Old Sep 01, 2011, 11:39 PM
NefariousRC's Avatar
USA, CA, San Diego
Joined Jan 2011
Getting RPM from RCExl ignition
The RCExl ignition modules for gas engines has an output for RPM from the hall sensor. Anybody know if this output could be used with the telemetry? Here's a picture of the ignition with their tach Y'd in with the hall sensor.
NefariousRC is offline Find More Posts by NefariousRC
Old Sep 02, 2011, 04:56 AM
Joined Aug 2002
No reported interface as yet, but as you are using RCExl ignition, just in case RCExl kill switch also
and missed the following post, on ARCG > Radios, :
"Don't use RCEXL switch as an optical kill switch", is recommended reading
Alan T.
A.T. is offline Find More Posts by A.T.
Old Sep 02, 2011, 01:42 PM
USA, CA, San Diego
Joined Jan 2011
Thank you. I did in fact see the info regarding the ignition kills.
Old Dec 08, 2011, 07:25 PM
Netherlands
Joined Jun 2006
Hi Guys,
I fixed this issue of feeding the CDI rpm output safely back to logger or telemetry input.
Watch this:
http://www.rcgroups.com/forums/showthread.php?t=1486857
Simple once you know how. I got data from RCEXL about the way the output works.
After that is was easy.
Let me you if this helps you.
Robke is offline Find More Posts by Robke
Old Oct 29, 2012, 04:37 AM
Joined Apr 2006
Hi Guys,
I use the RMP output from the RC-EXL directly to the Jeti MRPM-ac Sensor.
Use the black and withe leads that come out of the ignition unit.
When you don't have a readout, just switch the leads.
In the setup menu of the jeti-box set the number of poles to just one.
I use it to read out the RPM on my RC paraglider model:
www.rc-ppg.nl/en
Good luck
Piet
ukkie12342000 is offline Find More Posts by ukkie12342000
Discussion Tacho out from ignition to RPM input Robke Eagle Tree Systems 1 Dec 09, 2011 01:44 PM
Sold CRRC 26CC Gas engine with CH-RCEXL ignition Trade for electric plane donho1 Aircraft - Electric - Airplanes (FS/W) 4 Apr 20, 2011 08:16 AM
Sold I have a CRRC 26CC Gas engine with CH-RCEXL ignition to trade for a RTF electric p donho1 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Apr 18, 2011 03:20 PM
Discussion RCEXL Ignition Hall Sensor Test/ Timing Help tele1974 Fuel Plane Talk 0 Nov 09, 2009 02:46 PM
Discussion Rcexl Ignition Units challenger_i Engines 5 Sep 07, 2009 12:29 AM
