Old Aug 31, 2011, 01:43 PM
FRIENDLY FIRE is offline
Find More Posts by FRIENDLY FIRE
Joined Aug 2011
Build Log
Sukhoi/Hal Pak Fa concept FGFA design/build
DESIGNED FROM PICS AND NOT EXACT...JUST RELATIVE SHAPE. TOP INLETS ALLOW AIRFLOW TO ENTER THROUGH TOP OF WING. DUAL LAYERS FORM SLIGHT AIRFOIL. ONLY SINGLE ELEVONS ON PROTOTYPE UNTIL SUCCESSFUL FLIGHT. WORKING AIRBRAKE, ALTHOUGH TEST WILL BE CONDUCTED AT REASONABLE ALTITUDE JUST TO BE SAFE. DESIGNED FOR EITHER EDF OR PUSHER, AND WILL GO WITH A PROP VERSION ON THE TEST VEHICLE.
TEST PLATFORM CONSTRUCTED OF FOAM BOARD, NEXT VERSION WILL HAVE REVISIONS AND DEPRON CONSTRUCTION. PLANS TO FOLLOW IF THIS CONCOCTION OF FOAM AND GLUE INDEED FLYS.
AND BEFORE I GET CALLED OUT, I KNOW THE CANOPY ISNT SCALE...NEITHER IS THE LENGTH, OR BRAKE POSITION, OR SPLIT ELEVONS, OR THE BEND IN THE BEAK...AND THE PILOT/ENGINEER IS NEITHER RUSSIAN OR INDIAN.
WINGSPAN-28"
LENGTH-40"
WEIGHT-CLASSIFIED
NOW, LET THE COMMENTS AND CRITICISMS COMMENCE.
FRIENDLY FIRE is offline Find More Posts by FRIENDLY FIRE
Old Sep 01, 2011, 12:39 AM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
I think you are off to a good start. it looks like the concept plane.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Sep 01, 2011, 02:00 AM
mesnick is offline
Find More Posts by mesnick
mesnick's Avatar
Italy, Lazio, Rome
Joined Nov 2004
compliment a nice job
I like to see progress
Mesnick
mesnick is offline Find More Posts by mesnick
Old Sep 01, 2011, 11:39 AM
Joined Aug 2011
THANKS GUYS
HERES A FEW PICS OF THE PROTOTYPE BUILD PROGRESSION, DONT WANT TO PUT TOO MUCH DETAIL UNTIL THE BUGS ARE WORKED OUT...ON THE NEXT BUILD I'LL OUTLINE MORE STEP BY STEP ASSEMBLY.
Old Sep 01, 2011, 11:54 AM
Joined Aug 2011
Old Sep 02, 2011, 06:37 AM
Hover or die is offline
Find More Posts by Hover or die
it wasn't me flying that plane
Hover or die's Avatar
United States, NC, Wilmington
Joined Mar 2011
Nice looking start...Certainly nothing to be ashamed of!!Nothing like building from pics and you have done a fine job..Good luck on your maiden!
Take care............Chris
Hover or die is offline Find More Posts by Hover or die
Old Sep 02, 2011, 11:31 AM
Joined Aug 2011
HERE YOU CAN SEE THE INLET FROM THE TOP LAYER SINKS INTO THE OPENING IN THE BOTTOM LAYER ADDING TO, FOR GOOD OR BAD, THE AIR FLOW OF THE LOWER INLETS...WE WILL SEE.
Old Sep 02, 2011, 11:34 AM
Joined Aug 2011
PROFILE-ISH SHOT SHOWING ARC IN WING...
Old Sep 02, 2011, 02:14 PM
Joined Jan 2009
looks great to me. those upper inlets shouldn't give you too many problems, as long as they aren't too close to the fans. they'll basically act like cheater holes. this won't be great for top speed, but will be awesome for static thrust for takeoff and vertical maneuvers. this is all dependant on your intake area and what percentage of FSA they are, without the top inlets. it would be interesting to know what the area of the bottom inlets are and the top inlets, then combine them together and put that against the area of your fans.
is this for single fan, or twin fans? if it's a single, all those intakes might be too much and you'll scrub top speed, which isn't really an issue anyway.
Rich
Old Sep 03, 2011, 06:54 AM
D_FAST is online now
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
great start! love the look of this bird.
D_FAST is online now Find More Posts by D_FAST
Old Sep 04, 2011, 06:27 AM
frank40 is offline
Find More Posts by frank40
frank40's Avatar
Denmark
Joined Sep 2005
Looks great FRIENDLY FIRE, glad you are friendly
frank40 is offline Find More Posts by frank40
Old Sep 10, 2011, 05:50 PM
Joined Aug 2011
Rich-it will be for twins, although that will be later, and better thrust in exchange for high speed is cool for a first version, for me at least...tests will tell all.
Thanks guys
Old Sep 10, 2011, 05:53 PM
Joined Aug 2011
HERE IS A SHOT OF LIGHT OUTSIDE OF THE INLET, AND ONE WITH LIGHT COMING THHROUGH THE UPPER INLET
Old Sep 10, 2011, 05:55 PM
Joined Aug 2011
AND THE AIRBRAKE...
Old Sep 12, 2011, 12:47 PM
voyix is offline
Find More Posts by voyix
USA, FL, Miami
Joined Nov 2010
hey i built mine but its very tail heavy
I havent had time to post the pics yet but here was my startup page
http://www.rcgroups.com/forums/showt...1456436&page=1
voyix is offline Find More Posts by voyix
Build Log Sukhoi PAK FA - EASYBUILD nac Pusher Prop Jet Models 81 Jan 31, 2016 10:42 AM
Help! The Pak-Fa Concept. How Should I....? ICU Scratchbuilt EDFs 33 Mar 14, 2015 09:10 PM
Build Log Sukhoi Pak Fa T-50 podiumjets Scratchbuilt EDFs 238 Feb 10, 2015 02:06 PM
New Product Sukhoi Pak Fa T-50 podiumjets Foamy EDFs 413 Jun 04, 2014 04:59 AM
Idea 90mm Sukhoi PAK FA T-50 by Podiumjets, suggestion by me Mario_Shinobi Foamy EDFs 15 May 19, 2011 12:47 PM
