Old Jul 28, 2012, 04:03 PM
Rifraf is offline
Find More Posts by Rifraf
United States, CO, Golden
Joined Aug 2011
Originally Posted by Ohio AV8TOR View Post
There is one thing that is going to get used to which I am adjusting to is in slow flight like landing it quits flying. My 87" SHP does no do this and will glide a lot more than this. I am not talking about harrier flight which I like with this plane very little wing rock. Unless I am carrying some power when I flair there is no balloon up it just sinks. Nice landings carrying some power though.
I've noticed the same thing with mine. Totally normal until a couple feet off the ground, then it just sinks. It's definitely better with a touch of throttle right as I get a about 10' off the runway, but it's not intuitive for me, as my other planes, like you say, are usually floaty. Lightening up my weight helped a little, but not a lot. Because of this, I have beefed up the stock landing gear with some carbon fiber tape CA'ed along the whole inside of the LG and around the bottom, so the axle area is reinforced on both sides.
Rifraf is offline Find More Posts by Rifraf
Old Jul 28, 2012, 04:10 PM
GPT is offline
GPT
Find More Posts by GPT
GPT
GPT's Avatar
Sydney,Australia
Joined Dec 2004
I notice the same habit. If like me you've been used to flying Edges it is something you need to adapt to, otherwise ugly landings result.
GPT is offline Find More Posts by GPT
Old Jul 28, 2012, 04:14 PM
Ohio AV8TOR is online now
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Well thanks guys as I was wondering if I had something set up wrong. It is something I started adjusting to but have to think about it.
Ohio AV8TOR is online now Find More Posts by Ohio AV8TOR
Old Jul 28, 2012, 05:10 PM
On loan to Texas
Joined Oct 2005
I was sharing some PM's with Doc Austion and he had something interesting to share on the landings and that is to add a throttle to elevator mix on low throttle putting in some down elevator. Here is his blog on it
Old Jul 28, 2012, 05:18 PM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
That is a good mix to use. Especially since a properly setup plane will pull slightly to the canopy on a no power down line. The down elevator mixed in with the low throttle can also straighten out the down lines as well as helping out with landing.
hone1er is offline Find More Posts by hone1er
Old Jul 28, 2012, 05:59 PM
On loan to Texas
Joined Oct 2005
During our conversation Doc also mentioned the straightening out the down lines a win win. I just programmed it in for 1 trim unit and I have it on a switch so I will try it on some high glide to see. If all goes well it should having you use stick pressures on landing more like a sport plane.
Old Jul 28, 2012, 06:47 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
I'm going to program this in just for low rates to see how it works. Is there any sense in having this on high rates too?
going4speed is offline Find More Posts by going4speed
Old Jul 28, 2012, 07:07 PM
On loan to Texas
Joined Oct 2005
I assigned mine to another switch so it works both low and high
Old Jul 29, 2012, 12:02 AM
Rifraf is offline
Joined Aug 2011
That tip sounds good. I'll give it a shot. The video on that blog is another thing all together, makes it clear I have a long way to go....
Old Jul 29, 2012, 12:34 AM
jcfab is offline
Find More Posts by jcfab
Landing, HEY, I got it!!!!!
jcfab's Avatar
U.S.A. Celina, TX
Joined Oct 2010
+1 Doc can push a plane pretty hard sometimes. He has also been flying for quite some time. That mix sounds practical and may help some. I've been working on Ben's method a little and it seems to work well for me.
I turn final about 100 to 150 yards out, about 1/8 to 1/4 throttle and give the elevator a slight push to get down about fence level.(I'm landing over a barbed wire fence at the property line) Back the throttle off to 1/8 and let the plane descend for about 50 yards. When it is less than a foot off the ground I chop power and it settles right in. Roll out is about 10 feet. Like Ben said, "a stable approach". At 1/8 throttle, the plane is losing altitude but at a rate that puts me on the runway where I want to be. I fly off of Blackland that cracks and dips very bad. Even a slightly "rough" landing tears planes up. I've just learned how to smooth things out in the past week so I'm no expert but getting a little better each time.
Jeff
jcfab is offline Find More Posts by jcfab
Old Jul 29, 2012, 06:04 AM
On loan to Texas
Joined Oct 2005
Yea Docs videos are fun to watch for sure, he is out there.
Old Jul 29, 2012, 09:14 AM
On loan to Texas
Joined Oct 2005
Got in 4 flights this morning at the crack of dawn to beat the heat right now and I tried the throttle to elevator mix and it worked fantastic. You hardly notice the pitch down and to be honest it just simply looks like and behaves like a sport plane on landing. First custom pmix I did on my new 8FG and it was pretty easy and nice to have the servo viewing window because you don't have to power up the plane even. I just verified what direction (number value) one click of down trim did and made the mix match that.
Old Jul 29, 2012, 01:54 PM
jcfab is offline
jcfab's Avatar
U.S.A. Celina, TX
Joined Oct 2010
Ohio,
Glad that mix worked out for you. Finicky landings can really mess your head up. Not a whole lot of time to respond and if you don't it's kinda rough on airframes. Ask me how I know.
Jeff
Old Jul 29, 2012, 05:19 PM
Brownie433 is offline
Find More Posts by Brownie433
United States, WI, Milwaukee
Joined Sep 2008
Just got passed 250 flights on my V2 SHP this weekend Never thought a plane of mine would last that long.
Side note: For landings I have been using Doc's landing mix. This weekend I used the Airbrake Mix in my Futaba to raise the ailerons slightly on a switch (my landing mix) and I took some down elevator out of the mix. Works great for landing my tail heavy SHP. I am using -5 (I started at -2). The nose doesn't ballon up very much and it's easier to stop the stall and plunk landing. I still have just a hair of down elevator.
Brownie433 is offline Find More Posts by Brownie433
Old Jul 29, 2012, 05:45 PM
On loan to Texas
Joined Oct 2005
Congrats on the milestone, I hope I can say the same someday. Is there anything written up on the airbrake mix?
For Sale 3DHS 47" Extra 300 SHP rdbell Aircraft - Electric - Airplanes (FS/W) 10 Jul 29, 2013 11:39 PM
Sold 3DHS 47" Extra 300 SHP Red Brand New jdrennen03 Aircraft - Electric - Airplanes (FS/W) 2 Aug 03, 2011 01:11 PM
Wanted Looking for the 3DHS 47" Extra 300 SHP - Red GlockDoc Aircraft - Electric - Airplanes (FS/W) 1 Jul 16, 2011 02:14 PM
Wanted 3DHS Red Extra SHP v3 47" Cowl gms Aircraft - General - Miscellaneous (FS/W) 0 Apr 19, 2011 10:59 PM
