Old Sep 24, 2012, 01:52 PM
490905002 is offline
Find More Posts by 490905002
Joined Jan 2010
My friend.
This is not T1000, T580P + (GPS).
490905002 is offline Find More Posts by 490905002
Old Sep 24, 2012, 01:54 PM
Joined Jan 2010
T1000
Functions and features
T1000 (with GPS) is high-end model developed based on the T1000 platform; it is targeted for professional aerial photo and video usage.
1) Safe: Flight control system running in parallel via Remote controller and ground station to avoid possibility of accident. Also included low voltage alarm and lost signal auto return home function.
2) Efficient: 17 Slow Fly propellers + disc brushless motor, maximum efficient unto 12.8g/W.
3) Stable: 6 DOF, equipped with industrial grade high impact resistance and low drift MEMS sensors.
4) Simple: Pre-configured with remote controller, no setup required
5) Easy: Quick model setup, with two axis stabilized gimbals.
6) Operating temperature:-10~+60℃。
Functions and capabilities:
1) Auto take off (Ground station control)
2) Altitude hold (via remote control)
3) Position hold (Remote or ground station control)
4) Waypoint flight (ground station control)
5) Auto return home and auto landing (Remote or ground station control)
Camera Gimbals can be installed under the frame which allowed quick removal from the frame. The tilt and roll angle can be controlled via remote control. It uses the suspension mounting system which provides effective elimination of high and low frequency vibration.
Technical parameters
Model Dimension 1000 1000 160 Mm
Maximum Dimension 1430 1430 400 Mm
Folded Dimension D240 800 Mm
Motor distance Motor shaft to motor shaft (opposite) 1000mm
Propellers 17 CW/CCW customized 17inch
Battery LiPo 5S 20000mAh (weight 890g*2) Standard 1P
Model weight Excludes Battery, Receiver, payload 1200g
Take off weight 5S 10000mAh Lipo、RX、Camera Gimbal 3000g
Payload DV/Camera ≤1500g
Max. Trust With 1P standard Lipo 11000g
Max. Payload With 1P standard Lipo ≤2500g
Max. Take off weight With 1P standard Lipo 5000g
Flight distance Signal coverage zone(300M radius or 2KM) Out of signal coverage zone, no flight data, duration will depends on Lipo used
Flight no load 5S 10000mAh*2 Lipo, RX 55~65 Minutes
Flight load ≤1500g 5S 10000mAh*2 Lipo, RX 40~48 Minutes
Wind Resistance ≤6 class;Normal waypoint flights unto Class 4 wind Normal flight at class 5 wind
Old Sep 24, 2012, 01:55 PM
Joined Jan 2010
Description:
http://www.lotusrc.net/product1.asp?id=309
Old Sep 24, 2012, 01:57 PM
Joined Jan 2010
These two models are GPS version.However, T1000 Parameter far exceeds T580P +.Of course, the price is also far beyond.
Old Sep 24, 2012, 02:02 PM
Joined Jan 2010
Lotus RC T-580P+ with Gopro (8 min 54 sec)
Old Sep 24, 2012, 10:31 PM
LIUCHUNYAN is offline
Find More Posts by LIUCHUNYAN
Joined Jul 2012
The working conditions of aircraft
In fuselage of T580 built-in has a buzzer.All the information at vehicle work , rely on the buzzer sound to inform the operator, machine in any state at present . In that case, understanding buzzer different voices represents what state, it is very important.
Vehicle working condition were: 1. The power on initialization. 2. Standby/flight two states, the steps one by one.The steps one by one.
LIUCHUNYAN is offline Find More Posts by LIUCHUNYAN
Old Sep 25, 2012, 04:26 AM
Joined Jan 2010
This mask, you like it?
Description:
Description:
Description:
Description:
Old Sep 25, 2012, 06:44 AM
malcr001 is offline
Find More Posts by malcr001
malcr001's Avatar
United Kingdom, England, Gt Lon
Joined Nov 2007
Not a fan of those designs to be honest. Why? because it makes it look like a toy. Over the years I have come to understand that those often in eastern countries like to make their rc copters, planes etc look like toys where as over here not so much. After all my quad and groundstation must cost over 2k. Designs like this make it look cheaper than it is. If I spent that much I dont want it too look like a toy. If anything I want it to look as proffessional as possible. I have gone the oposite direction. I like to think my quad almost looks like it would be owned by the military. I will post up pics soon.
malcr001 is offline Find More Posts by malcr001
Old Sep 25, 2012, 08:08 PM
Joined Jul 2012
1. Power on initialization:
Please put the T580 on the floor or solid plane, and don't move it. To T580 power-on instant, buzzer will let out a whoop of short ring, said flight control system has been power on beganing to work. (if not send out sound, please check the fuselage bottom flight control power supply switch is opened or not , buzzer connection plug is loose or not . Two seconds later, T580 issued the first sound, indicates that the battery voltage detection pass, the battery has enough power to flight. And in two seconds, the second ring, said flight control detection to normal remote signal, and throttle lever is in the lowest position . Waiting for four seconds, T580 issued the third ring, it is three sound. Said flight control has completed sensor self-checking, into a standby state, it can take off at any time .
If a second interval long ring of the buzzer arise when power on, indicates that the battery is low electricity, can't flight . Please replace the battery. After voltage self-checking pass, an intermittent long ring arise , indicates no remote control signal or the throttle don't in the lowest position, please check the remote control equipment and flight control to the receiver of the connecting line.
2. Standby/flight
Under standby/flight condition, when the battery low electric aircraft will be issued a series of rapid short sound, and inform the user, the battery is low electricity, if it is in flight, please land on the ground to replace the battery as quickly as possible. Remote signal loss, can also send rapid short sound, and the aircraft will enter autonomous landing, fuselage recover level position, slow down height, until the fall to the ground. Landing function is to assume that aircraft in an ideal windless environment ongoing self protection to land, it is not absolutely safe, design purpose is to reduce the loss of the plane crash. Start aircraft , buzzer for two sound short ring, and remind users motors are about to begin turning, pay attention to safety. Stop for a sound long ring.
- - - - - - - - - - - - - - - - - - self-check sound for three short ring .T580 indicates for cross flight mode, three long ring for X flight mode. - - - - - - - - - - - - - - - - - - - - - -
Old Sep 26, 2012, 06:59 AM
Joined Jan 2010
Thank you very much.
We look forward to seeing your pictures.
Old Sep 26, 2012, 09:51 AM
HummingbirdRPV is offline
Find More Posts by HummingbirdRPV
HummingbirdRPV's Avatar
Canada, AB, Edmonton
Joined Mar 2012
So what make of flight controller do you have in this machine? Does it have a connection to update firmware?
HummingbirdRPV is offline Find More Posts by HummingbirdRPV
Old Sep 26, 2012, 01:07 PM
Joined Jan 2010
It is to be controlled by the ground station.
Not need to upgrade.
Old Sep 26, 2012, 01:11 PM
Joined Jan 2010
The aircraft relatively long time LOTUSRC flight.
Flying a long time, we must ensure a favorable factor of three aspects:
Power system efficiency is high enough (the match between the motor, blades, power transfer to the right).
The machine itself is light enough (to use a new or special material).
Ensure the strength of the body (to use high-strength materials).
Description:
Old Sep 26, 2012, 02:32 PM
Joined Jan 2010
LotusRC T580P+ with Upgraded ESC Dual Cam Flight Review (8 min 39 sec)
Old Sep 26, 2012, 02:33 PM
Joined Jan 2010
HeliPal - T580P+ Quadcopter Test Flight 01 (5 min 36 sec)
New Product ARF LotusRC T580 quadcopter LotusRC Multirotor Talk 3741 Jan 09, 2012 11:23 AM
Question XAircraft X650 vs. LotusRC T580 ~>Miha<~ Multirotor Talk 8 Sep 08, 2011 02:19 PM
Discussion Our stories-developers and pilots,started with the LotusRC T580 flips yiny0730 Multirotor Talk 3 Jul 02, 2011 06:58 AM
