Old Sep 01, 2011, 02:05 PM
MaxGen is offline
Find More Posts by MaxGen
Canada, ON, Toronto
Joined Nov 2006
flight tips for a beginner
Hi all,
I've just built my first quad and have begun learning how to fly it. I fly R/C planes and I have a Blade mCX I play with, but the quad is new.
I've noticed the most dificult part about learning how to fly the quad is maintaining orientation. My flights typically consist of slow controlled take off, followed by drifting that I am afraid will become out of control, so I end up bringing it down a little hard in my rush to get it on the ground.
Are there any flying tips for beginners? Would it help to mix some rudder with the ailerons?
Scot...
MaxGen is offline Find More Posts by MaxGen
Old Sep 01, 2011, 02:14 PM
OLDTOM is offline
Find More Posts by OLDTOM
OLDTOM's Avatar
United States, TX, Waxahachie
Joined Jun 2011
Colored props are good, styrofoam balls, any thing to mark the front that is easy to see helps. Simulaters are helpful and fun also.
Give yourself plenty of space, keep practicing, it will get a lot more easy to make it do what you want it to.
OLDTOM is offline Find More Posts by OLDTOM
Old Sep 01, 2011, 02:54 PM
Multicopter is offline
Find More Posts by Multicopter
Joined Apr 2011
I use colored LED-lanterns. I also believe fewer arms makes it easier to keep the orientation, so I prefer a Y-6 over a flat 6.
Multicopter is offline Find More Posts by Multicopter
Old Sep 01, 2011, 10:30 PM
jpsabo is offline
Find More Posts by jpsabo
jpsabo's Avatar
Joined Feb 2011
Hi Scot -
I use an airplane model for my Spektrum DX8, but use expo to give more control of aileron, elevators and rudder. Color helps me orient. I have both an X and + mode quad and it certainly takes time and practice to fly these. Some hints I've gotten is to fly simple patterns. I've found open field flying helpful as well.
Color orientation can be as simple as electrical tape on props tips: http://dl.dropbox.com/u/788548/Quadcopter/IMG_1549.JPG or spray paint props and gear: http://dl.dropbox.com/u/788548/Quadcopter/IMG_1560.JPG
Basically, whatever works...
Regarding the drift, to an extent that is normal as the quad would not be able to hold an exact position unless it was using GPS. I'm using the QuadRino board and MultiWii software and with a bit of trim and tuning (and help from a barometer and mangetometer), position hold is very good. What flight controller are you using?
Regards,
John
Originally Posted by MaxGen View Post
Hi all,
Scot...
jpsabo is offline Find More Posts by jpsabo
Old Sep 02, 2011, 03:13 AM
SeismicCWave is online now
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
Hi all,
Scot...
As every one said. Make sure you can see the orientation of your machine. It will not matter when you cannot tell the orientation with your eyes.
The rest is just a matter of practicing. You have to do the same thing with your fixed wing and your Blade MCx. Practice with your Blade MCx hovering nose-in until you are totally comfortable. If you don't have that anymore use a flight sim.
The only way to succeed in a skill oriented task like flying RC is to practice, practice and practice.
SeismicCWave is online now Find More Posts by SeismicCWave
Idea Tips for a Beginner philipjames11 Electric Plane Talk 5 Sep 01, 2011 08:41 AM
Question Any indoor flight or Small field tips or threads? suseuser Micro Ready-to-Fly 10 Aug 17, 2011 10:18 AM
Help! first flight, any tips? keek135 Beginner Training Area (Aircraft-Electric) 14 Jul 15, 2011 05:03 PM
Discussion Tips for an acro beginner? Adrian A Slope 29 Jun 15, 2011 01:07 PM
Any EDF First Flight Tips for a Beginner? AndrewK Electric Ducted Fan Jet Talk 10 Sep 27, 2008 08:59 PM
