Espritmodel.com Heli Air
Old Aug 30, 2011, 10:12 PM
Tony97's Avatar
Joined May 2004
Can't get Guardian to work
I installed the guardian today. Light blinks, servo display and art. horizon all work. I ran setup wizard too. The Guardian isn't on or working. No "G" on the screen. What am I missing? I tried different switch settings too like AUX1 & AUX2, AUX1 3 position, etc. No luck. Thought was my AUX2 switch. Moved to gear switch. No luck. HELP.
Tony97 is offline Find More Posts by Tony97
Old Aug 30, 2011, 10:36 PM
I should be flying right now!
al1242's Avatar
Indiana
Joined May 2010
Did you go into the Configure radio menu and turn on the guardian under "Stabilization/Elevon mixing on"? It is kind of confusing but that must be "yes" and make sure wing type is standard(if it is a normal plane)
al1242 is offline Find More Posts by al1242
Discussion PARIS v4.0 board. Can't get it to work. Kyle D. Multirotor Talk 28 Dec 25, 2011 09:15 PM
Discussion Can't get Co-Pilot II Display to work on Vista 64bit system ozsteel FMA Direct 1 Aug 15, 2011 08:44 AM
Help! Just can't get this loft to work (SW2010) ICU CAD/CAM 12 Jul 12, 2011 09:15 PM
Discussion Can't get Trainer function to work on Futaba 6EXA FlyValue Radios 2 May 17, 2011 02:32 AM
Question Can't get the Field Link programmer to work DonDuc Castle Creations 3 Mar 28, 2011 10:58 AM
