Old Jul 31, 2012, 08:07 PM
skarface is offline
Find More Posts by skarface
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
think I will love it, just I need a plane to put it in, I don't know if my mom will let me get another one right now but then if I do I need to get some ball links and make the linkages 100% with no binding, I am sure that is why my elevator servo burnt out, which caused my last crash.
skarface is offline Find More Posts by skarface
Old Jul 31, 2012, 08:55 PM
asasan is offline
Find More Posts by asasan
United States, CA, Berkeley
Joined Jul 2011
Ignoring a one-time 30 or $40 extra cost, and extra 30 grams in 1200 (3%), what do you guys think of this motor for 47" SHP?
Scorpion SII-3020-890KV
Data Chart
It will actually help the battery location that was pretty screwed up with pull-pull and Omega 103g to begin with.
asasan is offline Find More Posts by asasan
Old Jul 31, 2012, 08:58 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
Looks great. I just don't like collet adapters on cowled airplanes.
going4speed is offline Find More Posts by going4speed
Old Jul 31, 2012, 09:42 PM
3Daddict is offline
Find More Posts by 3Daddict
Addicted to 3DHS and EF
3Daddict's Avatar
United States, FL, Bonita Springs
Joined Oct 2010
Originally Posted by going4speed View Post
How much flight time did you get out of that hacker?
I have one on my shp
it was one my V3 SHp for a year and on my new V4 for the past couple months.
3Daddict is offline Find More Posts by 3Daddict
Old Jul 31, 2012, 10:11 PM
blueapplepaste is offline
Find More Posts by blueapplepaste
blueapplepaste's Avatar
United States, TX, Keller
Joined Jul 2009
Data Chart
Scorpion motors are some of the nicest motors I've ever used. You can't go wrong. However, that one is heavier and a little more expensive, I would think there might be better options. But for sheer quality, scorpion is tops.
blueapplepaste is offline Find More Posts by blueapplepaste
Old Jul 31, 2012, 10:23 PM
3DHS 'native'
USA, TX, Spring
If they did a bolt on prop adapter I would run nothing else.
Old Jul 31, 2012, 10:26 PM
asasan is offline
Joined Jul 2011
Next ones down can only handle full throttle with 13x6.5 at short bursts. I like the comfort of not pushing the motor or ESC (ICE LITE 50A) doing whatever you like, WOT, even with 14x7.
Old Jul 31, 2012, 10:28 PM
tominator06 is offline
Find More Posts by tominator06
Team Hillbilly
tominator06's Avatar
United States, MD, Dundalk
Joined Feb 2009
Originally Posted by skarface View Post
Tom what did you pull with a 2825-1025 with 13x6.5? I have a hacker x55 you think that will be good?
My setup will be 2815-1000 13x6.5 hacker x-55 and 3s lipo. You guys think I should just get a ice lite 75?
Here is the first watts up test with it in the edge on the ice 75 and 13x6.5. This was right after i finished building it. Had not even flown it yet.
I ran it in the shp with the ice 50 on a 13x4 apc and xoar 13x5 and the amps were good.
3dhobbyshop 48" Edge 540 - Buck and a half Huck is ready for maiden (0 min 38 sec)
tominator06 is offline Find More Posts by tominator06
Old Jul 31, 2012, 10:29 PM
3DHS 'native'
USA, TX, Spring
Private video.
Old Jul 31, 2012, 10:30 PM
asasan is offline
Joined Jul 2011
you know you can get any adapter you like with set screw, etc. for 5mm shaft, right?
Old Jul 31, 2012, 10:34 PM
Team Hillbilly
Joined Feb 2009
Private video.
Sorry. I think I fixed it now.
Old Jul 31, 2012, 10:56 PM
skarface is offline
skarface's Avatar
Joined Aug 2011
I could not load the video from my iPhone? O well I will get on the computer tomorrow and watch it.
Old Jul 31, 2012, 11:22 PM
3DHS 'native'
USA, TX, Spring
Still not as good as a bolt on that EVERY motor manufacturer has except scorpion. The most expensive and they don't keep up with tech....hey use what you like its just not for me.
Old Aug 01, 2012, 02:11 AM
Eagle34 is offline
Find More Posts by Eagle34
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
I think PA uses those collet type adapters also, but they aren't really a manufacturer.
Eagle34 is offline Find More Posts by Eagle34
Old Aug 01, 2012, 02:19 AM
GPT is offline
GPT
Find More Posts by GPT
GPT
GPT's Avatar
Sydney,Australia
Joined Dec 2004
Data Chart
Way too heavy for this plane and with the collet adapter the prop will most likely sit way in front of the cowling. A Motrolfly 2815 -950 with a 13x6.5 is a sweet setup for the SHP
GPT is offline Find More Posts by GPT
For Sale 3DHS 47" Extra 300 SHP rdbell Aircraft - Electric - Airplanes (FS/W) 10 Jul 29, 2013 10:39 PM
Sold 3DHS 47" Extra 300 SHP Red Brand New jdrennen03 Aircraft - Electric - Airplanes (FS/W) 2 Aug 03, 2011 12:11 PM
Wanted Looking for the 3DHS 47" Extra 300 SHP - Red GlockDoc Aircraft - Electric - Airplanes (FS/W) 1 Jul 16, 2011 01:14 PM
Wanted 3DHS Red Extra SHP v3 47" Cowl gms Aircraft - General - Miscellaneous (FS/W) 0 Apr 19, 2011 09:59 PM
