Old Sep 07, 2011, 10:17 PM
3dFlyer88 is offline
Find More Posts by 3dFlyer88
is it supposed to smoke??
3dFlyer88's Avatar
canada alberta outside edmonton
Joined Apr 2007
yes we proved your method correct and have come up with another and will be uploading a video soon. Its a 100% effective unless u miss the rudder.
3dFlyer88 is offline Find More Posts by 3dFlyer88
Old Sep 07, 2011, 10:41 PM
3dFlyer88's Avatar
Joined Apr 2007
heres the video i mentioned
umx stryker upright boomerang techniques (2 min 19 sec)
Old Sep 07, 2011, 10:50 PM
lambers is offline
Find More Posts by lambers
Joined Jun 2010
http://www.youtube.com/watch?v=YuZLV5rIADw
Good video, I've always been nervous about letting it come down in the spin, but I think I'll try it next time now =)
lambers is offline Find More Posts by lambers
Old Sep 08, 2011, 06:33 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
The only way I can do it is with Dave's method (still working on yours as it seem much better). So all I can tell is that with Dave's method, you can simply reverse the right stick totally (it's up and right) to down and left, and it stop the spin almost right away, and it does stay relatively level. I would not want to do a full speed upright boomerang landing. But by stopping it just before, it does become a simple elevator landing. So with your method, there's probably a way to do the same thing and stop the rotation quickly just before landing...
RealGambler is offline Find More Posts by RealGambler
Old Sep 08, 2011, 06:50 AM
Canada, QC
Joined Oct 2009
Your video is taken from too far away, so I'm not sure, but I think your actual method is counterclockwise (if you're looking at the Stryker from the top as it's going down) while Dave and Lamber's methods are clockwise (again looking at the Stryker from the top). So if I'm right, most likely, the sticks moves could be all inverted and the spin could be done both way, easily. Something else that could be interesting I guess.
Old Sep 08, 2011, 07:46 PM
3dFlyer88's Avatar
Joined Apr 2007
yeah reverse the sticks you reverse the boomerang. THe camera hhas terrible zoom so its hard to show the spin but the landing was while it was in the boom and no damage has occured from probably 50 landing like this on 2 strykers.
Old Sep 08, 2011, 09:56 PM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
How about someone doing something like this??
RC Training - Blender (0 min 32 sec)
erkq is offline Find More Posts by erkq
Old Sep 09, 2011, 09:03 AM
bluemeane is offline
Find More Posts by bluemeane
bluemeane's Avatar
Joined Apr 2007
http://youtu.be/h7ZZD4vtn94
Not gonna happen with a pusher..... The fuse is too short, plus I don't think it has enough thrust to reverse like that and not hit the ground... And there is the fact that most people here say it doesn't have very much rudder authority.
But correct me if any of these are wrong.
bluemeane is offline Find More Posts by bluemeane
Old Sep 09, 2011, 09:09 AM
erkq is offline
Joined Dec 2010
Hahaha... not what I meant at all. But I can see how I wasn't clear. I meant show the boomerang in that format, with the stick input on one screen full speed and slo-mo.
Old Sep 09, 2011, 10:37 AM
bluemeane's Avatar
Joined Apr 2007
HAHAHAHA Nice.
I was thinking you were crazy for a moment.
Old Sep 12, 2011, 05:16 PM
Rooster433 is offline
Find More Posts by Rooster433
United States, NC, Mooresville
Joined Feb 2006
The way I do it is to
1. Carry some good speed
2. quickly push down elevator and full aileron deflection (either way) power off and opposite rudder
3. Once spin is established switch rudder to same direction as alieron
if you want a upright spin
do the same as above but entry should be between 30-45 degrees. Hold the controls until it establishes a flat spin. It might look like its going to be an inverted spin first... don't worry just hold on, it will go upright. Do not reverse rudder (it stops the pin for some reason)
Rooster433 is offline Find More Posts by Rooster433
Old Dec 04, 2011, 08:00 PM
Racerx4 is offline
Find More Posts by Racerx4
Racerx4's Avatar
United States, OK, Norman
Joined Jun 2011
What is an elevator landing?
Noah
Racerx4 is offline Find More Posts by Racerx4
Old Dec 04, 2011, 09:32 PM
Canada, QC
Joined Oct 2009
That's the bigger Stryker, but here is a good elevator landing example:
(you simply stall your speed, go full elevator, and let the Stryker come straight down. Basically, it's a vertical landing, no forward speed)
F-27Q Parkzone Stryker elevator landing (0 min 35 sec)
And here's some upright boomerang landings:
Ultra-micro Stryker 180 upright boomerang landings. (3 min 37 sec)
Old Apr 27, 2012, 08:41 AM
strykerf27q is offline
Find More Posts by strykerf27q
Joined Mar 2012
Bump! I'm flying a full sized q on full rates and trying to learn fast upright and inverted boomerangs!
strykerf27q is offline Find More Posts by strykerf27q
Old Sep 16, 2015, 05:22 PM
epoweredrc is online now
Find More Posts by epoweredrc
27 yrs. of Aircraft flying.
epoweredrc's Avatar
United States, GA, Tallapoosa
Ok i finally after yrs of wanting one i picked up a use min skyker and flew 3 flights yesterday i could get a flat spin but never could get that boomarang effect. I did one flat spin landing in the tall grass. Its been to long do u cross the rudder or aileron after u get into the flat or both?
epoweredrc is online now Find More Posts by epoweredrc
For Sale Electric Boomerang Combat Wing glennjunior1 Aircraft - General - Miscellaneous (FS/W) 10 Aug 09, 2011 12:16 AM
Wanted boomerang jets baby boomerang plumberboy Aircraft - Fuel - Jets (FS/W) 0 Aug 01, 2011 07:06 PM
For Sale electric boomerang flying wing glennjunior1 Aircraft - Electric - Airplanes (FS/W) 4 Jul 25, 2011 10:36 AM
Help! 1 oz. R&G Kevlar/Disser layup techniques ? KevinSharbonda Hand Launch 32 Jul 21, 2011 07:47 PM
Discussion Shooting 3d RC video ?- Camera movement techniques Reflex Films 3D Flying 4 Jul 01, 2011 10:32 AM
