Old Aug 29, 2011, 02:05 PM
rtbchris is offline
Find More Posts by rtbchris
Joined Jul 2010
Yaw Pot on KK Controller Board and Torque
Would adjusting the yaw pot on my KK controller board help me fix torque issues? I only ask because tilting my rear motor to the right to compensate for the counter clockwise movement is not working.
rtbchris is offline Find More Posts by rtbchris
Old Aug 29, 2011, 08:48 PM
SeismicCWave is offline
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
>>Would adjusting the yaw pot on my KK controller board help me fix torque issues?<<
Let's focus on what the Yaw pot does on a KK board. The yaw pot normally adjust the gain of the yaw gyro compensation. That is the higher you turn the pot the more the servo will tilt the motor to compensate for the yaw motion.
Second function of the yaw pot is to calibrate the speed controllers. You turn the yaw pot minimum and throttle stick at full and power on the controller board to calibrate the high end of the speed controllers.
>>I only ask because tilting my rear motor to the right to compensate for the counter clockwise movement is not working.<<
Ok, try to look at your tricopter from the rear towards the front and try to understand this. You can figure it out yourself. Now if top of the motor is leaning right which way is the propeller blowing air? The propeller is blowing air to the bottom to lift the tricopter and the propeller is blowing air to the left. Correct? Can you see it? Now if you look at your tricopter from the top. If something is pushing the tail motor to the right (that will happen when the propeller blows air to the left the tail will go right) which way does the tricopter spins? Counter clockwise!!!!!! So of course tilting the motor to the right will not help your counter clockwise spin! It is helping the counter clockwise spin!
SeismicCWave is offline Find More Posts by SeismicCWave
Help! Yaw gyro KK board not responding Menno Multirotor Talk 10 Nov 26, 2013 09:58 AM
Discussion KK Controller Board and Counter Rotating Motors rtbchris Multirotor Talk 18 Aug 29, 2011 03:43 AM
Discussion Can a KK Controller Board Ruin My ESCs? rtbchris Multirotor Talk 8 Aug 25, 2011 01:11 AM
Discussion Devices That Work with KK Controller Board? rtbchris Multirotor Talk 10 Aug 21, 2011 04:41 PM
Discussion KK Controller Board and Li-Po Batteries rtbchris Multirotor Talk 2 Aug 15, 2011 02:03 PM
