klemetti is offline Find More Posts by I. Klemetti
Old Jan 11, 2013, 08:13 AM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
Dont ya hate when that happens. Your fix looks like nothing was ever wrong.
Edwin
edwin1 is offline Find More Posts by edwin1
Old Jan 12, 2013, 03:17 PM
Taken Lightly
Joined Mar 2003
Yes, Edwin, I hate it. However something goes wrong so often I'm somewhat used to it. Still I hate it.
I fixed the canopy with eight small screws at the sides of the canopy. The front corners protruded so bad I had to build more balsa around the corners.
I glassed the fuselage with water based polyurethane acrylate laquer.
ilkka
Old Jan 26, 2013, 12:32 PM
Taken Lightly
Joined Mar 2003
After glassing the fuselage I sprayed it lightly with base color just to see how smooth a surface I have managed to create. Well, instead of a smooth surface I have managed to make a ploughed field.
In addition to the nose glazing there are four more windows at the nose. I cut the openings and cut recesses on the edges to allow the 0.5 mm window sheets to be flush with the fuselage. Then I made windows frames from litho plate to cover the glued windows edges.
After I sprayed the fuselage with filler I still can see the balsa sheet edges. Letīs see if I can iron them out by sanding and filling and sanding and...
ilkka
Old Jan 26, 2013, 02:41 PM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Yup, the old sand/fill/sand/fill/sand/fill/sand/fill/sand/fill/sand thing.
All that means is that you're getting close !!!
She's looking good. Keep up the good work !
TomCrump is offline Find More Posts by TomCrump
Old Jan 27, 2013, 01:40 AM
Taken Lightly
Joined Mar 2003
Thanks Tom
I'd put it this way:
weight on - weight off - weight on - weight off - ...
I hope the final weight gain is not too much.
ilkka
Old Feb 02, 2013, 02:51 PM
Taken Lightly
Joined Mar 2003
Some cockpit detailing. In my model there is less than half of the devices found in real Ju 88. I concentrated in the ones near the windows. When the canopy is on you cannot see all of them either. And when the crew is sitting in the cockpit you can see even less.
In literature the Ju 88 cocpit is described cramped. That's true. When I had glued the widgets on the walls the crew barely fit in the cocpit.
ilkka
Old Feb 02, 2013, 04:55 PM
splinterz25 is offline
Find More Posts by splinterz25
Jack of all master of none
splinterz25's Avatar
Baltimore MD USA
Joined Jan 2011
Very nice great attention to detail and weight.
Bruce
splinterz25 is offline Find More Posts by splinterz25
Old Feb 02, 2013, 05:52 PM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
When I first look at a scale model, my eye is immediately drawn to the cockpit. Yours will not disappoint anyone.
Old Feb 03, 2013, 04:41 AM
Gree is offline
Find More Posts by Gree
Gree's Avatar
Sydney, Australia
Joined Jun 2006
You are a true artist ilkka! The cockpit is spectacular, I can't believe you are scratch-building all of this. Absolutely amazing.
Gree is offline Find More Posts by Gree
Old Feb 03, 2013, 05:37 AM
Taken Lightly
Joined Mar 2003
Thanks guys!
Yes, Tom. And the windscreen area, too. At the windscreen you know the nature of the aircraft. In the cocpit you know how it is supposed to be used.
Originally Posted by Gree View Post
... I can't believe you are scratch-building all of this.
Scratch building comes from the lack of ARFs or kits of this airplane and size. Had I wanted a Piper Cub or a Mustang I surely wouldn't be scratch building.
ilkka
Old Feb 04, 2013, 05:58 AM
kjsw is offline
Find More Posts by kjsw
Joined Apr 2012
Your work is wonderful!
I read your report now for about six months. And I'm always surprised when you post new pictures.
Especially because I like the airplane and the scale as well as you build it.
In particular I like your pilots. I wish I had the talent to build such beautiful pilots.
Did not you reworked the surface of the fuselage (Filler)?
Klaus.
kjsw is offline Find More Posts by kjsw
Old Feb 04, 2013, 06:29 AM
kusunokimasahige is offline
Find More Posts by kusunokimasahige
Tally Ho!
kusunokimasahige's Avatar
The Netherlands
Joined Apr 2006
This is a work of art !!
KM
kusunokimasahige is offline Find More Posts by kusunokimasahige
Old Feb 04, 2013, 06:46 AM
Taken Lightly
Joined Mar 2003
Thank you Klaus and KM!
The fuselage is primed, spot filled and sprayed with filler plus sanded after every treatment. It is half way done. I'll continue the surface preparation after the ventral gondola and glazing are attached.
ilkka
Old Feb 04, 2013, 10:38 AM
kjsw is offline
Joined Apr 2012
Thanks for the answer.
I'm longing to know about the next steps... I'll stay here!
Klaus.
Anyone know of a Junkers Ju-87 Stuka kit or ARTF? The Max-Q Parkflyers 12 Mar 07, 2009 09:07 AM
Anyone know when the Junkers JU 87 D-1 STUKA from FSK will be available? Electricman Parkflyers 6 Sep 10, 2004 03:28 PM
Bahuer Junkers JU-52 tlh101 Scale Kit/Scratch Built 34 Jul 03, 2003 02:14 PM
Junkers Ju 52/3m "Iron Annie" Philipp Gardemin Scale Kit/Scratch Built 2 Jul 31, 2001 09:22 AM
