Old Aug 13, 2012, 09:42 PM
tominator06 is offline
Find More Posts by tominator06
Team Hillbilly
tominator06's Avatar
United States, MD, Dundalk
Joined Feb 2009
Originally Posted by SoarWest View Post
Built my first 3DSH plane, the 47Ē Extra 300 SHP and had a maiden flight this weekend. All went well, itís trimmed nearly exactly neutral and is possibly tail heavy with the battery all the way forward. Inverted it flies level just as it does oriented normally and up. On takeoff I was expecting it to pull up and finally had to use elevator to lift it off the ground.
Iím a little disappointed in the power of the 103g with a 12x6 prop. I donít seem to have the quick responses I was expecting from watching other friends fly their 3DHS planes. I had expected the recommended setup to be a bit more, but perhaps itís not the motor, but another component such as the ESC or the prop?
In testing with a fresh 3S 2200mAH I get the following stats:
HK 40A ESC, 12x6 JXF poly composite prop; yields 42.4Amps peak, 473.2 watts peak
It takes a bit to spin up and I was expecting it to respond like an EPP foamy, maybe that is just how these larger planes are? If I upside the motor, perhaps the Motrofly 2815-950? They show 500 watts in their data with a 12x6 prop but thatís not much of a difference.
Suggestions for next steps are appreciated? My thinking is to let one of my friends who has several 3DHS planes give it a fly and see what he thinks, then look at the ESC or possibly prop, but my default guess is itís the engine.
Thanks for input, Dale
I would think about trying a 13x4 apc prop. That might be the sweet spot. Getting a better esc might also net good results. Get some video.
tominator06 is offline Find More Posts by tominator06
Old Aug 13, 2012, 11:36 PM
scot88 is offline
Find More Posts by scot88
Joined Jun 2010
SoarWest
Are you sure the esc isn't in heli, governer mode? #7 on the programing, 1st mode has a 5 sec delay to ramp up to full power if your using the Mystery/ HK esc.
scot88 is offline Find More Posts by scot88
Old Aug 14, 2012, 11:50 AM
Ace4 is offline
Find More Posts by Ace4
Stick banger
Ace4's Avatar
USA, AZ, Chandler
Try an APCe 13x6.5 or Xoar electric 13x6.5, it will really wake up the 103g. I see you are in Maricopa, if you would like send me a PM and I could meet you at a flying field somewhere this weekend. I think I have some spare 13x6.5 props you could try. The slow spool up sounds like an ESC setting. I have the Motrolfly 2815-950 in my SHP, it's a little more powerful than the 103g, but the difference is not earth shattering.
Ace4 is offline Find More Posts by Ace4
Old Aug 14, 2012, 05:50 PM
rdcskkrose is offline
Find More Posts by rdcskkrose
TEAM HILLBILLY
rdcskkrose's Avatar
USA, CO, Highlands Ranch
Joined Apr 2009
I too strapped on the O130 14x7 combo after starting with the O103 13x6.5. Glad I did!
rdcskkrose is offline Find More Posts by rdcskkrose
Old Aug 14, 2012, 06:45 PM
SoarWest is offline
Find More Posts by SoarWest
Trex 700, Gaui X5, 450DFC
SoarWest's Avatar
United States, AZ, Queen Creek
Joined Apr 2010
It looks like I'll upgrade to the Omega130, especially if it qualifies for this weekends sale?
Ace, I would be happy to say hello sometime and go flying. I have some great flying spots in Maricopa if you are in the area. I head out to the place referred to as Area 51 on occasion too. I have yet to try the Chandler Bowl with my 3DHS planes, but they should fly there too, and that's fairly close. I just worry putting batteries in my car during these hot days but it's cooling down soon. 120 in a hot car is likely very bad for my batteries!
SoarWest is offline Find More Posts by SoarWest
Old Aug 14, 2012, 10:10 PM
Brownie433 is offline
Find More Posts by Brownie433
United States, WI, Milwaukee
Joined Sep 2008
After flying more this weekend. I just had to post how much I love landing with the aileron mix. It's way better than just down elevator. The landings were always a bit of a fight, I either got it nicely or it dropped onto the gear when the main wing stalled OR floated right on by me.
I raised the ailerons on a switch to kill some main wing lift and help keep the nose down for landing. Works awesome!!! Some guys with other tail heavy 3DHS birds are using it at the field now and love it.
http://www.rcgroups.com/forums/showp...postcount=1424
Brownie433 is offline Find More Posts by Brownie433
Old Aug 15, 2012, 12:06 AM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
What brand of 14x7 are you guys using? Right now I am using an APC but considering the Falcons when they are back in stock.
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Aug 15, 2012, 12:19 AM
SoarWest is offline
SoarWest's Avatar
Joined Apr 2010
Brownie, about how much up aileron are you adding when you flip this switch? A few more setup details would be appreciated. And are you measuring at the inside or outside of the aileron and elevator etc.
Old Aug 15, 2012, 12:22 AM
3Daddict is offline
Find More Posts by 3Daddict
Addicted to 3DHS and EF
3Daddict's Avatar
United States, FL, Bonita Springs
Joined Oct 2010
Xoar electric beachwood. and I suggest the 13x6.5 prop for this bird with the 130 gram omaga.
3Daddict is offline Find More Posts by 3Daddict
Old Aug 15, 2012, 12:23 AM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
sounds like a spoileron mix?
3drcparts is offline Find More Posts by 3drcparts
Old Aug 15, 2012, 12:54 PM
St3v3 is offline
Find More Posts by St3v3
St3v3's Avatar
United Kingdom, England, Fareham
Joined Jun 2011
I have one of these on order now
St3v3 is offline Find More Posts by St3v3
Old Aug 15, 2012, 03:31 PM
SoarWest is offline
SoarWest's Avatar
Joined Apr 2010
In reference to my questions above concerning speed to spin up the motor, I replaced the ESC with new more expensive unit and now have the following numbers. This ESC does put out more power with the same battery, motor, prop combo, and does respond more like I was expecting. Interesting that the ESC could be the lagging piece here.
Omega 103g on 3DHS Extra47SHP, battery 2200mAh 3S, fresh charge for each test
Test w/HK 50A ESC and 12x6 JXF Poly; 42.4A peak; 473.2 watts peak
w/Turnigy AE 45A ESC and 12x6 JXF Poly; 47.5A peak; 529.5 watts peak
50 more watts from the same setup is better than a 10% increase in power by changing a single component. I'll fly it to verify but it feels better in static testing.
Old Aug 15, 2012, 10:37 PM
Joined Sep 2008
Sure. For my 47" I have about 2-3 degrees of up for landing (measured inside as near the fuse as the aileron goes). I started out slow and worked my way to a comfortable angle. Lands sweet where I'm at. No funny business either, just makes it easier to keep the nose down and not balloon - which also prevents the stall.
For the actual radio setup - I cheat and use a futaba mix called Airbrake and it essentially let's me move any of my control surfaces up or down from center. I just moved the ailerons from 0 to -5.
Hope this helps.
Brownie
Old Aug 15, 2012, 10:44 PM
Joined Sep 2008
Yep, that's the term I was looking for.
Just a note: Some consider adding up elevator for spoileron mix to go with the up aileron, but in my landing mix this is not the case. Up elevator makes it worse, so keep the elevator normal or slightly down for this to work well.
Brownie
Old Aug 16, 2012, 12:11 AM
On loan to Texas
Joined Oct 2005
Hope this helps.
Brownie
I will have to try this when I get home to see if I like it better than the down elevator mix. Do you have it on a switch for to activate it or is it a throttle mix.
For Sale 3DHS 47" Extra 300 SHP rdbell Aircraft - Electric - Airplanes (FS/W) 10 Jul 29, 2013 10:39 PM
Sold 3DHS 47" Extra 300 SHP Red Brand New jdrennen03 Aircraft - Electric - Airplanes (FS/W) 2 Aug 03, 2011 12:11 PM
Wanted Looking for the 3DHS 47" Extra 300 SHP - Red GlockDoc Aircraft - Electric - Airplanes (FS/W) 1 Jul 16, 2011 01:14 PM
Wanted 3DHS Red Extra SHP v3 47" Cowl gms Aircraft - General - Miscellaneous (FS/W) 0 Apr 19, 2011 09:59 PM
