Old Jul 19, 2012, 01:28 PM
490905002 is offline
Find More Posts by 490905002
Joined Jan 2010
http://www.rcgroups.com/forums/showt...4#post21739679
490905002 is offline Find More Posts by 490905002
Old Jul 19, 2012, 01:29 PM
Joined Jan 2010
http://www.rcgroups.com/forums/showt...2#post22186455
Old Jul 19, 2012, 01:30 PM
Joined Jan 2010
Specifications:
1. Complete new designed multilayer circuit with thicker copper foil,whitch is good for anti-electric shock.and thermal performance.
2. MOSFET is drived by special chip. Higher reliability and lower heat.
3. Working voltage:7-11.1V,suitable for 2-3S battery.
4. Sustainable output for each motor:18A. Instantaneous output for each motor:22A, No longer than 10s.
5. New designed communication protocol with better anti-interference ability.
6. Improved start algorithm to reduce the instantaneous electric shock to the battery.System can be started more quickly and smoothly.
7. Control refresh rate:500HZ.IIC interface.
Great Support Information from Lotus to exiting and new T580 users: (May need some waiting time if local stock is not immediately available, valid till the announcement of end date)
1. All old ESCs can be sent back to your distributors for a free exchange to the new version, but you need to pay for the return shipping fee (both way).In return, you will get one pair of props (either color of your choice) free as a token of appreciation of your support on T580.
2. A gift to all the new purchase of T580: two pair of props:a orange pair and a black pair.
3. A gift to all the new purchase of the new ESC: a pair of props with your choice of color.
Old Aug 20, 2012, 10:21 PM
Joined Jan 2010
Description:
Description:
Description:
Description:
Description:
Description:
Old Aug 24, 2012, 01:00 AM
LIUCHUNYAN is offline
Find More Posts by LIUCHUNYAN
Joined Jul 2012
T580 looks like the T580P , they are similar with each other . But their motors and landing gear's color are not the same , T580 is blue , while T580P is orange .
LIUCHUNYAN is offline Find More Posts by LIUCHUNYAN
Old Aug 24, 2012, 04:48 AM
andrebandre is offline
Find More Posts by andrebandre
andrebandre's Avatar
United States, NM, Clovis
Joined Jul 2006
@490905002
I would like to get for my P+, a camera gimbal like the one pictured below.
Do you happen to know where i might be able to find one?
andrebandre is offline Find More Posts by andrebandre
Old Aug 24, 2012, 08:00 AM
denodan is offline
Find More Posts by denodan
Joined Jun 2012
Originally Posted by alishanmao View Post
What radio are you using? i had this issue when using walkera radio. no matter what the thing kept beeping. I switched to spektrum all worked. Futaba All worked.
If you are using spektrum and futaba and still the same stuff, possibly something is wrong with those 7 Quality control signatures
can you like do a video showing ESC and board clearly and that sound is clear too. I can send video to LotusRC and ask them what is happening. we have solved one such problem before doing the same.
I am using a Devo 8s with my Lotus 580P+, just got a Lotus, flies well, holds the altitude pretty well indeed, but Does not sit as Still as Ali's demos on You Tube, So have to still be on the stick for ailerons and elevator, but throttle holds pretty well indeed, but if there is a wind can effect height slight.
Flying using a 4500 mAh battery, which can give me over 15 Mins flying time, so seems to fly well at the moment, so far have had about 8 flights and going well.
I am not sure, but had it set to Heli mode, then went Aircraft mode as suggested in the Manual, and may be flying slightly better. Will soon have my Camera mount, and getting a set of LED's.
denodan is offline Find More Posts by denodan
Old Aug 24, 2012, 10:33 AM
Joined Jan 2010
Originally Posted by andrebandre View Post
@490905002
pls email to me
flying.yan@163.com
Description:
Description:
Old Aug 24, 2012, 10:36 AM
Joined Jan 2010
You can try to debug remote control D / E curve, adjusted to a slash.The helicopter mode using the remote control.
Old Aug 24, 2012, 10:42 AM
Joined Jan 2010
T580/T580P+ stable delicate adjustment D / E curve settings.
T580 uses all used for aerial photography and FPV, good feel and stability in the pursuit of below 10C for example, introduced to set the D / E curve, it is a good feel and stability. Varies from person to person, just to bring the effect of forward imperfect exhibitions
1.
Open 10C power switch, and gets into a menu. Choose the second D / E set.
2.
To enter the sub-menu is as follows:
Description:
Old Aug 24, 2012, 10:45 AM
Joined Jan 2010
3.
1 adjustment AILE
Is the fixed-wing inside the aileron
Set of curves, adjusted to plus or minus 36% (operating in different people feel different, you can self-adjust)
Rudder amount was adjusted to 50%. The switch D rocker switch.
Description:
Old Aug 24, 2012, 10:46 AM
Joined Jan 2010
2 Adjust the elevator.
Set of curves, adjusted to plus or minus 36% (operating in different people feel different, you can self-adjustment).
The rudder is adjusted to 50%,
The toggle switch B rocker.
Description:
Old Aug 24, 2012, 10:48 AM
Joined Jan 2010
3 throttle curve adjustment, can be adjusted according to their own feel to -30%.
Description:
Old Aug 24, 2012, 10:50 AM
Joined Jan 2010
4 Adjust the direction.
Description:
Old Aug 24, 2012, 10:53 AM
Joined Jan 2010
The toggle switch A rocker.
When after such adjustment
A
B
D
Rocker switch in the position below, is turned on, is shown above.
If you want to restore the default settings, can only be
A
B
D
Three rocker pushed to the host. As shown below:
Description:
Description:
Description:
Description:
New Product ARF LotusRC T580 quadcopter LotusRC Multirotor Talk 3741 Jan 09, 2012 11:23 AM
Question XAircraft X650 vs. LotusRC T580 ~>Miha<~ Multirotor Talk 8 Sep 08, 2011 02:19 PM
Discussion Our stories-developers and pilots,started with the LotusRC T580 flips yiny0730 Multirotor Talk 3 Jul 02, 2011 06:58 AM
