Old Sep 20, 2011, 01:40 PM
94'325is is offline
Find More Posts by 94'325is
94'325is's Avatar
Florida
Joined Jan 2010
I'm basically planning on running it until the noise either gets worse or I notice it getting hotter after flights. I said that roughly 100 flights ago and it's still doing great and hauling the SHP around nicely. My 72g on the other hand has some weird issues but it also has 300+ flights on it. They're cheap enough motors that I'm worried about buying a new one eventually.
94'325is is offline Find More Posts by 94'325is
Old Sep 20, 2011, 01:55 PM
ricoalonso is offline
Find More Posts by ricoalonso
ricoalonso's Avatar
USA, KS, Derby
Joined Mar 2003
Yeah I think I'll do the same. I'll start bringing my IR gun next time to regularly measure the motor temp.
ricoalonso is offline Find More Posts by ricoalonso
Old Sep 20, 2011, 03:06 PM
Aeroplayin is online now
Find More Posts by Aeroplayin
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
No problem, glad I could help. I got nine guys at my field together to buy SHP's back in October 2010. My friend Warren was the first to mention the noise after he had flown it for about a month. We ran both planes side by side and they both sounded the same. It was a concern for a while, but I really don't even hear it anymore unless someone mentions it.... all three motors have been running fine and I have seriously abused the original. I have not heard anything from any of the original gang of nine about a motor failure. Some of the planes have not survived, of course....
Aeroplayin is online now Find More Posts by Aeroplayin
Old Sep 20, 2011, 09:34 PM
Tom K. is offline
Find More Posts by Tom K.
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Hehe...
Tom K. is offline Find More Posts by Tom K.
Old Sep 21, 2011, 03:31 PM
Mr Big Head is offline
Find More Posts by Mr Big Head
Mr Big Head's Avatar
United States, CA, Redding
Joined Feb 2011
A question about the old Extra 300 SHP.
I purchased a yellow Extra 300 SHP about 3 weeks ago off the ceiling at a Sacramento hobby shop. Once I got it home I noticed that the vertical stab was not pushed in all the way. I was able to remove it and now it will seat all the way down. I had to remove the hinges on the rudder too as the alignment was now not right. Since I have taken it apart this far I also removed the elevator. Its halves were connected by a wire with 90 degree bends on the end that plugged into each elevator half. I know the new design has a flat stick which connects them and is much more solid.
I am thinking I could cut a half circle behind the horizontal stabilizer and join the 2 halves together with a flat stick like the new design. Has anyone ever attempted this with success?
Mr Big Head is offline Find More Posts by Mr Big Head
Old Sep 21, 2011, 05:40 PM
3Daddict is offline
Find More Posts by 3Daddict
Addicted to 3DHS and EF
3Daddict's Avatar
United States, OH, Bristolville
Joined Oct 2010
I will have this plane back up in the air tomorrow. I sent in my hitec hs 65 to hitec and they fixed it for me free of charge. now it is time to get this bird back in the air.
3Daddict is offline Find More Posts by 3Daddict
Old Sep 23, 2011, 12:30 AM
str8wing is offline
Find More Posts by str8wing
Las Vegas, NV
Joined Nov 2009
Hi MBH, My version 2 yellow has the same phenolic "stick" between the elevator halves as my red version 3. I don't know if the version 1 used wire or not, but it really seems likely to me the original builder did an "old school" modification on his own. A piano wire elevator joiner was pretty common back in the days of DIY kits. It should have been epoxied in though. If you have both elevator halves off, changing it back to the original design shouldn't be too hard. Just make sure you use the same material 3dhs uses (looks like printed circuit board to me). I don't think a piece of basswood or spruce would be strong or rigid enough.
str8wing is offline Find More Posts by str8wing
Old Sep 23, 2011, 03:44 AM
GPT is offline
GPT
Find More Posts by GPT
GPT
GPT's Avatar
Sydney,Australia
Joined Dec 2004
Version 1's did have the wire joiner
GPT is offline Find More Posts by GPT
Old Sep 23, 2011, 10:13 AM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
i think the elevator joiner is fiberglass
keithy4129 is offline Find More Posts by keithy4129
Old Sep 23, 2011, 11:49 AM
dnahas is offline
Find More Posts by dnahas
dnahas's Avatar
USA, TX, Allen
Joined Jan 2011
Originally Posted by tominator06 View Post
Boy do I love my new charging setup. Friend of mine called and wanted me to go fly but I needed to charge 3 of my 4 packs. Didn't take long at all. 3 2200mah 3s packs took 3601 mah in 19 minutes. Quite a bit of that time was balancing too.
+1 for a good charging setup.
Did you try setting the icharger to balance as it charges, opposed to balancing at the end?
J/c to see if its any faster, my guess is no.
dnahas is offline Find More Posts by dnahas
Old Sep 23, 2011, 12:30 PM
Brownie433 is offline
Find More Posts by Brownie433
United States, WI, Milwaukee
Joined Sep 2008
It's phenolic I believe.
Brownie433 is offline Find More Posts by Brownie433
Old Sep 23, 2011, 01:02 PM
94'325is is offline
94'325is's Avatar
Florida
Joined Jan 2010
Yep, phenolic. Strong too, tried to break an old one and it took a LOT of force to snap.
Old Sep 23, 2011, 10:17 PM
Joined Aug 2010
is phenolic fiberglass? kind of looks it, not sure
Old Sep 24, 2011, 12:44 AM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
pretty much. phenolic resin impregnated fiberglass cloth.
theKM is offline Find More Posts by theKM
Old Sep 24, 2011, 01:27 AM
groovejet is offline
Find More Posts by groovejet
How many planes is too many?
groovejet's Avatar
Australia, VIC, Melbourne
Joined Aug 2007
Originally Posted by ambientech View Post
It will disappear with no new posts. Will have to search for it.
It's common practice to link to old threads in the first post of a new thread. Perhaps ask the OP to do that.
groovejet is offline Find More Posts by groovejet
For Sale 3DHS 47" Extra 300 SHP rdbell Aircraft - Electric - Airplanes (FS/W) 10 Jul 29, 2013 11:39 PM
Sold 3DHS 47" Extra 300 SHP Red Brand New jdrennen03 Aircraft - Electric - Airplanes (FS/W) 2 Aug 03, 2011 01:11 PM
Wanted Looking for the 3DHS 47" Extra 300 SHP - Red GlockDoc Aircraft - Electric - Airplanes (FS/W) 1 Jul 16, 2011 02:14 PM
Wanted 3DHS Red Extra SHP v3 47" Cowl gms Aircraft - General - Miscellaneous (FS/W) 0 Apr 19, 2011 10:59 PM
