Old Dec 03, 2012, 08:31 AM
Da Big_G is online now
Find More Posts by Da Big_G
"Get off the runway!"
Da Big_G's Avatar
United States, TX, Hutto
Joined May 2012
Originally Posted by rayonnair View Post
Slop in the servos or bad centering are possible candidates? I had a similar problem with another plane that went away when I swapped the aileron servos out.
I don't think so, it is only to the right when inverted. Never a problem right side up. I will add a few degrees of down thrust and recheck this weekend. One thing I did notice is I had to add noticeable left aileron trim..maybe 1/8th inch...to get level flight. This does bother me. Maybe a slight wing warp. I will check incidences tonight.
Da Big_G is online now Find More Posts by Da Big_G
Old Dec 03, 2012, 10:33 AM
olds455 is offline
Find More Posts by olds455
USA, AK, Anchorage
Joined Nov 2005
How even is your elevator? Either mine wasn't straight when I glued it or the horizontal stab is twisted. I have figured it out yet but I've only flown mine twice anyways. It had some aileron trim required to
olds455 is offline Find More Posts by olds455
Old Dec 03, 2012, 10:39 AM
Da Big_G's Avatar
Joined May 2012
Originally Posted by olds455 View Post
How even is your elevator? Either mine wasn't straight when I glued it or the horizontal stab is twisted. I have figured it out yet but I've only flown mine twice anyways. It had some aileron grin required to
The elevator is off by a degree or two, I bought this plane used. I don't think this is the cause of the roll, but maybe someday I'll cut her up and fix it. I've got 2 other N.I.B. SHP's that I will build straight.
Old Dec 03, 2012, 10:49 PM
rcfun33 is offline
Find More Posts by rcfun33
Northern Colorado
Joined May 2004
Crash
Messed up post
rcfun33 is offline Find More Posts by rcfun33
Old Dec 03, 2012, 10:50 PM
rcfun33 is offline
Northern Colorado
Joined May 2004
Crash
So I tried to fly this weekend. I did my normal range check and all seemed to work fine. I gave some up elevator and took off from a dry lake bed. Shortly after takeoff it was obvious my elevator was stuck in an up position. I had full control of my rudder, ailerons and throttle, but the elevator was stuck. I could sort of control it, but too much throttle and it would just loop, too little throttle and it would want to stall.
After a couple of minutes of trying to get a grip on flying with the fixed elevator I decided to try to land. I tried to basically harrier it in, but I am not a very good 3D pilot and for some reason I have trouble with it tip stalling pretty hard when it stalls. So I was probably about 10 feet up and it stalled and I basically had no choice but to just shut it down.
The plane nosed in and broke the motor mount and cowl so I will have to see if I can order new ones and repair it.
The strange thing is that when I came up to the plane the elevator worked fine. While flying I had continued to try to work the elevator, but it never responded. I'm not sure what caused the elevator to have problems. I was flying off of dirt and I wondered if a pebble could have gotten stuck in the elevator, but it seems unlikely that it could have stayed stuck with me working the elevator up and down. The servos are HS-65MG and probably have less than a dozen flights on them and no crashes before now.
Any ideas of what could have happened?
Dave
Old Dec 03, 2012, 11:41 PM
rayonnair is online now
Find More Posts by rayonnair
rayonnair's Avatar
Singapore, Singapore
Joined Jun 2012
Yup that's precisely the issue I had. Upright no roll. Inverted a slow roll in one direction. It went away when I replaced the servos, but I cannot confirm that this was the reason.
rayonnair is online now Find More Posts by rayonnair
Old Dec 04, 2012, 12:38 PM
3Daddict is offline
Find More Posts by 3Daddict
Addicted to 3DHS and EF
3Daddict's Avatar
United States, FL, Bonita Springs
Joined Oct 2010
Dave
My guess is there is something wrong with the servo. I would sent it back to hitec and see what they say. as for it not doing anything on the ground that is more thank likely due to there being no load on it.
3Daddict is offline Find More Posts by 3Daddict
Old Dec 06, 2012, 11:14 AM
JamesFM is offline
Find More Posts by JamesFM
Joined Nov 2012
Well I took my Extra out for a few flights this morning after finally getting around to changing out the bent prop adapter. She few great besides my rudder sticking. I think where the pull-pull wires attach to the servo horn is to tight and not rotating freely. Did my first KE spin, and 10+ more to follow it. Flies soooo much different than my 48 inch foamie so I'm a little cautious doing low flying. Haven't quite got the hang of inverted harriers on it yet too.
So it few great, but landing it was a real PITA. Not matter what I tried I couldn't stop it from tipping over nose first in the field that I'm flying in. The ground isn't exactly smooth. I put some new 2.5 inch wheels on it but I don't think they made a difference. I'm starting to think I need to make a hybrid ski/wheel combo. Putting a ski over the wheel and having maybe 1/16th of an inch of the bottom of the wheel poking through it. It'll add some weight but as long as I get it close to what the wheel pants weight I should be good. I'm open to suggestions though.
JamesFM is offline Find More Posts by JamesFM
Old Dec 06, 2012, 06:58 PM
Bloosee is online now
Find More Posts by Bloosee
SoCal fair weather flyer
Bloosee's Avatar
United States, CA, San Diego
Joined Jan 2012
With my buck huck on grass, I found that taking off the non-stock big wheels and replacing them with the stock wheels AND pants made it land better. The pants act as skis/skids, they slide over clumps of grass instead of the wheels bumping and rolling over them. They pants are designed to do that. I think people make the mistake of thinking they will cause problems but instead they improve things.
As far as tipping over, it sounds like a no brainer and rather obvious, but if you hold full elevator after you touch down and stay on it until the plane stops it shouldn't tip over. I hadn't flown in a couple of weeks and I was tipping over on touch down, couldn't figure out why my landings sucked, I didn't even realize I was letting go of the elevator, DUH!
Bloosee is online now Find More Posts by Bloosee
Old Dec 07, 2012, 10:24 PM
Da Big_G's Avatar
Joined May 2012
FYI motor data
Flew the SHP for the second outing Thursday. I was not impressed with the punch-out of the omega 130g. Pulled some data tonight.
With an APC 13-6.5 prop. (33 grams)
42 amps
4lbs./6oz. thrust
466 watts
169 watts/lb.
With Hobby King APC "style" 14-7 prop. (28 grams)
52 amps
4lbs./11 oz. thrust
577 watts
209 watts/lb.
Battery: Hobby King Turnigy 3S, 2200ma., 35-45C
Unloaded voltage: 4.04 volts/cell
ESC: Thunderbird 54
RTF plane weight: 44oz.
This should yield positive results. I'll find out tomorrow.
On a side note: I added some spoilerons (-5 for now) on the retract switch to help with landing. I can harrier land it, but I am old school and want to land it traditionally, if possible.
Old Dec 07, 2012, 10:27 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
42 amps
4lbs./6oz. thrust
466 watts
169 watts/lb.
52 amps
4lbs./11 oz. thrust
577 watts
209 watts/lb.
Battery: Hobby King Turnigy 4S, 2200ma., 35-45C
ESC: Thunderbird 54
omega 130g on 4s and a 14x7 will burn up the motor
3drcparts is offline Find More Posts by 3drcparts
Old Dec 07, 2012, 10:37 PM
Da Big_G's Avatar
Joined May 2012
Yes it will.. 3 series..11.1 volts...my bad.
Old Dec 07, 2012, 10:58 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
good, just making sure
Old Dec 08, 2012, 07:04 AM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Anyone looking for a deal on a Omega 130g motor? This was all bought the end of Sept and only has 128 flights on it. The motor never was crashed and in fact never had a broken prop with it. I am moving up in size.
Omega 130g motor, Extreme Flight Airboss 45A ESC, and 4 Falcon props (2 used and 2 new in the packaging 2 ea. 13x6.5 and 14x7)
New $205 will sell shipped in the conus $110
Goes to the first
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Dec 08, 2012, 10:23 AM
mcnowhere is offline
Find More Posts by mcnowhere
Look out below
mcnowhere's Avatar
United States, OR, McMinnville
Joined Aug 2011
Well got started on my blue shp.
Description: parts laid out
Taking longer the most, first balsa so always going back to manual or vid
Description: cut out holes and more ca to joints
Seems to be coming together
Description: wheels and pants
mcnowhere is offline Find More Posts by mcnowhere
For Sale 3DHS 47" Extra 300 SHP rdbell Aircraft - Electric - Airplanes (FS/W) 10 Jul 29, 2013 10:39 PM
Sold 3DHS 47" Extra 300 SHP Red Brand New jdrennen03 Aircraft - Electric - Airplanes (FS/W) 2 Aug 03, 2011 12:11 PM
Wanted Looking for the 3DHS 47" Extra 300 SHP - Red GlockDoc Aircraft - Electric - Airplanes (FS/W) 1 Jul 16, 2011 01:14 PM
Wanted 3DHS Red Extra SHP v3 47" Cowl gms Aircraft - General - Miscellaneous (FS/W) 0 Apr 19, 2011 09:59 PM
