Old Oct 25, 2012, 11:11 PM
hookpilot is offline
Find More Posts by hookpilot
hookpilot's Avatar
Originally Posted by john hand View Post
MY father passed away fifteen years ago. From agent orange i would estimate he built at least forty differant model of paddlewheelers. I have a photo album filled with them.I never started building them on my own until he was gone , i helped him growing up .The first one i built about six mos. after his passing and realized i paid really good attention.And my first one looked pretty good.
Where did he serve in Vietnam? I was a helicopter pilot there for a year flying UH-1H Hueys and AH-1G Cobras in an Air Cav unit at Lai Khe and around Pleiku, 1968-1969. I'd like to see pictures of his collection.
Mike in Edmonds
hookpilot is offline Find More Posts by hookpilot
Old Oct 26, 2012, 01:14 AM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Hey Mike,
Do you know Paul Fleming?
He has some stories to tell, one flight involving the evacuation(twice) of a family and their cow.
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Oct 26, 2012, 08:59 AM
john hand is offline
Find More Posts by john hand
Joined Oct 2012
i know he served 68/69 not sure where he was stationed he was a truck driver over there delievering surplies
john hand is offline Find More Posts by john hand
Old Oct 26, 2012, 08:20 PM
hookpilot's Avatar
Originally Posted by Umi_Ryuzuki View Post
Hey Mike,
I know a Jim Fleming. He was a flight engineer with the Chinook helicopter unit at Paine Field where I flew for 24 years. It's amazing how Vietnam era guys pop up out of the backroads in the Pacific Northwest. I have a large flying segment of my website at: mjonesfamily.com. Lots of photos of the guys I flew with. There is a link to the Air Cav Squadron I flew with in Vietnam, B Troop, 7/17th Air Cav, The Ruthless Riders!
Old Oct 27, 2012, 12:28 AM
hookpilot's Avatar
Adding a Few More Bits and Pieces to Preston
After trying to make a small railing at the top of the A-frame out of brass, I gave up and rebuilt it using .035" Plastruct styrene rod. Success! It will be delicate and in a vulnerable place on the model, but it will do for now. I'm picking up a Triton resistance soldering system in a few days if the price is right. Anyone out there have one of these for sale??? I've got almost 15 feet of railing to build on Preston, oh Joy! The electric drive system is undergoing a rebuild. More on this later.
I just dug out an old pen-in-ink drawing I did 34 years ago. At the time I was building a Vosper Motor Torpedo Boat.
Mike in Edmonds
Old Oct 28, 2012, 02:53 AM
Joined Oct 2012
never had much luck with styrene myself think its very hard to work with
Old Oct 30, 2012, 07:46 PM
hookpilot's Avatar
Working with Styrene
It's interesting how many different building materials people use. for me, styrene sheet worked out best for the superstructure on the Preston. On a previous steamboat model I planked the entire boat in Alaska cedar. That was a lot of work, but it looked great. I probably would have used brass on the A frame work platform if I had a resistance soldering system. Styrene railing goes together fast, so prep and setup are critical to getting a good result.
Mike in Edmonds
Old Oct 31, 2012, 01:08 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
I have made a lot of railings, but never used a resistance soldering system.
I found a good flux and a 30 watt iron worked well to build up railings in place.
Old Nov 01, 2012, 10:39 PM
hookpilot's Avatar
What 10 channel Radio to choose
I've been looking at the Spektrum DX 10t and DX18 radios for the Preston. Any other radios out there to consider. I need 6 proportional channels and 4 non-proportional channels. By non proportional I mean 3 position switches.
Old Nov 09, 2012, 12:06 AM
hookpilot's Avatar
Progress on the Preston Steam Engine
My friend Dave is moving along with the building of W.T. Preston's steam engine. I can now begin buying all the piping, fittings, valves, water level control system and feedwater pump for the steam plant. When Mike from Macssteam returns from holiday, I'll have the information I need to order his beautiful 3.5" dia. horizontal marine boiler with all the fittings, plus a few extra and 2.5" gas tank. I first need to find out the thread type on the WLDS system's water level probe. Then Mike can silver-solder in the proper bush to accept the probe. Along with the WLDS, I'll be picking up their electric feedwater pump and solenoid valve. While all this is going on, I need to get inspired to finish the detail work on railing and hog rods. Gotta fire up that video of the Lone Star sternwheeler chugging across that beautiful Colorado foggy morning lake. As all this comes together, the weight of my model grows. 18 pounds minus steam plant with target weight of 37 pounds. By the time I add the steam plant I'll be getting closer to the correct displacement. It's critical on a stern wheeler to submerge the paddle wheel blades at the optimum depth, no more than one blade width. The attached picture (courtesy of Dave who is building the engine) shows the main cylinder with piston valve assembly sitting on top. 1/4" steam lines will feed each cylinder and exhaust through 5/16" exhaust pipes. There will be 4 servo actuated cylinder drain valves to prevent hydraulic lock up on start. These may have to be machined since there is very little clearance under the cylinders. Commercially available drain valves may be too big. Lots of subsystems to think about...
Mike in Edmonds
Old Nov 15, 2012, 07:31 PM
hookpilot's Avatar
DX10t On the Way!!
After much research and thinking about the future of my interests in both model ships and airplanes, I ordered the Spektrum DX10t and case. This will take care of my RC needs for a long time. I still have a cabinet full of radios that will probably get auctioned off at the next club silent auction. Using a tray radio will allow operation of the steam donkey/crane in a more intuitive way. The DX18 puts a lot of the controls I would be using to operate the donkey and crane in odd positions. I also like the special harness that keeps the transmitter from swinging and banging around when you bend over. I also like the idea of being able to swap out modules on the tray. I'll be doing a complete review once it's installed in the Preston.
Dave is making excellent progress on the steam engine. I'm ordering the Macssteam 3.5" marine boiler and the WLDS (water level detection system) with boiler feedwater pump. Work began today on soldering up the 15 feet of railing on the model.
Mike in Edmonds
Old Nov 21, 2012, 08:14 PM
hookpilot's Avatar
Picked up My DX10t this Afternoon!
What a beautiful radio. I also picked up the carrying case and neck strap for the radio. I started installing the Spektrum servos last night. And the big surprise of the day--- After getting an email from Spektrum that the custom Spektrum jacket is discontinued, the hobby shop I deal with mysteriously found a jacket, in my size, so it is now at an embroidery shop to have my name and DX10t stitched into the coat. I'm set now...
Mike in Edmonds
Old Nov 25, 2012, 02:57 PM
hookpilot's Avatar
Macssteam Ltd. Boiler
I'm ready to take the plunge and order the boiler for the Preston. It will be their
3 1/2" horizontal marine boiler and will include all fittings (safety valve, water level gauge, 2 steam valves, one for main steam line to engine, second to an attenuator to regulate boiler pressure, boiler pressure gauge and siphon, one-way valve to add water to boiler while in steam, burner, and WLDS sensor + electric feedwater pump to maintain boiler water level.) Delivery should be in 3 weeks.
Work continues on getting the temporary electric drive working right. Much head scratching, and I can't afford to loose more hair. At this rate, I'll have the steam plant done before the electric drive is made to work.
The DX10t is amazing! The more I learn about this transmitter, the better the overall control of the model will be. Mrs. Santa is probably getting me the Spektrum telemetry module, and iPhone adaptor, plus the Spektrum jacket with custom embroidery.
Mike in Edmonds
Old Nov 25, 2012, 04:21 PM
Robert R is offline
Find More Posts by Robert R
It's a fine fiddly business.
Robert R's Avatar
United States, WA, Marysville
Joined May 2009
I am not much of a boater, but I read every post on this thread. Cool.
Robert
Robert R is offline Find More Posts by Robert R
Latest blog entry: Mustang Sally Sea Trials
Old Nov 26, 2012, 12:09 AM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Very cool.
MILLERTIME is offline Find More Posts by MILLERTIME
Build Log Sternwheeler Towboat Scratch Build tugboatjack Scale Boats 79 Jan 09, 2012 04:04 PM
For Sale **Video now up** Vintage TopFlight 1" scale Mustang plans w/ box w/B&M 35 engine bluemeane Aircraft - Fuel - Engines and Accessories (FS/W) 4 Aug 23, 2011 08:31 AM
Discussion miami class a s r l w w 2 1/32 scale mickthefish Dock Talk 2 Jan 14, 2011 06:35 PM
Discussion 1/32 simi scale depron 737 design/build adbradley Scale Kit/Scratch Built 0 Dec 14, 2008 12:27 PM
Discussion W. T. Preston in Anacortes Washington State Can Fly Land?? Aerial Photography 0 Feb 25, 2008 12:00 AM
