Old Oct 04, 2003, 10:05 PM
larsy87 is offline
Find More Posts by larsy87
Lookin' Good. Real Good.
larsy87's Avatar
London, Canada
Joined Aug 2002
Epoxy is good, just heavier.
Some nice lookngi E-starters there!
larsy87 is offline Find More Posts by larsy87
Old Oct 04, 2003, 10:44 PM
spithungry is offline
Find More Posts by spithungry
no strings attached
spithungry's Avatar
the great white north
Joined Jul 2003
what're you guyz using to paint the cowls ?
i'de like to panit mine with checkers, but i have no idea of what to use.
thanks !
spithungry is offline Find More Posts by spithungry
Old Oct 04, 2003, 11:22 PM
Azygos is offline
Find More Posts by Azygos
United States, UT, Payson
Joined Mar 2003
E-Starter
Well, mine was mostly stock when I got it. (See picture)
Then after a while the white became grey, and fingerprinted because of handling the plane, so I painted the entire thing dark green, and removed the decals as well. Then eventually it became dented and such, and white started showing through the paint on the fuselage, so I painted the fuse Solder Blue (like a greyish blue).
In the mean time of all of the painting I was using bad JST connectors, and the result was the fuse breaking in five places, four of those in the tail, and the cowl cracked in two places and dented in all the places that weren't cracked (after I lost all power).
Now the thing is so heavy that the only batteries that will work are the full AA's from Wal-Mart (1850 MAH). These batteries make the plane FAST. The 720 MAH AAA's that I used to have don't have enough umph.
Just my long and boring story. I may have to get some pictures of the current paint job.
Oh, and after a while my tailwheel got weak, so I took it off. I re-enforced the bottom of the rudder with a peice of balsa, filled in the gap with spackle, and just land on that. It seems strong enough. It is plenty strong to land on grass, but when I land on asphalt, sometimes the bottom two hinges on the rudder try to pull out. Elmer's glue anyone!?
My E-Starter now has well over 75 flights (guesstimation).
B.T.W. I just weighed it and the AUW is 20 and 1/2 oz. 7 oz. of that are batteries. Hm, I may have to make that a 10 Cell AA pack and slap a GWS EPS 400 to the nose! That would make it about 4 oz. heavier!
Chris
The picture is from back in the day. When my plane was beautiful. For a foamie, that is!
Azygos is offline Find More Posts by Azygos
Old Oct 04, 2003, 11:26 PM
Azygos is offline
Joined Mar 2003
One more thing.
The plane (when I first got it) didn't have ailerons. Back then with the 7 cell 720's it weighed a mere 13 oz.!
Now with a 7 cell 1850 pack, as I mentioned, it weighs 7 1/2 oz. more.
Chris
Old Oct 05, 2003, 03:09 AM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
You will need CA for some of the parts, another tip is to rough up any smooth surface that you have use with epoxy. my tip is anything that is plastic needs to be scratched up a little with the blade on my Xacto knife.. epoxy is good but also adds weight..
If you have any questions email me...
tallflyer is offline Find More Posts by tallflyer
Latest blog entry: My Official 3DR Solo Blog
Old Oct 05, 2003, 03:19 AM
tallflyer's Avatar
Joined Jul 2002
Ezconectors
Here is my Aileron setup for The E-Starter using Ezconectors makes this job fast and adjusting your Ailerons that much faster.
Old Oct 05, 2003, 08:42 AM
tallflyer's Avatar
Joined Jul 2002
servo and rec install
The E Starter has a large and easy to access body mounting gear is easy
Old Oct 05, 2003, 09:06 AM
tallflyer's Avatar
Joined Jul 2002
stab modifacation
Here is a little tip that I did that will add a little more strength to the stabalizer follow the direction per the manual then add a peace of packing tape over the front edge that is a little wider then the medal brace, the tape should cover the top and the bottom of the stab about 3/4 of the way back from the leading edge..
look at the picture to get an idea of the setup!
Old Oct 05, 2003, 11:58 AM
busybee is offline
Find More Posts by busybee
two left feet
Austin, TX
Joined Aug 2003
I used the same testors model master paint for the foam & cowl. I just temporarily attached the cowl to the fuse while painting.
Also, I did not use any CA (except for that nut for the wing screw). Strictly GWS glue for all foam-to-foam connections (overnight to dry), and epoxy for all other connections.. you could use epoxy for everything if you want to build it quickly.
busybee is offline Find More Posts by busybee
Old Oct 05, 2003, 10:29 PM
azjerry is offline
Find More Posts by azjerry
Phoenix Deer Vally, Arizona, United States
Joined Sep 2003
Chris,
I'm assuming (dangerous I know :^) ) that you're talking about standard AA cells, How are you wiring them together?
azjerry is offline Find More Posts by azjerry
Old Oct 06, 2003, 02:36 AM
tallflyer's Avatar
Joined Jul 2002
Here is the battery Im Using
THis is The GWS Battery That I use in My E Starter gives me about 8-10 minute flights Im going to try my lipo pack on tuesday just going to have to figer out how to add weight to the plane to make up for the difference of the much lighter pack!
Old Oct 08, 2003, 07:53 PM
crashworthy is offline
Find More Posts by crashworthy
Tularosa, NM
Joined Sep 2003
Another E-Starter ready to maiden
Hope the rain quits so I can maiden her tomorrow.
crashworthy is offline Find More Posts by crashworthy
Old Oct 08, 2003, 07:55 PM
Tularosa, NM
Joined Sep 2003
Another view
Old Oct 28, 2003, 07:25 PM
cease2001 is offline
Find More Posts by cease2001
electricflyer
Nampa, ID
Joined Feb 2003
e-starter servos
I aloso strengthend the tail. I also added a brass reinforcement to the tail wheel pivot. I'm using 2 servos for the ailerons. I mounted an astroflight 010 brushless and am running thunder power 3s 2100 Lipo. I bulid a new battery compartment door.
cease2001 is offline Find More Posts by cease2001
Old Oct 29, 2003, 11:06 AM
ecclam is offline
Find More Posts by ecclam
ecclam's Avatar
London
Joined Jul 2003
Yet another one ready to fly
Hi every one thanks for all the hints, finally fnished mine
just wating for some nice weather.....
Eric
ecclam is offline Find More Posts by ecclam
Post your e-starter pics to show our members. Death Devil Parkflyers 5 Mar 18, 2004 08:29 AM
Post your Viper Twin Pics Here! Zagi-Extreme Foamies (Kits) 3 Mar 30, 2003 09:04 PM
Post Your Zagi 400X Pics Here HavingFun2002 Foamies (Kits) 63 Feb 02, 2003 01:21 AM
Post your Aeroflakes meet pics here Jgardner Scratchbuilt Indoor and Micro Models 38 Jan 24, 2003 03:44 PM
Post your fun fly pics here. Paul Susbauer 3D / Fun Fly Fuel Planes 8 Jan 23, 2003 03:11 AM
