Old Sep 22, 2012, 06:58 AM
denodan is offline
Find More Posts by denodan
Joined Jun 2012
No Just tried mine, flash red when bound with RX and no throttle, and go blue with power on, first time I only really noticed it, and somwhere near the centre there is one that does flash blue. first time I noticed these colours.
Mine looks good now I have red LED lights for back and blue for the front. Looks good at night.
denodan is offline Find More Posts by denodan
Old Sep 22, 2012, 06:59 AM
denodan is offline
Joined Jun 2012
When are they coming out with an ESC board that takes 4s and 5s batteries?
Old Sep 22, 2012, 07:28 AM
490905002 is offline
Find More Posts by 490905002
Joined Jan 2010
The GPS version you can use the 4S or 5S.
Conventional products, plus a dedicated module.
490905002 is offline Find More Posts by 490905002
Old Sep 22, 2012, 07:25 PM
loquacious is online now
Find More Posts by loquacious
loquacious's Avatar
Australia, WA, Perth
Joined Apr 2012
Originally Posted by denodan View Post
His LED on the board is flashing blue. I am sure mine flashes red, when it's going, can see it flashing red when flying, and even when the TX has bind to the Lotus and mine is working fine, flies well.
My TX is definitely bound. My receiver flashes red then goes solid red after the three beeps that signal it is in X mode. All channels seems to work properly. I am just reluctant to fly it with the motor seemingly not spinning properly.
Can you tell me at what point on your throttle do you achieve lift off? The win has died down today so might get brave and see if I can get it airborne without doing any damage.
loquacious is online now Find More Posts by loquacious
Old Sep 22, 2012, 07:44 PM
loquacious's Avatar
Joined Apr 2012
Originally Posted by 490905002 View Post
Please upload the fuselage barcode number.
PHOTO.
Thanks.
Here is my barcode number
Old Sep 22, 2012, 09:50 PM
loquacious's Avatar
Joined Apr 2012
Not Happy !!
I took the T580P+ outside to see how it would fly. Throttled up, trimmed it and it took to the sky, I was elated for all of about 15 - 20 seconds. Then the motor on the suspect arm seemed to slow and down it came crashing heavily and breaking an arm and motor (see pics)
Upon close inspection all three wires from the escape top the motor on the suspect arm are "stripped" in almost identical places and I am thinking this could have been the cause of less power to the motor on that arm.
I now have a crashed quad and no idea if and where I can get another arm to replace the smashed one. The other three motors power up still and work well.
Old Sep 22, 2012, 09:55 PM
loquacious's Avatar
Joined Apr 2012
Is there anywhere I can get another arm for my quad. It is the arm coded "blue".
Old Sep 23, 2012, 12:54 AM
denodan is offline
Joined Jun 2012
http://www.goodluckbuy.com/lotusrc-t...raft-2pcs.html
Here is where you can get arms. Sorry your having trouble with your 580P+.
Old Sep 23, 2012, 02:44 AM
loquacious's Avatar
Joined Apr 2012
I need the full arm with wiring .. as you can see in my photos the wiring is bared and the black wire actually broke off.
I need this but they are out of stock .... http://www.hobby-wing.com/t580pp-ins...-arm-beam.html
Old Sep 23, 2012, 02:54 AM
denodan is offline
Joined Jun 2012
Try LotusRC. also does anyone know the price of the LotusT1000?
Old Sep 23, 2012, 08:57 PM
LIUCHUNYAN is offline
Find More Posts by LIUCHUNYAN
Joined Jul 2012
Propeller:T580 use 4 pcs 1260 specifications of plastic composite material is frontal and versa professional propllers, in installation please in strict accordance with the instructions of the guidance. Because of the motor shaft position are nylon ring, propeller installation shall not pressure to ring, need to keep 1 mm or so clearance, to prevent motor bearings is pressured leading to motor rotation hindered.
Fuselage structure: check whether the screw loose or not , guarantee the structure fit solid tightly , no exists loose sloshing phenomenon . So far, the basic work before flight are ready.
LIUCHUNYAN is offline Find More Posts by LIUCHUNYAN
Old Sep 23, 2012, 09:13 PM
Joined Jul 2012
Old Sep 24, 2012, 07:28 AM
Joined Jan 2010
www.lotusrc.net
Old Sep 24, 2012, 07:29 AM
Joined Jan 2010
About USD4700.00.
Old Sep 24, 2012, 09:02 AM
aopen3434 is offline
Find More Posts by aopen3434
Joined Jul 2011
http://mymobilemms.com/OFFTHEGRIDWAT...roducts_id=114
LOTUSRC T1000 with GPS Quadcopter (Folding design)GPS Edition
$3,000.00
Ready to fly kit from factory non custom craft!
lotus RC T1000, T580P+ (with GPS) is high-end model developed based on the T580P+ platform, it is targeted for professional aerial photo and video usage.
1) Safe: Flight control system running in parallel via Remote controller and ground station to avoid possibility of accident. Also included low voltage alarm and lost signal auto return home function.
2) Efficient: 14” Slow Fly propellers + disc brushless motor, maximum efficient unto 12.2g/W.
3) Stable: 6 DOF, utilizing industrial grade high impact resistance and low drift MEMS sensors.
4) Simple: Pre-configured with remote controller, no setup required
5) Easy: Quick model setup, with two axis stabilized gimbals.
6) Operating temperature:-10~+60℃。
Functions and capabilities:
1) Auto take off (Ground station control)
2) Altitude hold (via remote control)
3) Position hold (Remote or ground station control)
4) Way point flight (ground station control)
5) Auto return home and auto landing (Remote or ground station control)
Camera Gimbal can be installed under the frame which allowed quick removal from the frame. The tilt and roll angle can be controlled via remote control. It uses the suspension mounting system which provides effective elimination of high and low frequency vibration.
http://WWW.OFFTHEGRIDWATER.CA
Item
Description
Specifications
Qty
Unit
1
Body/cover
Compounded industrial Plastic + 3K Carbon
1
Set
2
Arm
3K Carbon
4
PC
3
Skid
Fibreglass/plastic/strengthen aluminum
1
Set
4
Motor
C3410 KV420
High efficiency out runner brushless
4
PC
5
Propellers
1445 Compounded industrial Plastic
2
Pairs
6
Camera Gimbal (Option)
Carbon fibre, dual axis
1
Set
7
Gimbal Servo
High speed digital metal gear
2
PC
8
Brushless ESC
2-6S 18A high speed ESC
1
Set
9
GPS+INS Auto stabilize system
1
Set
10 Radio system WFLY 9-ch 2.4G radio WFT09II (customized version) 1 set
Dimension 634 634 296
Mm
Maximum Dimension
960 960 296
Mm
Folded Dimension
D160 520
Mm
Motor distance
Motor shaft to motor shaft (opposite)
600mm
Propellers
1447 CW/CCW customized
14inch
Battery
LiPo 5S 10000mAh (weight 890g)
Standard 1P
Model weight
Excludes Battery, Receiver, payload
1100g
Take off weight
5S 10000mAh Lipo、RX、Camera Gimbal
2300g
Payload
GOPRO/DV/light SLR
≤700g
Max. Trust
With 1P standard Lipo
8800g
Max. Payload
≤1000g
Max. Take off weight
3000g
Flight distance
Signal coverage zone(300M radius or 2KM)
Out of signal coverage zone, no flight data, duration will depends on Lipo used
Flight time 1
3S 4300mAh 1P Lipo, RX
10 Minutes
Flight time 2
4S 10000mAh 1P Lipo, RX
15~20 Minutes
Flight time 3
5S 10000mAh 1P Lipo, RX
25~30 Minutes
Wind Resistence
≤6 class;Normal waypoint flights upto Class 4 wind
Normal flight at class 5 wind
aopen3434 is offline Find More Posts by aopen3434
Site Sponsor
New Product ARF LotusRC T580 quadcopter LotusRC Multirotor Talk 3741 Jan 09, 2012 11:23 AM
Question XAircraft X650 vs. LotusRC T580 ~>Miha<~ Multirotor Talk 8 Sep 08, 2011 02:19 PM
Discussion Our stories-developers and pilots,started with the LotusRC T580 flips yiny0730 Multirotor Talk 3 Jul 02, 2011 06:58 AM
