Old Aug 30, 2011, 11:41 PM
bigo66 is offline
Find More Posts by bigo66
Orlin the fpv-a-holic
bigo66's Avatar
Joined Dec 2010
Help!
Futaba T7C refuses to work with throttle trim. Plea for help :)
Have tried everything. Running a futaba T7C and while trying to get an eagle tree osd, RTH working discovered the throttle trim does not work. The trim button moves and there is an audible tone, but once the throttle is running the up and down trim buttons have no effect. Have a turnigy 60 amp brushless esc. It's important this is functional. Any help or recommendations is greatly appreciated.
bigo66 is offline Find More Posts by bigo66
Old Aug 31, 2011, 01:20 PM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
If throttle trim switch is broken, you can use sub-trim to set trim position.
Throttle trim is rarely used during flight once it is set either gas or electric.
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old Sep 01, 2011, 01:23 AM
bigo66 is offline
bigo66's Avatar
Joined Dec 2010
Thanks for the reply. Here's an update. Called Futaba and discovered the transmitter was programmed to reverse throttle. Switched to normal, then reversed the throttle channel. Trim is now working the way it should.
Discussion RTH question on Futaba T7C throttle / failsafe trigger bigo66 FPV Talk 0 Aug 28, 2011 09:57 PM
Discussion Futaba 9cap Throttle trim problem... Mykro Radios 3 Aug 17, 2011 05:54 AM
Discussion Cant Get the throttle To work on my Futaba 7c Vyas Radios 2 May 18, 2011 01:30 AM
Discussion Help with my Futaba T7C 2.4 Radio, How to Program this... flywmoi Radios 2 Mar 25, 2011 02:12 AM
Discussion Throttle Hold switch assignment for a Futaba T7C? Tommygunn Radios 3 Oct 26, 2009 10:17 AM
