Old Sep 22, 2011, 04:12 PM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
Originally Posted by stevelmaa View Post
I actually reversed the servo locations and put the elevator servo right underneath the elevator stabilizer with the arm pointing down. No problem getting max throws. I am also using an elongated servo arm but its not maxed out. Don't know exactly the amount of throw but it stops dead in a wall and does tight KE Spins.
I also reversed the servo locations and have my extended arm right up next to the hor stab, but I was thinking of lowering the servo even more for a slightly longer arm. I am getting max throws now but would like to try a little more just to see if I like it a little better. Either that or I will put the linkage in the hole closest to the elevator and then make the cutout in the fuse a little bigger to allow more elevator movement. I'm not trying to say this plane isn't fantastic just the way it is I'm just curious if a little more elevator deflection would change it all that much. I don't know if I'm going to do any of this for sure, just mostly thinking about it.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Sep 22, 2011, 04:28 PM
stevelmaa is online now
Find More Posts by stevelmaa
Renton, Wa.
Joined Feb 2006
Hey Jet. When you are saying that you have your extended arm right up next to the hor. stab, does this mean that the arm is pointed up, and just brushing the bottom of the hor. stab. I have mine opposite. The arm is pointed down. Makes for a weird angle but the plane, being as light as it is, is'nt affected and it might increase your throws some. I am also using Dubro connectors, the kind that are included with the 3DH kits, which allows for free rotation. Using HS 65 MG's
stevelmaa is online now Find More Posts by stevelmaa
Old Sep 22, 2011, 05:31 PM
Burke, VA
Joined Sep 2009
Yeah it's pointed up and it just clears the underside of the hor stab. Hmm, I might try going down with it, the reason I didn't go this route before is I thought it was just too much of an angle and once the angle of the arm is turned so far it just pulls the horn forward instead of causing the horn to rotate around the axis of the elevator hinge. I don't know if this is a good explanation or not.
Old Sep 22, 2011, 05:53 PM
Renton, Wa.
Joined Feb 2006
Perfectly good explanation and thats what I thought also. I think I have just the right length of modified servo arm and control horn though that its just under that scenario. Even with that happening however the throw up and down, at least to me, is a lot more than the other way. I also used the Control Horns Twisted Hobbys "A"
http://shop.twistedhobbys.com/Contro...Mounts_c17.htm
also. Which might make a difference . Did not like the stock control horns so ordered those also. Had to dremmel off the little tab in front but they hold up well.
Old Sep 22, 2011, 09:10 PM
mtwargo is online now
Find More Posts by mtwargo
PA Team Pilot
mtwargo's Avatar
United States, FL, Orlando
Joined Oct 2008
Ok Guys... My Extra Slick All lit up!!!!!
I heard twistedhobbys was doing their own Lighting system... So I did My own.
Michael Wargo Flies the TwistedHobbys Extra Slick at night (3 min 49 sec)
mtwargo is online now Find More Posts by mtwargo
Old Sep 22, 2011, 09:53 PM
livinma1 is offline
Find More Posts by livinma1
livinma1's Avatar
United States, GA, Buford
Joined Jun 2003
Very nice Mike... Which lights did you use ?
livinma1 is offline Find More Posts by livinma1
Old Sep 22, 2011, 09:54 PM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
Looks good Michael! Coming to E Nall?
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Sep 23, 2011, 05:16 AM
Burke, VA
Joined Sep 2009
I was looking at the plane last night and decided not to modify it any further for more elevator deflection. On down elevator it's already as far as the bevel in the stab/elevator will allow and I'm not going to cut them apart and rebevel. Not that big a deal, it flies most excellent just as is. I did cut off the piece of cf that I had put in as a tail skid and made a new one out of piano wire, the cf one was getting ground down too much already. I also noticed that the piece of EPP for the tail skid kept flexing as the plane sat so I added a piece of flat cf through the skid into the fuse to keep it straight.
Old Sep 23, 2011, 11:28 AM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
Nice vid mtwargo, the lighting system looks great, makes me want to have a go at that for the dark winter nights. The music and the editing all goes together nicely with some nice flying. How much weight does the lighting add? it doesn't look like it makes much difference to the flying.
Aviefly is offline Find More Posts by Aviefly
Old Sep 23, 2011, 04:16 PM
PA Team Pilot
mtwargo's Avatar
Joined Oct 2008
these lights were from hobbyking... Lumifly.... And Herc... I will not be at enall... can't make it! Bummer. I am so busy at work.
Old Sep 23, 2011, 04:48 PM
livinma1 is offline
livinma1's Avatar
Joined Jun 2003
Thanks !
Old Sep 24, 2011, 07:32 AM
Burke, VA
Joined Sep 2009
Well it finally wasn't raining this morning, and no fog so I got out early for a half dozen flights. I have been running my plane with a 5% throttle curve because the motor stutters just a little at startup, so just for the fun of it today I disabled the throttle curve and wow, all of a sudden all my slow high alpha stuff started to come around. I have been struggling a little with harriers, I had to fly at a pretty low aoa and at a little faster speed than I like. Now with no throttle curve I can go slower and a little higher aoa and like it much better. This airplane is just so responsive at very low throttle that the throttle curve was messing it up, I'm liking it even better now.
Old Sep 24, 2011, 03:23 PM
RCredneck is offline
Find More Posts by RCredneck
Skullbone RC
RCredneck's Avatar
Texas
Joined Nov 2009
Originally Posted by RCredneck View Post
Just ordered this, SWEET!!!!!
...and she's arrived, WOO-HOO!! Won't get to start on her till tomorrow but it looks killer.
RCredneck is offline Find More Posts by RCredneck
Old Sep 25, 2011, 07:04 AM
Dan5.0 is offline
Find More Posts by Dan5.0
Dan5.0's Avatar
Joined Dec 2008
Congrats on the new bird.
Mike great vid!
Dan5.0 is offline Find More Posts by Dan5.0
Old Sep 25, 2011, 07:55 AM
Wingin' Wayne is offline
Find More Posts by Wingin' Wayne
I like the violent stuff!
Costa Mesa, CA
I love my Telink Yak and was going to order a backup. Now I'm thinking about this one instead. From what I've read on this thread, the Slick is an improvement over the Yak. Hard to believe, but is that the feeling most have? Thanks guys!
Wingin' Wayne is offline Find More Posts by Wingin' Wayne
Build Log Twisted Hobbys - Telink 43" SU 29 - Build, Fly, Vid hercdriver7777 3D Foamies 634 Nov 16, 2014 09:06 PM
Discussion Twisted Hobbys - 32" Xtra Slick - Build, Fly, Vid hercdriver7777 3D Foamies 3018 Jul 03, 2014 12:53 PM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion Twisted Hobbys Big Slick Build Thread garyholland 3D Foamies 165 Mar 08, 2012 11:45 AM
Discussion Telink/ Twisted Hobbys Xtra Slick (big) maineflyer1 3D Foamies 21 Nov 07, 2011 06:04 AM
