Old Aug 10, 2012, 04:17 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
Dont we all! If i could sell all my small planed with the exception of the 47 SHP in trade for a 87 I would do it in a heart beat!
Originally Posted by alfabeast View Post
I now have 4 flights on the SHP, and like it bigtime, maybe the best 3dhs plane yet, and I have had or have, 41-in edge, 38 epp, 47 Extra SR, 57 extra, 59 slick, 68 velox, yak 46, 71 slick. This thing feels like an extension of my brain! Now I need the big daddy 87.
going4speed is offline Find More Posts by going4speed
Old Aug 10, 2012, 04:23 PM
Fliprob17 is offline
Find More Posts by Fliprob17
ADC Vinyl
Fliprob17's Avatar
SoCal-Rancho Santa Marg.
Joined Mar 2007
the 87 is silky smooth. Used it for IMAC competition this year running a DA-60. Absolutely fantastic 50cc size plane.
Fliprob17 is offline Find More Posts by Fliprob17
Old Aug 10, 2012, 05:28 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
about 50% done, are you guys using the 3dhs long servo arms on the rudder/elevator?
3drcparts is offline Find More Posts by 3drcparts
Old Aug 10, 2012, 05:36 PM
3DHS 'native'
USA, TX, Spring
elevator only and its got ridiculous 55 degree throw.
Old Aug 10, 2012, 05:51 PM
LanceMc is offline
Find More Posts by LanceMc
Certified Wingnut
LanceMc's Avatar
Delta BC
Joined Jul 2008
On mine, I needed the long arms to get max throw on the rudder and elevator.
Lance
LanceMc is offline Find More Posts by LanceMc
Old Aug 10, 2012, 06:42 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
I' went with the short arm on rudder, will let you know if I need the longer arm
Old Aug 10, 2012, 07:09 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
Hs-65mg with dx8 at 150 throws, yep you need the longer arm for the rudder to get full deflection
Old Aug 10, 2012, 08:25 PM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Wow surprised you like it more than the 71" Slick. If and when you can do it "big daddy 87" will definitely top your list then.
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Aug 11, 2012, 07:28 AM
alfabeast is online now
Find More Posts by alfabeast
3D Addict
alfabeast's Avatar
Merrimac, MA
Joined Jan 2006
I love the slick too, but it took me longer to feel comfortable with it. I was there on the 3rd flight with the shp. I feel better down low with a cheaper airframe too, and can get out of trouble faster with the smaller plane.
alfabeast is online now Find More Posts by alfabeast
Old Aug 12, 2012, 11:44 AM
3D Addict
alfabeast's Avatar
Merrimac, MA
Joined Jan 2006
Well, after a few more flights on the shp, it is a blast to fly, but I came to my senses - the Slick 71 is better at low and slow, and hover. I was initially impressed with the way the SHP flies big during high energy extreme aerobatics, esp. for a smaller plane.
Old Aug 12, 2012, 04:39 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
Maiden went pretty good, but I think I'm tail heavy even with the battery all the way forwards, still wanted to climb inverted, I went with the omega 103g, but did not read the manual and thus did not use the spacers for the motor. It always takes me a while to dial in a new airframe, but I think I'll like it.
Old Aug 13, 2012, 08:24 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
Originally Posted by azlodaiel View Post
APC 13x6.5
APC 13X6.5 on my Omega 103 pulled 48 amps and 561 watts, I think that is going to cause me problems
Old Aug 13, 2012, 08:48 PM
SoarWest is offline
Find More Posts by SoarWest
Trex 700, Gaui X5, 450DFC
SoarWest's Avatar
United States, AZ, Queen Creek
Joined Apr 2010
Built my first 3DSH plane, the 47” Extra 300 SHP and had a maiden flight this weekend. All went well, it’s trimmed nearly exactly neutral and is possibly tail heavy with the battery all the way forward. Inverted it flies level just as it does oriented normally and up. On takeoff I was expecting it to pull up and finally had to use elevator to lift it off the ground.
I’m a little disappointed in the power of the 103g with a 12x6 prop. I don’t seem to have the quick responses I was expecting from watching other friends fly their 3DHS planes. I had expected the recommended setup to be a bit more, but perhaps it’s not the motor, but another component such as the ESC or the prop?
In testing with a fresh 3S 2200mAH I get the following stats:
HK 40A ESC, 12x6 JXF poly composite prop; yields 42.4Amps peak, 473.2 watts peak
It takes a bit to spin up and I was expecting it to respond like an EPP foamy, maybe that is just how these larger planes are? If I upside the motor, perhaps the Motrofly 2815-950? They show 500 watts in their data with a 12x6 prop but that’s not much of a difference.
Suggestions for next steps are appreciated? My thinking is to let one of my friends who has several 3DHS planes give it a fly and see what he thinks, then look at the ESC or possibly prop, but my default guess is it’s the engine.
Thanks for input, Dale
SoarWest is offline Find More Posts by SoarWest
Old Aug 13, 2012, 08:52 PM
3DHS 'native'
USA, TX, Spring
ESC is a bottle neck in my opinion. try a ztw speed control.
Or just stick with that setup and try a 13x6.5
Old Aug 13, 2012, 09:01 PM
skarface is offline
Find More Posts by skarface
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
I used a 14x7 with a omega 130g and that gives it a lot more punch than a 103g with 12x6 prop and I know alot of people use the motrolfly 2815-950 with a 13x6.5 and like it, or if you really want punch you can get a custom wound motrolfly 2815-1000 and use a 13x6.5 prop, I am going to try that setup when I have the cash to fix the plane and the motor but I have been told the 2815-1000 and a 13x6.5 prop will be alot of fun.
I really liked and had no problem with the 130g omega and a 14x7 but it broke and it was my fault so i bought a motrolfly to dry something different.
skarface is offline Find More Posts by skarface
For Sale 3DHS 47" Extra 300 SHP rdbell Aircraft - Electric - Airplanes (FS/W) 10 Jul 29, 2013 10:39 PM
Sold 3DHS 47" Extra 300 SHP Red Brand New jdrennen03 Aircraft - Electric - Airplanes (FS/W) 2 Aug 03, 2011 12:11 PM
Wanted Looking for the 3DHS 47" Extra 300 SHP - Red GlockDoc Aircraft - Electric - Airplanes (FS/W) 1 Jul 16, 2011 01:14 PM
Wanted 3DHS Red Extra SHP v3 47" Cowl gms Aircraft - General - Miscellaneous (FS/W) 0 Apr 19, 2011 09:59 PM
