Old Nov 15, 2012, 08:31 AM
Da Big_G is offline
Find More Posts by Da Big_G
"Get off the runway!"
Da Big_G's Avatar
United States, TX, Hutto
Joined May 2012
Originally Posted by 3171scott View Post
I picked up an older one and they dont have that perticular blue that you have. Its not a big deal, i will get a newer version if i have to. was just checking, thanks.
They have the blue one in stock, the white one is out. I can sell you one if you're sure it is correct. Do you need a blue/white/silver one? Do you have a pic. of the damaged one?..If not, I'll post up a pic. of what I have.
Da Big_G is offline Find More Posts by Da Big_G
Old Nov 15, 2012, 05:21 PM
JamesFM is offline
Find More Posts by JamesFM
Joined Nov 2012
Well, I maidened it today. First flight was mostly trimming her and getting a feel for it. Landing was a bit sketchy, came in slightly hard. Second flight I started putting her through the paces. Gotta love that blender/KE spin growl. On landing I came up a little short of my runway, it's very short about 50 feet so I gotta use it all, wheel pant caught on a group of small rocks and tipped it over. The air frame looks ok from what I can see, but I haven't taken the cowl off yet to really get a look at the motor box.
However, I bent the motor shaft. Where can I get another for the Omega 130g motor?
JamesFM is offline Find More Posts by JamesFM
Old Nov 15, 2012, 05:29 PM
AeroKen is offline
Find More Posts by AeroKen
3D? I only got two thumbs!
United States, MA
Joined Jul 2012
Are you sure you bent the motor shaft? I had a similar incident in a different plane with an Omega 130, and the prop adapter was bent but the motor shaft was fine.
AeroKen is offline Find More Posts by AeroKen
Old Nov 15, 2012, 07:58 PM
Bloosee is offline
Find More Posts by Bloosee
SoCal fair weather flyer
Bloosee's Avatar
United States, CA, San Diego
Joined Jan 2012
I would think the plane's front end would self destruct before the shaft would bend! I've knocked my buck huck over plenty of times, motors fine, couple of broken props is all. I've found these planes to be way more solid than I ever expected.
Bloosee is offline Find More Posts by Bloosee
Old Nov 16, 2012, 01:14 PM
Hewey19 is offline
Find More Posts by Hewey19
Hewey19's Avatar
USA, MI, Lansing
Joined Aug 2009
If you need anything it is probably just this.
http://www.3dhobbyshop.com/Omega-Air...r_p_15514.html
Hewey19 is offline Find More Posts by Hewey19
Old Nov 16, 2012, 02:44 PM
JamesFM is offline
Joined Nov 2012
Yep, that was it. Thanks guys.
Old Nov 20, 2012, 07:32 AM
3171scott is offline
Find More Posts by 3171scott
3171scott's Avatar
United States, OH, Youngstown
Joined Apr 2011
I have what ever version that did not come with SFG's and flat tail surfaces, When i checked the 3DHS parts it did not look like a match. I will take a pic of the plane and if you can help cool, if not i will pick up one from them. Thanks for your time.
3171scott is offline Find More Posts by 3171scott
Old Nov 22, 2012, 10:03 AM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Any Texas flyers looking to buy a 47" SHP?
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Nov 22, 2012, 12:00 PM
Da Big_G is offline
Da Big_G's Avatar
Joined May 2012
Sorry man, I just picked up 3....G/L.
Old Nov 22, 2012, 04:26 PM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
i snapped the motor shaft (not the prop adapter) in mid air on a 103 gram omega motor, it was funny seeing the can/prop shoot off, lol.
keithy4129 is offline Find More Posts by keithy4129
Old Nov 22, 2012, 08:13 PM
Bloosee is offline
Bloosee's Avatar
Joined Jan 2012
Old Nov 23, 2012, 11:38 AM
Ace4 is offline
Find More Posts by Ace4
Stick banger
Ace4's Avatar
USA, AZ, Chandler
Yea, that happened during a blender on mine. Motor was about 1.5 year old at that point. I replaced the shaft and flew it for another 6 months til the backplate of the motor cracked and the can started rubbing.
Ace4 is offline Find More Posts by Ace4
Old Nov 23, 2012, 10:01 PM
rayonnair is offline
Find More Posts by rayonnair
rayonnair's Avatar
Singapore, Singapore
Joined Jun 2012
Another fun morning with the extra 300 SHP. Trying to teach myself rollers, but got bored and frustrated at my bad timing. So I decided to bring it low (eye level) and practice my upright harrier. Then I thought it would be a good idea to bring it as close as I possibly could to myself.*
So it comes closer, and closer, and closer. About 3 metres away I think to myself, 'it's time to turn it around'. I put in some rudder... in the wrong direction! The bird heads STRAIGHT for me. With no time to turn it around I RUN clutching my controller. The bird sails through the area I occupied a second ago and I have a heavy harrier landing -> flip over.
The peanut gallery was very amused!
No damage to the extra, I threw her back in the air after checking that the motor mount hadn't cracked. This is really one tough bird.
*Note: I'd never dream of doing this if there were people around me. I was alone at the flight line today, hence this seemed like a good idea .
rayonnair is offline Find More Posts by rayonnair
Old Nov 23, 2012, 10:45 PM
asasan is offline
Find More Posts by asasan
United States, CA, Berkeley
Joined Jul 2011
where did you find a motor shaft for 103?
asasan is offline Find More Posts by asasan
Old Nov 24, 2012, 09:45 AM
mcnowhere is offline
Find More Posts by mcnowhere
Look out below
mcnowhere's Avatar
United States, OR, McMinnville
Joined Aug 2011
Hello all. Have been stalking this thread for a little bit and ordered a blue shp with the 130 omega on black friday(discount code). I am waiting for stock level to return from HURC and wanted you to double check my list.
APC 13 x 6.5E Composite Propeller - Prop $4.90
HYPERION CLASSIC SHAPED SPINNER 2" Blue $4.90
Sky Power 60A ESC with Switchmode BEC $32.95
Emax 12g ES08MA Metal Gear Sub Micro Servo $7.95
6 and 12 inch extentions
I already have 2 sky lipo 2650's that I hope might work- 30c and 228g
I can't tell if the plane comes with control rods or not?
mcnowhere is offline Find More Posts by mcnowhere
For Sale 3DHS 47" Extra 300 SHP rdbell Aircraft - Electric - Airplanes (FS/W) 10 Jul 29, 2013 10:39 PM
Sold 3DHS 47" Extra 300 SHP Red Brand New jdrennen03 Aircraft - Electric - Airplanes (FS/W) 2 Aug 03, 2011 12:11 PM
Wanted Looking for the 3DHS 47" Extra 300 SHP - Red GlockDoc Aircraft - Electric - Airplanes (FS/W) 1 Jul 16, 2011 01:14 PM
Wanted 3DHS Red Extra SHP v3 47" Cowl gms Aircraft - General - Miscellaneous (FS/W) 0 Apr 19, 2011 09:59 PM
