Old Aug 30, 2011, 05:11 PM
hobbypartz is offline
Find More Posts by hobbypartz
hobbypartz's Avatar
Los Angeles
Joined Mar 2009
New Dynam Super Detail 4 Ch Piper J3 Cub 1245mm RC Airplane
New Dynam Super Detail 4 Ch Piper J3 Cub Review (4 min 45 sec)
Link to buy: http://www.nitroplanes.com/60a-dy894...w-rtf-24g.html
The new Dynam Piper J3 Cub is ready to fly (RTF) with all electronics pre-installed, including the 4CH Transmitter and Receiver, Charger and Batteries. It is made of EPO material so it is highly durable. Everyone can fly this plane, even in windy conditions. Made for 3D aerobatic flight and crash resistance, this plane will impress flyers in all skill levels. Equipped with the tinted clear plastic canopy and landing gear, tail landing gear , and removeable battery cover. It is made for skilled users but also easy to learn for beginners.
Features:
Perfect for all levels: Beginners, Middle-level users, or Experienced Pilots
RTF: Ready to Fly right out of the box (Everything included and 90% assembled)
Easy to construct with pre-installed electronics (motors, servos and speed controllers)
Beautiful design and great details: Resembles a real plane
Factory-finished with stunning appearances
3D Aerobatic Performance
Construction: Lightweight, strong, and crash resistant
Easy take off: effortlessly depart from the ground or your hand
30 amp Brushless Electronic Speed Control
Strong wing designed for smooth airflow providing exceptional stability, and great ease to control and fly even in wind conditions
Full function 4 Channel compatible transmitter with mixing: Aileron control, Elevator control, Rudder, and Throttle.
Durable pre-colored foam fuselage, wings, and tail
Battery: High Quality Rechargeable 11.1V 2200mah Li-Polymer Battery for 20 minutes flight time (Upgradeable optional battery for even longer flight time).
90 Minutes auto peak detection charger
Specifications:
Wing Spawn: 1245mm
Total Length: 850mm
Fly Weight: 1000g
Wing Area: 43.9dm2
Wing Load: 26g/dm2
Motor: Brushless ,kv1100
Battery: 11.1V 2200mAh 25C Li-Poly
Charger: 2~3 Cells Li-Po balance charger
Transmitter: 4 CH 2.4ghz
Servo: 9g high-speed (4 PCS)
ESC: 30A
Package Contents
Dynam piper j3 cub Remote Control Plane Brushless A22 Motor ESC RTF
4CH Transmitter
Receiver, Brushless and ESC
Power Adapter
LiPo Battery Balance Charger
11.1V 2200mAh Li-Po Rechargeable Battery
Brushless Motor Propellers and Landing Gear
English User Manual
hobbypartz is offline Find More Posts by hobbypartz
Old Sep 02, 2011, 07:46 PM
Bedhead7 is offline
Find More Posts by Bedhead7
Joined Aug 2011
build review
I purchased this New Dynam Super Detail 4 Ch Piper J3 Cub 1245mm from nitroplanes.com a few days ago. Built the kit last night. Have not flown it yet.
I don't have many good things to say about the kit, but I will say that nitroplanes shipped the kit fast. The kit and box did not have any major visible damage on arrival.
This was my first RC plane build. I've been building plastic models and RC cars for awhile so I know my way around complex instructions, small parts and modeling tools. I purchased the Piper because I've read it's a good starter plane. I also wanted something I could build quickly and get in the air fast. The Dynam piper video preview http://www.nitroplanes.com/60a-dy894...w-rtf-24g.html on nitroplanes made it look promising. It flew well and I liked the scale so I said what the hell. I pulled the trigger on this kit before a more formal review of a production kit had been posted. As I have yet to find a review of this kit, here is my own.
Opening the box, the fuselage and a few loose parts were wrapped in bubble wrap with a few pieces of tape. The bright orange/yellow wings, tail and landing gear were sitting unprotected between thin pieces of cardboard. The transmitter and battery/charger were separately boxed inside the main box. There were also a few plastic bags full of random screws, springs and the cheap epoxy I've heard bad things about. The packaging was just barely passable, nothing above and beyond.
I flipped through the directions and things started to go down hill. Small photos and laughably vague instructions in Engrish lowered my excitement level. I'm not sure how much Chinese to English translators are going for these days but they must be too expensive for Dynam to afford.
Next I pulled out the pre-assembled landing gear and spun one of the wheels. The wheel fell off and rolled on the ground. I picked up the wheel and studied the wheel and the hub that holds it onto the axle. The industrial design quality was very poor for such a fundamental part of the plane. Part of the wheel hub had broken off and was stuck inside the wheel itself. I don't believe even a mint condition set of wheels and hubs for this kit would function properly. I tried to press the wheel back on the axle and one of the landing gear cross beams cracked and broke away from the axle. Cracked is the wrong word, crumbled is more accurate. All the yellow plastic in this kit is extremely brittle and "chalky". This did not matter much though because all the piper cross beam suspension on this kit is just for show. Non functional static and brittle cheap plastic. If you watch the end of the nitroplanes video closely, you can see they had exact same broken landing gear crossbeam problem described above. Just to keep things symmetrical, I broke the other crossbeam on purpose then used tie down straps to permanently keep them both in place.
The box had been open for about 5 minutes and I was fairly sure I would not be able to complete the kit. Without functioning wheels, how do I take off and land the plane? With my excitement level turning to anger, I focused on fixing the wheels to get them set and spinning. I debated just returning the kit but decided to find a way to scratch build a fix.
The wheel hub is basically a short tube that caps the wheel onto the axle. I opened a few ballpoint pens laying around and luckily found a plastic ink tube with the exact same dimensions and thickness to the wheel hub. The plastic used in the ballpoint pen was of higher quality than the plastic used in the Dynam kit. I put the wheel back on the axle and glued the ballpoint pen replacement onto the axle. With some trimmer lube the wheel spun perfectly and attached securely. I then did the same thing to the non broken wheel. It took about two hours to finally get the landing gear wheels properly working.
Next I glued the two foam wings together per the instructions and hooked up the aileron servos to the control board. I will say the servo and wiring quality seemed pretty good. The transmitter is also not bad for the price. I plugged in the lipo battery to get some juice going for later servo trimming. The battery and charger also seemed ok for the price.
Next I had to attach the wings to the fuselage. The wings attach with two very small screws for the size of the plane. It was quite hard to line up the screws through the wings and into the screw housings in the fuselage. This took 10 - 15 tries before I got both screws to properly line up and screw in. I also feel the fit and tightness of the screws was poor as this was probably the most important joint on the aircraft and also, the only joint holding the wings on. Because of this, I used two part epoxy to glue the wings onto the fuselage, removing any chance of ever taking the wings off again. If the screws had been a higher gauge and gripped the fuselage better, I would not have glued the wings down. Frustrating. My apartment is small and I really can't afford to have the fully assembled plane laying around.
At this point I considered the Dynam kit a $150.00 throwaway lesson and crash course into rc planes. With my expectations adjusted to zero, I continued on with the build.
Next I combined the foam rudder and stabilizer. A fairly good fit. The foam parts of this kit are molded well but the paint chips off very easily. I seated the tail into the fuselage with more two part epoxy, again, a nice fit.
I moved onto installing the landing gear to the fuselage. I got the landing gear screwed into the fuselage when I realized I had to screw the wing braces into the same holes as the landing gear. Thanks vague Engrish instructions. While removing one of the screws, the screw head broke off with very minimal torque. The screw was now stuck deep in the cheap yellow fuselage plastic with no conceivable way of removing it. Again, I thought this was probably it and the plane would never fly. I found a way to gouge through the plastic enough to get a grip on the screw with my Leatherman pliers. This was the only time I was happy the plastic was so brittle. I replaced the "weakest screw in history" with a bigger than provided screw and felt good about it.
At this point I was getting tired. This ready to fly plane build was going into it's 4th hour. I moved onto the rear landing gear. Very small cheap spongy wheel that hooks into the foam rudder with springs and is supposed to be steerable with the rudder control. I plugged in the lipo and turned the transmitter on. I found that the rear weight of the plane was being transferred into the foam rudder through the rear landing gear movement. This almost caused the rudder to rip off. I will not be flying this plane with the rear wheel connected to the rudder.
The plane does look decent from a distance and I can't complain about the engine, propeller, servos, transmitter or foam pieces. The main problems with this kit are the horrible yellow plastics used on critical parts, cheap undersized screws with less then favorable install points and vague instructions. If you want a $150.00 frustrating and throwaway crash course into RC planes, I guess this is the kit for you. If you want something fun to build, and want to own and fly a quality product, STAY AWAY! Pay the few extra bucks for something better.
Bedhead7 is offline Find More Posts by Bedhead7
Old Nov 29, 2011, 03:58 PM
capnchaos is offline
Find More Posts by capnchaos
Cap'n Chaos
Joined Dec 2009
I was thinking about this as my first plane (have some heli experience).
After having it a few months would you still recommend something else?
capnchaos is offline Find More Posts by capnchaos
Old Jan 26, 2012, 02:28 PM
Philscho is offline
Find More Posts by Philscho
Joined Jan 2012
Dynam Piper J3 Cub 1245mm Instruction manual????
Boy! Amen on the comment about the Chinglish language instruction manual. It is hard enough to figure out what the instructions are actually trying to say, but on top of that they sent the Instruction manual for the RTF version of the plane and I have the ARF kit which requires much more assembly. Has anyone seen a version of the ARF manual for this kit online anywhere as a PDF or instructional video??? There is nothing in the RTF manual about where to mount the RX or wiring the RX to the servos??? This type of sketchy language use would make it difficult for a newcomer to figure out how to use a pair of Chopsticks??
Phil
Philscho is offline Find More Posts by Philscho
Old Jan 31, 2012, 09:39 PM
devgrp is offline
Find More Posts by devgrp
United States, NC, Charlotte
Joined Oct 2011
Phil
The ARF and the RTF are the same except one comes with a TX and Rx and one without, so both uses the same manual. The first plane I bought from NP was a RTF. I replaced the rx and tx with my own and built the plane. The next plane I bought was a ARF which came just like my ARF except no tx and rx.
You can mount the rx anywhere you like. There are no designated area to mount it. Once you build your first plane, you will become more familiar with process. My first plane build took about 4 hrs and that was RTF Cessna.
Wiring he Rx is dependent on the rx and tx. Rudder goes into the rud ch, ele into ele ch and so forth
devgrp is offline Find More Posts by devgrp
Old Feb 01, 2012, 01:21 PM
Philscho is offline
Joined Jan 2012
Hey thanks for the info. I cobbled together info from the internet and multiple readings of the manual. Through trial and error I got it put together and functioning correctly. All in all it is a very cool looking scale J3. I can keep it looking that way until I actually try to fly it. Again thanks for the info.
Felipe
Old Feb 01, 2012, 03:53 PM
devgrp is offline
Joined Oct 2011
Ok man. Glad to know you got everything working
Old Feb 04, 2012, 09:38 PM
c91x is offline
Find More Posts by c91x
Joined Jul 2010
not trying to belittle you but this was the easiest plane i've ever put together but i've put together quite a few. Still haven't flown it but it took about 20 mintues put together. Agree the landing gear is horrible but i did change out the stock wheel for some 2 3/4" du bro wheels to simulate tundra tires.
c91x is offline Find More Posts by c91x
Old Feb 07, 2012, 06:55 PM
c91x is offline
Joined Jul 2010
mine died today....... i'm a cheap ass and was using a hobby king orange rx and it browned out and did a nose dive. It was really a fun plane in wind, you could make it pretty much hover in front of you and with the tundra tires i put on touch in goes were really fun
Old Aug 10, 2012, 10:21 PM
bicyclemonkey is offline
Find More Posts by bicyclemonkey
bicyclemonkey's Avatar
Fayetteville, AR
Joined Jan 2010
How did you attach your dubro wheels? I have some dubros but they're too wide for the bent wire axles. They'd look great on there plus the small factory wheels don't spin hardly at all.
bicyclemonkey is offline Find More Posts by bicyclemonkey
Old Mar 20, 2013, 06:53 AM
Dalrock69 is offline
Find More Posts by Dalrock69
Dalrock69's Avatar
United States, AR, Jonesboro
Joined Oct 2012
I want to change out the cheap foam wheels with DuBro Rubber Wheels too. I have not tried to replace them yet. I wanted to find out if you just pop off the Cub Hubs or is there more to it than that. Please let me know.
Thanx
~D~
Dalrock69 is offline Find More Posts by Dalrock69
Old May 13, 2013, 11:04 PM
wattman is offline
Find More Posts by wattman
wattman's Avatar
Evansville Dress Reg., Indiana, United States
Joined Jun 2004
I am so sad that I took a chance on a non HH / Parkzone aircraft .
I had never before purchased a yellow piper cub that is three different shades of yellow .
I can live with somewhat close enough between the cowel and the fuselage , but the horrible plastic non-yellow cockpit / windows casting extending so much into the fuselage area , that contrast so badly with the fuselage is beyond belief .
Nitroplanes photos and flying video sure are not what you receive when you order this Dynam Piper J3 Cub 1245mm wingspan .
Its so dishearting to receive a product like this is .
There were a couple more Dynam aircraft that I was thinking about ordering , but not now , no way , fool me once this much , and thats it for me .
Back to trying with this plane , and after years of flying and about 34 planes experience, this was the first one that the ESC would not work , I tried many times reading the manual and what not but no go , so after a couple of hours , removed the ESC and put in a EFlite ESC , you know , the ones you install , power up and it works . And getting the two small screws that hold the wing on installed , OMG what a headache that is . Oh yes broke the landing gear plastic wrestling with the wheels and wheel retainers , of course I expect the wheels to actually roll .
Why I have not taken this major problem outside and stomped it , ok , I am to old to do that , I will try to fly it , who knows maybe it will be a good flyer ?
I can not belive that I bought this ,but the price baited me in .
wattman is offline Find More Posts by wattman
Old Jul 17, 2013, 10:45 PM
Dalrock69's Avatar
Joined Oct 2012
Dynam Super Detail Piper J3 Cub 1245mm RC ARF
If you are thinking about buying this plane, my advise is to buy something else...
What a POS. Worst Dynam Plane I have ever owned. Three different shades of yellow ... Plastic Wheel Struts were broken straight out of the box (just like they are on NitroPlanes video and pictures) ... Plastic Left Main Wing Strut broke on the Maiden Flight (glad they are just for looks) ... I think I got the only one of these planes with wheels that actually roll, but they are way too small for a Cub and made of foam ... Tail Wheel Assembly broke off on my first Grass Landing ... The pilot figure is an effing joke (way too big) ... I see very few things about this plane that are pros (bunch of cons) ... It is not scale much less "Super Scale". I could go on and on, but I think I have made my point.
Old Jul 18, 2013, 04:36 PM
WVrailfan is offline
Find More Posts by WVrailfan
WVrailfan's Avatar
United States, WV, St Albans
Joined Jun 2011
I purchased this plane before I read all the negative comments. And, to be honest, it is not the best thought out model Dynam has. I have both the Dynam C-47 and Catalina and both of those planes look and fly great. I would recommend both of them to anyone with some 4 channel experience.
The comments about the appearance of this plane out of the box are dead on. The paint work is awful, with at least three shades of yellow, because there was no effort to apply extra coats to the tinted plastic windscreen surround and yellow doesn't cover dark plastic well. The plastic should have been primed first or had multiple coats of yellow to get it closer to the yellow on the foam parts of the plane. The cowl, which is cast in yellow plastic is likely close enough for most folks, but a coat of the same yellow they painted the fuselage with would have helped.
All that said, the plane only cost $99.00, so for that amount, I'm okay with having to do a little touch up painting.
To be honest, a little masking tape and some yellow spray paint and the included decals, or in my case some from Callie Graphics, and you can have a decent looking little Cub.
I flew mine today for the first time and it flies like a Cub should, slow and easy. No damage on landing, but since I did nose over on my second flight, I will likely add some larger tires for flying from grass.
So, if you want a plane that doesn't need any tweaking, look elsewhere for a Cub. Good luck finding one this size for $100. If you like to paint or tinker, this plane isn't that bad.
Jim
WVrailfan is offline Find More Posts by WVrailfan
Old Jul 21, 2013, 08:46 PM
WVrailfan's Avatar
Joined Jun 2011
I flew this plane a few more times this evening. It was late and the light wasn't idea for photos, but I did manage to get a couple.
I've conceded the issue with appearance regarding the thin paint on the windshield surround.
However, after flying the plane a half dozen times now, I don't see the problems with the struts and landing gear others have posted about. I am landing on grass, and I did nose it over twice, but, I have that problem with most of my tail draggers at one time or another. The gear and wing struts are still intact.
I think under "normal" conditions this plane holds up as well as most. If you land hard, yup, you might break something. That is pretty much true of any plane.
So far, I am enjoying my little Cub. If flies like a Cub, slow, gentle in the turns and pretty easy to land. It's not a race horse, but I was expecting a Cub not a Mustang. I flew 10 minutes using a 2200 battery and only used half of the battery, floating around at half throttle. I think this will be one of my "go to" planes for calm lazy evening flying.
Jim
Discussion $129.95 Dynam 4-Ch 64mm EDF Brushless-Powered RC Remote Control Jet RTF wnppmy Electric Ducted Fan Jet Talk 5 Jul 07, 2013 07:35 PM
Build Log Dynam 4Ch Super J3 Cub PA-18 build and maintenance log DragonDemiGod Beginner Training Area (Aircraft-Electric) 3 Apr 23, 2012 10:45 PM
For Sale 4 CH Piper J3 CUB RTF marluzkat Aircraft - Electric - Airplanes (FS/W) 8 Apr 05, 2011 08:49 PM
Discussion 4-CH J3 Super Cub Dtrimas Banana Hobby 19 Oct 06, 2008 08:14 PM
Article The Herr Piper J3 Cub and the Hobby Hangar 1/2A Super Cub Robert Buonfiglio Electric Plane Talk 0 Mar 09, 2000 12:00 AM
