Old Dec 08, 2012, 11:25 AM
JOHN 3:16
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Looks like your build area is too neat & tidy to me!
Sammy70 is offline Find More Posts by Sammy70
Old Dec 08, 2012, 11:48 AM
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Originally Posted by Ohio AV8TOR View Post
Anyone looking for a deal on a Omega 130g motor? This was all bought the end of Sept and only has 128 flights on it. The motor never was crashed and in fact never had a broken prop with it. I am moving up in size.
Omega 130g motor, Extreme Flight Airboss 45A ESC, and 4 Falcon props (2 used and 2 new in the packaging 2 ea. 13x6.5 and 14x7)
New $205 will sell shipped in the conus $110
Goes to the first
This is sold
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Dec 08, 2012, 12:41 PM
Look out below
mcnowhere's Avatar
United States, OR, McMinnville
Joined Aug 2011
It gets messy, I keep gettin smudges from my fingers having ca on them. Anything clean that off when I am done?
mcnowhere is offline Find More Posts by mcnowhere
Old Dec 08, 2012, 01:09 PM
JOHN 3:16
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Yes--use a little CA debonder on a paper towel to wipe of CA marks.
Old Dec 08, 2012, 03:02 PM
Joined Sep 2012
hi, small question, where is your CG in 3D on the 47' v4?
thanks
sebfrench is offline Find More Posts by sebfrench
Old Dec 08, 2012, 03:12 PM
Bloosee's Avatar
United States, CA, San Diego
Joined Jan 2012
thanks
The exact same location as the CG for normal flight. Lots of BS out there about the CG being rear ward for 3D but the proper CG is the proper CG no matter what.
Bloosee is offline Find More Posts by Bloosee
Old Dec 08, 2012, 03:15 PM
Mr Big Head's Avatar
United States, CA, Redding
Joined Feb 2011
Originally Posted by Bloosee View Post
The exact same location as the CG for normal flight. Lots of BS out there about the CG being reward for 3D but the proper CG is the proper CG no matter what.
1 mans pain is another mans pleasure..... Just Sayin
Mr Big Head is offline Find More Posts by Mr Big Head
Old Dec 09, 2012, 09:51 PM
Hav2fly's Avatar
Pflugerville, Tx
Joined Jan 2010
Originally Posted by Da Big_G View Post
Flew the SHP for the second outing Thursday. I was not impressed with the punch-out of the omega 130g. Pulled some data tonight.
With an APC 13-6.5 prop. (33 grams)
42 amps
4lbs./6oz. thrust
466 watts
169 watts/lb.
With Hobby King APC "style" 14-7 prop. (28 grams)
52 amps
4lbs./11 oz. thrust
577 watts
209 watts/lb.
Battery: Hobby King Turnigy 3S, 2200ma., 35-45C
Unloaded voltage: 4.04 volts/cell
ESC: Thunderbird 54
RTF plane weight: 44oz.
This should yield positive results. I'll find out tomorrow.
On a side note: I added some spoilerons (-5 for now) on the retract switch to help with landing. I can harrier land it, but I am old school and want to land it traditionally, if possible.
I don't think that 130g is as strong as it should be. My 103g was a lot stronger in that plane. I'm not using the 103 right now if you want to try it. The right wing on my 41" EPP Edge ripped off in mid flight a couple of weeks ago. The 103 was in it and made crazy power at it did in the SHP.
I expected more out of it when I installed it in that plane.
Shane
Hav2fly is offline Find More Posts by Hav2fly
Old Dec 09, 2012, 10:07 PM
"Get off the runway!"
Da Big_G's Avatar
United States, TX, Hutto
Joined May 2012
Shane
Yea, the motor feels a little tight, but I don't know Omega motors. The vertical pull-out is very authoritative now with the 14-7 prop...and I still get 5 min. flight times with mixed flying. Perhaps the Thunderbird esc is holding it back a bit, maybe needs a bit more timing. Even with the 3S/2200 LiPo, the AUW is still 44 oz., so it looks like I'm good to go. Did you ever check the watts or amps when you flew it with the 130 motor? I will say it hovers at least as easily as my 3DHS EPP Edge 540.
Da Big_G is offline Find More Posts by Da Big_G
Old Dec 09, 2012, 10:18 PM
Hav2fly's Avatar
Pflugerville, Tx
Joined Jan 2010
I never checked it with the 130, but Im l pretty sure the numbers were better on the 103, than what you show with 130 on a 13x6.5 ..
Glad it hovers as well as the EPP Edge, considering the
Edge has a gyro
Old Dec 09, 2012, 10:31 PM
Da Big_G's Avatar
Joined May 2012
Edge has a gyro
The gyro is set to minimum gain but it helps in windy landing, for sure. I should crank it up and see if it helps hovering...It doesn't seem to respond very quickly, though.The 130 seems to be performing as designed, at least on paper. I do see that many owners of 47-48 inch planes prefer the 130 over the 103. Sorry about your wing departure. BTW, I did up the spoilerons to -10, and the landings are slick as can be.
Old Dec 10, 2012, 12:41 PM
Bloosee's Avatar
Joined Jan 2012
So -10 is downward deflection?
Old Dec 10, 2012, 12:47 PM
Da Big_G's Avatar
Joined May 2012
Upwards on Futaba. It's just a number. Seems to be about 2-3 degrees.
Old Dec 10, 2012, 07:04 PM
Look out below
mcnowhere's Avatar
Joined Aug 2011
Up like a spoiler? Not down like flaps.
Old Dec 10, 2012, 07:16 PM
Da Big_G's Avatar
Joined May 2012
Yes. Very effective at keeping the nose down. Makes very nice landings.
Sold 3DHS 47" Extra 300 SHP Red Brand New jdrennen03 Aircraft - Electric - Airplanes (FS/W) 2 Aug 03, 2011 12:11 PM
For Sale 3DHS 47" Extra 300 SHP rdbell Aircraft - Electric - Airplanes (FS/W) 2 Aug 02, 2011 08:38 AM
Wanted Looking for the 3DHS 47" Extra 300 SHP - Red GlockDoc Aircraft - Electric - Airplanes (FS/W) 1 Jul 16, 2011 01:14 PM
Wanted 3DHS Red Extra SHP v3 47" Cowl gms Aircraft - Electric - Miscellaneous (FS/W) 0 Apr 19, 2011 09:59 PM
