Joined Jan 2010
This size, and the T380 LOTUSRC relative ratio. T380 can fly up to 28 minutes. Look at the T380 specifications: |
Joined Jan 2010
T380
Technical parameters Aircraft size 410x410x140 mm Maximum expandable size 615x615x140 mm Motor to motor Diagonal distance between two motor centers 410mm Propellers frontal and versa professional props 8045 8inch Battery LiPo 3S 2200mAh 20C standard1P Aircraft weight(kit only) Without battery, receiver, applicable payload 430gram Take-off weight 3S 2200mAh 1P battery, receiver 610gram Recommended payload Camera mount ≤380gram Maximum payload Use standard 1P battery ≤380gram Maximum takeoff weight Use standard 1P battery 1300gram Flight distance Visual area - Flight time 3S 2200mAh 1Pbattery, receiver 18~25mins Specific information:http://www.lotusrc.net/product1.asp?id=297 |
Joined Jan 2010
In fact, T580P + (GPS) version of the time, not short, the parameters are as follows:
Flight time 1 3S 4300mAh 1P Lipo, RX 10 Minutes Flight time 2 4S 10000mAh 1P Lipo, RX 15 ~ 20 Minutes Flight time 3 5S 10000mAh 1P Lipo, RX 25 ~ 30 Minutes Wind Resistance ≤ 6 class; Normal waypoint flights unto Class 4 wind Normal flight at class 5 wind Specific information is as follows: http://www.lotusrc.net/product1.asp?id=308 |
Joined Jan 2010
Joined Jan 2010
Joined Jun 2012
Ether buy from here if you can, as you get the option of what plug, pick deans, or buy a battery at a model shop, or online and find a good hobby shop to change it to a deans plug.
http://www.mrpositive.co.nz/brands/T...&sort=priceasc |
Joined Jan 2010
| Thread Tools | |
| New Product ARF LotusRC T580 quadcopter | LotusRC | Multirotor Talk | 3741 | Jan 09, 2012 11:23 AM |
| Question XAircraft X650 vs. LotusRC T580 | ~>Miha<~ | Multirotor Talk | 8 | Sep 08, 2011 02:19 PM |
| Discussion Our stories-developers and pilots,started with the LotusRC T580 flips | yiny0730 | Multirotor Talk | 3 | Jul 02, 2011 06:58 AM |
