Old Aug 17, 2012, 12:09 PM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Originally Posted by dentalpain View Post
Do u think 65hb on ailerons will be okay with stock arms. Im pulling these from another build. Its not a big deal to pick up some 65mg if they make a difference.
I personally have no experience with 3DHS planes using the HB with their large control surfaces. I was just saying if you use them you can reduce the stress on them by not using the long arms and still get the recommended movement. The best solution however is the MG servos. Use MG for sure on elevator and rudder. If you have to buy a MG look at the Savox 0255 servo which is digital and metal gears for basically the same price. That is what I am moving into next. The Savox I put in my 87" Extra have been fantastic.
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Aug 17, 2012, 01:58 PM
dentalpain is offline
Find More Posts by dentalpain
dentalpain's Avatar
United States, FL, Marianna
Joined Apr 2011
Order placed. Im going to try the 65hbs (since I have them) first and upgrade if needed. Now I have 3x gens 3s 2200, do you guys think these will okay or should I grab some 2500-2600 for better cg? I will be using a 130g w/ ice 50lite on a 14x7 apc.
dentalpain is offline Find More Posts by dentalpain
Old Aug 17, 2012, 06:21 PM
propchief is offline
Find More Posts by propchief
JKasprak
propchief's Avatar
Fayetteville, NC 28304
Joined Jan 2010
you should be fine
propchief is offline Find More Posts by propchief
Old Aug 17, 2012, 07:19 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
you'll be fine and you can always upgrade the hs-65hb to mg by just swapping the gear set
3drcparts is offline Find More Posts by 3drcparts
Old Aug 17, 2012, 08:56 PM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
SHP Awesomeness
man, got some flights in with this plane today (v3), it is my original 3d balsa wood plane, I never get bored of it, and it's so durable, I'm glad it was kept in production, I still have a brand new in the box v3, I bought it because I was certain I would turn this thing into popsicle sticks, It has sat in the box for a very long time, I'm kind of thinking about picking up a v4 because of the air-foiled tail feathers. Does the air-foiled vertical/horizontal stabs make that much of a difference over the v3? I know it helps with durability but does it fly that much better? It's gotta be hard to perfect perfection
keithy4129 is offline Find More Posts by keithy4129
Old Aug 18, 2012, 07:52 AM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
I think longer arms would put more stress on the gear?
going4speed is offline Find More Posts by going4speed
Old Aug 18, 2012, 08:22 AM
dentalpain's Avatar
Joined Apr 2011
Thats what he said...thanks for the input guys. Looking forward to this airframe.
Old Aug 18, 2012, 11:33 AM
Bigster is online now
Find More Posts by Bigster
Well, now that you know ...
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
I had the longer arms on the ailerons on mine and ended up taking them off due to blowback with the HS-65's. It's much, much better now with the stock arms. Plenty of throw and less blowback.
Bigster is online now Find More Posts by Bigster
Old Aug 18, 2012, 12:07 PM
Joined Aug 2010
+1, max out the endpoints and use the shortest arm possible.
Old Aug 19, 2012, 04:41 PM
3dhsedge41er is offline
Find More Posts by 3dhsedge41er
Joined Jul 2011
I am 15 and would like to buy this plane. I live in Idaho Falls and it is always windy here. (does this fly ok in the wind?) I have the bh and the only reason i am not buying th 1.5 bh is because of the landing gear. So, I was wondering if there was a cheaper setup. I know it won't fly as good, but my parents don't want me to blow all the money I earned this summer and want me to save for college and a mission for my church. So I want to know if I should just get the omega 130(best) or if there was a good sunnysky or gforce that i could use. Any experiance with either? I like to fly WOT on my bh and I am about 5000 asl. I would also like to find a cheaper alternative to the hitecs. I killed all of the hs45 in my bh.( ironically rudder was the last to go) and although they were replaced i would rather buy two extra cheaper servos for an instant fix. I would like to get a hk or hp esc for around $30-40 and I have a reciever (corona) any info and/or constructive criticsm would be nice. Also alternates to anything listed above from your experiance
3dhsedge41er is offline Find More Posts by 3dhsedge41er
Old Aug 19, 2012, 04:54 PM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
I've been wanting to try these servos. They have the same specs as a hitec 65mg http://twistedhobbys.com/Servo-TH-14...Servo-MG65.htm
There are also some solar servos from HP, but i'm not sure which ones are the ones you need.
The ZTW esc have proven to be a good esc for many folks and it's a reasonable price
http://www.quantumhobby.com/ZTW-50A-...ztw50asbec.htm
As far as motors i think that's one area i don't mess around with and either go with the recommended setup or a motrofly but i think those are more expensive. But someone else can hopefully chime in on the motor
hone1er is offline Find More Posts by hone1er
Old Aug 19, 2012, 05:26 PM
On loan to Texas
Joined Oct 2005
Originally Posted by 3dhsedge41er View Post
I am 15 and would like to buy this plane. So, I was wondering if there was a cheaper setup. I know it won't fly as good, but my parents don't want me to blow all the money I earned this summer and want me to save for college and a mission for my church.
The Omega130 is a perfect motor for this plane and I would not skip it. A friend has put together a 3DHS 48" Edge 540 on a budget and later bought the 130 motor. He is very happy with everything else so you may want to look into a Hobbywing ESC and Solar as that is what he is using and quite happy with it. He has around 40 flights with it so I cant give you long term success. Good luck
Old Aug 19, 2012, 08:38 PM
Capt. Roll is offline
Find More Posts by Capt. Roll
Capt. Roll's Avatar
United States, TX, Fort Worth
Joined Dec 2010
Here is my "economical" 48" Edge electronics. I haven't change anything in the plane other than the motor. Go with the Omega 130 if you can; bundle it with the ARF when you order and I think it saves you $10.
Servos:
Solar D654 for ailerons (direct drop in for servo opening)
Solar D658 for rudder (this is over-sized, servo opening needs to be enlarged)
PowerHD 2216 for elevator (direct drop in for servo opening)
ESC:
HobbyWing 60 Amp Opto
BEC
HobbyWing 3-5 Amp Switching Type
Motor:
Exceed RC Rocket 3015-840kv
Prop:
JXF 14X7 electric
Spinner
HK 1.5" plastic with AL backplate
LiPo's
3S 2200mAh 25C GensAce; 30C Gforce; 30C Glacier
The Rocket 3015-840 is not blistering fast but will pull this plane unlimited vertical. This motor is probably a little stronger than the Omega 103 but not as powerful as the Omega 130. The Omega 130 was not in stock anywhere when I ordered the Edge so I went with a Rocket. I"ve had good success with the Rocket motors in other builds and this one was working nicely for a $17 motor. 3DHS received new inventory on the Omega 130 so I ordered one and replaced the Rocket. The Omega 130 for sure has more power; the Rocket will serve as a backup.
The Solar servos are digital with metal gears. Right now there is no gear slop/lash; nice range of motion, speed from stop to stop is fast, they hold their deflected position, and return to center positions with out twitching or bounce. After 40 flights there have been no changes in performance. They will be a great value if the servos hold up over the long haul.
I've very pleased with the performance and flight characteristics of this setup. My 3D skills are limited but the plane has easily handled anything I'm able to do.
Capt. Roll is offline Find More Posts by Capt. Roll
Old Aug 20, 2012, 08:04 PM
Brownie433 is offline
Find More Posts by Brownie433
United States, WI, Milwaukee
Joined Sep 2008
Just an FYI on my experience with the HS65-HBs.
I have a V2 SHP with 268 flights on it. I have the original HBs on the ailerons and elevator, they are getting a little sloppy but not much. I had to replace the HB on the rudder at 154 flights when the wind picked my bird up off the runway and slammed it down. The rudder took a big hit and lunched the HB servo.
If you aren't banging the servos off the ground or in the car the HBs have been fine for me. Helped me with an already tailheavy bird.
Brownie433 is offline Find More Posts by Brownie433
Old Aug 20, 2012, 10:34 PM
SoarWest is offline
Find More Posts by SoarWest
Trex 700, Gaui X5, 450DFC
SoarWest's Avatar
United States, AZ, Queen Creek
Joined Apr 2010
3DHSEdge41'r
FYI I packed up a 103g and a 50A ESC for you, will place it in the mail tomorrow morning.
Let me know what you decide to fly and how it goes.
Good luck with your adventures in flying and keep after those school and mission plans.
;-) Dale in AZ
SoarWest is offline Find More Posts by SoarWest
For Sale 3DHS 47" Extra 300 SHP rdbell Aircraft - Electric - Airplanes (FS/W) 10 Jul 29, 2013 10:39 PM
Sold 3DHS 47" Extra 300 SHP Red Brand New jdrennen03 Aircraft - Electric - Airplanes (FS/W) 2 Aug 03, 2011 12:11 PM
Wanted Looking for the 3DHS 47" Extra 300 SHP - Red GlockDoc Aircraft - Electric - Airplanes (FS/W) 1 Jul 16, 2011 01:14 PM
Wanted 3DHS Red Extra SHP v3 47" Cowl gms Aircraft - General - Miscellaneous (FS/W) 0 Apr 19, 2011 09:59 PM
