Old Aug 30, 2011, 09:34 PM
custom t is offline
Find More Posts by custom t
Platinum Ball3r
custom t's Avatar
Canada, BC, North Vancouver
Joined Oct 2009
hepppp! :-) is this a good set up?
Making an easy star into fpv?
Fpv equipment: lawmate 1w tx/rx 1.2ghz
8dbi patch antenna stock whip on tx
Go pro for caera
RC equipment. Easy star rtf
Now this is where I need help..
Motor. Brushed/brush less
Esc?
Tx/rx what could i use for a tx/rx that will give me about 2km?
Lip battery: 3s 1600 and 1700 will run tx and plane off it. I will be flying in a well known area so i don't need gps. Possibly my roof.. will I be able to fly for very long and will I be able to get off the ground?
Thanks recommendations for mtor /esc /tx/rx will be appreciated
custom t is offline Find More Posts by custom t
Old Aug 30, 2011, 10:32 PM
custom t is offline
Platinum Ball3r
custom t's Avatar
Joined Oct 2009
http://www.readymaderc.com/store/ind...roducts_id=508
Would this be a better start?
Old Aug 31, 2011, 01:09 AM
ScooterInVegas is offline
Find More Posts by ScooterInVegas
Village Idiot!
ScooterInVegas's Avatar
United States, NV, Las Vegas
Joined Apr 2011
Originally Posted by custom t View Post
Thats good stuff. Tx will run hot, needs air flow at all times. On a RC car/truck, it will need a fan or bigger heat sink. aka, PC parts.
ScooterInVegas is offline Find More Posts by ScooterInVegas
Old Aug 31, 2011, 03:50 AM
Ugrd is offline
Find More Posts by Ugrd
Ask me about my FPV addiction
Ugrd's Avatar
United States, MN, Wayzata
Joined May 2011
you never need a 1 watt unless your going 40KM+
Ugrd is offline Find More Posts by Ugrd
Old Aug 31, 2011, 10:26 AM
Village Idiot!
Joined Apr 2011
I think there is two tx problems to over come on a rc car. One, range on the ground is shorter than in the air. The other is separation between the Tx and Rx. The more powerfull the Tx, the farther your going to want it from the Rx and servos. Catch 22 we call the here in the States.
There is a few truck based FPV threads here, you should go there and see what they are running. I would guess a 300mw Tx with a clover leaf antenna would work good. But that's a guess on my part. Lower mw to play nice with the other electronics and the CL antenna to help with the multipathing.
Old Aug 31, 2011, 01:47 PM
custom t is offline
Platinum Ball3r
custom t's Avatar
Joined Oct 2009
Ummm I thought an easy star was a plane? :-)
Old Aug 31, 2011, 01:50 PM
rob38 is offline
Find More Posts by rob38
rob38's Avatar
Noord Holland
Joined Oct 2007
+1
rob
rob38 is offline Find More Posts by rob38
Old Aug 31, 2011, 01:54 PM
custom t is offline
Platinum Ball3r
custom t's Avatar
Joined Oct 2009
Oh well I/still need a radio with a good range to control the plane so who knows how far i can go. Would a dx5e be good for long range? Ifci put a long antenna on the rx?
Old Aug 31, 2011, 02:23 PM
Village Idiot!
Joined Apr 2011
Is there an issue with using the lawmate 1.2ghz 1w system with a spektrum dx3.0 2.4ghz radio.?
Ummm... Here is a quote from you yesterday @ 10:30pm.
That is a GROUND based radio. Thought you were doing ground based fpv.
Old Aug 31, 2011, 02:26 PM
Village Idiot!
Joined Apr 2011
Perfect. Just make sure to mount the vTx as close as possible to the Rx. Good Luck.
OK, that's a bad joke. If you searched and read a LOT on RCG, you would know that 2.4 is not the best choice for fpv. FM is a better choice.
Old Aug 31, 2011, 03:24 PM
custom t is offline
Platinum Ball3r
custom t's Avatar
Joined Oct 2009
Yah I was looking at the futaba radios but i can't find a good cheaper one around 200$ I guess the best bet would be to look at the classifieds. Right?
Old Aug 31, 2011, 05:00 PM
Village Idiot!
Joined Apr 2011
I bought a 7 ch Hitec used for $50 with a adj channel fm module. Took the module off and put a dragon link on it. I need more channels, 7 isn't enough. Might put the DL on a JR 9503.
I need more channels for flaps and LED lights.
Old Aug 31, 2011, 06:13 PM
custom t is offline
Platinum Ball3r
custom t's Avatar
Joined Oct 2009
How much is a dragon link? And what does it do? Could I put it on the stock easy star radio?
Old Aug 31, 2011, 08:29 PM
Village Idiot!
Joined Apr 2011
You dont need one of those. You have to open the transmitter and solder wires and add resistors and stuff.
You just need a good FM 72mhz 6 channel radio. That would work best.
Old Sep 01, 2011, 07:59 PM
custom t is offline
Platinum Ball3r
custom t's Avatar
Joined Oct 2009
How far would the range be? I need at least 2-3km
Question Thought's on this plane set up jimmyjam45 Electric Plane Talk 11 Jul 11, 2011 05:21 PM
Question Is this a good MiniMag Set-up? frank3246 Foamies (Kits) 6 Jan 05, 2007 09:24 PM
Discussion Is This A Good Set Up? submarco Glow to Electric Conversions 9 Aug 31, 2006 05:22 AM
Discussion Is this set up good? Blacktop Flying Wings 9 Jul 03, 2006 08:10 PM
Discussion Good Set-up for this plane... rjbrittain11 Electric Plane Talk 1 Mar 16, 2006 06:47 PM
