Old Aug 31, 2011, 12:10 PM
Ace4 is offline
Find More Posts by Ace4
Stick banger
Ace4's Avatar
USA, AZ, Chandler
Originally Posted by 94'325is View Post
Oh forgot, one other tip.
When using the metal wing bolts, make sure to check them EVERY flight. Mine have gotten loose and I've lost a wing twice. One good way of preventing that and still keeping them easily removable is to cut a small disk of sandpaper and put it on the wingbolt. It stops them from coming loose but it's not as permanent as Loktite.
You can also grab some rubber o-rings from a hardware store and put them on the bolts, they work really well as lock washers on bolts that aren't tightly torqued.
Ace4 is offline Find More Posts by Ace4
Old Aug 31, 2011, 12:32 PM
lazor 22 is offline
Find More Posts by lazor 22
lazor 22's Avatar
Wendell, NC
Joined Jun 2010
Guess I should subscribe to this one.
lazor 22 is offline Find More Posts by lazor 22
Old Aug 31, 2011, 01:50 PM
Brownie433 is offline
Find More Posts by Brownie433
United States, WI, Milwaukee
Joined Sep 2008
I have a V2 SHP with a tad over 200 flights. I was thinking of trying V3 wings with the SFGs to help my harriers.
Will the V3 wings work on a V2 fuse? Same spar size, same position on fuse, some anti-rotation point? This may be something only the vendor can answer since they know the specs or anyone who owns both air frames.
Brownie433 is offline Find More Posts by Brownie433
Old Aug 31, 2011, 05:41 PM
Tom K. is offline
Find More Posts by Tom K.
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
I'm not the vendor... nor do I know if the wings will work... but if it turns out the wings don't fit, you could try making some custom SFG's:
http://www.rcwebclub.com/Articles/Te...5/Default.aspx
You should probably beef up the wood so it's not as flimsy since it won't be between the wing and the stock SFG's... and you may want to use a wood screw to install them, then take it out, soak the hole with some thin or medium CA, the after it's dry re-install them.
--Tom K.
Tom K. is offline Find More Posts by Tom K.
Old Aug 31, 2011, 07:24 PM
Chuck is offline
Find More Posts by Chuck
Balsa to the Wall
Chuck's Avatar
Deep in the East Texas Piney Woods
Joined Dec 2001
Thanks for starting this thread. I have a yellow V2 with almost 200 flights on it, and a blue V2 NIB for backup. I really love this plane. You can fly it as easy or hard as you want.
I'm just wondering if 3DHS replaces this one with the Buck & 1/2 Huck.
Chuck
Chuck is offline Find More Posts by Chuck
Old Aug 31, 2011, 07:36 PM
rdsok is offline
Find More Posts by rdsok
rdsok's Avatar
United States, OK, Norman
Joined Mar 2010
Chuck
Last I heard... they are keeping the SHP but they do plan to make a v4 with a few updates to the current airframe. I certainly wouldn't want to start speculating on the possible changes, probably minimal stuff since the v3 is already so nice.
There is only one change I'd wish for... an airfoiled elevator since that would be a bit stronger than the flat one it currently has. An option for either a recommended 3S or 4S setup would be nice for some... I'm partial to the 3S so it wouldn't be something I'd ask for... but I'm not everyone.
In the end, it will be tough for them to top the excellent model they already have in the SHP.
Randy
rdsok is offline Find More Posts by rdsok
Old Aug 31, 2011, 08:11 PM
tominator06 is offline
Find More Posts by tominator06
Team Hillbilly
tominator06's Avatar
United States, MD, Dundalk
Joined Feb 2009
I agree I think the changes will be minimal. Just a few tweaks and of course a couple new awesome Km color schemes. I mentioned something about airfoiled tail in the other thread when the new version was first mentioned. From what I gathered the non airfoiled tail has much to to with the docility of this plane. If one wanted a more aggressive version then the velox would fit the bill much better. I have been trying to push the limits with it lately by overpowering it and trying to get more throw than it's designed for. I guess my best bet would be to leave it as it is and get another airframe with more aggressive handling characteristics. That way I'll always have a super forgiving plane to fall back on and or something to let others Sip the Kool-aid. I have a couple friends who are very interested in this plane so I plan on letting them get a pull on it next time I see them at the field. Got to spread the Awesomeness.
tominator06 is offline Find More Posts by tominator06
Old Aug 31, 2011, 09:02 PM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
yeah, I think that HUGE flat horizontal stab/elevator helps make it forgiving
keithy4129 is offline Find More Posts by keithy4129
Old Aug 31, 2011, 09:08 PM
Chuck is offline
Balsa to the Wall
Chuck's Avatar
Joined Dec 2001
Adding airfoiled tailfeathers would surely drive up the price.
Chuck
Old Aug 31, 2011, 09:13 PM
Irg is online now
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
ah but now that all you guys spent $150, what's $30 more?!!?
trust me, eventually you will get to the point where $150x10 seems totally reasonable to spend on a plane!!!11111!!!
Irg is online now Find More Posts by Irg
Old Aug 31, 2011, 09:35 PM
Tom K. is offline
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
An airfoiled stab will make it more stable because the air will flow over the surface smoother making for less buffeting... that's why full scale aircraft don't just put a hinged piece of plywood on the back (well there are more reasons...) If you want it to be docile... then turn back the rates. Now, we have a super stable SHP and with low rates anybody can fly it, and with high, you can really step up your game without having to spend another $300-$500 to set up a velox or slick or whatever... it just makes sense.
--Tom K.
Old Aug 31, 2011, 10:21 PM
Team Hillbilly
Joined Feb 2009
Well we can all speculate but only time will tell. One thing I do know is it flys great the way it is so anything they do to improve it will just make it that much better.
Old Sep 01, 2011, 11:15 AM
Joined Sep 2008
--Tom K.
Thanks Tom. I might look at that if the V3 wings won't work. I'm thinking they will but that's only a guess. Hopefully someone may know.
Old Sep 01, 2011, 12:29 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
--Tom K.
airfoil doesn't make the surface smoother, but it helps the air stay laminar in more attitudes. a flat surface creates turbulated air a lot sooner. the handling improvement is more for when the plane is at speed then during 3D, but biggest benefit is strength, people will simply be able to push them harder. as for full scale, a great many full scale planes have flat tail surfaces; pitts biplanes, lasers, even some Edges...
theKM is offline Find More Posts by theKM
Old Sep 01, 2011, 01:43 PM
Irg is online now
Irg
Irg
Irg's Avatar
Joined Apr 2009
neat info and photo! thanks km.
For Sale 3DHS 47" Extra 300 SHP rdbell Aircraft - Electric - Airplanes (FS/W) 10 Jul 29, 2013 11:39 PM
Sold 3DHS 47" Extra 300 SHP Red Brand New jdrennen03 Aircraft - Electric - Airplanes (FS/W) 2 Aug 03, 2011 01:11 PM
Wanted Looking for the 3DHS 47" Extra 300 SHP - Red GlockDoc Aircraft - Electric - Airplanes (FS/W) 1 Jul 16, 2011 02:14 PM
Wanted 3DHS Red Extra SHP v3 47" Cowl gms Aircraft - General - Miscellaneous (FS/W) 0 Apr 19, 2011 10:59 PM
