Old Sep 10, 2003, 08:53 PM
DavidJ is offline
Find More Posts by DavidJ
Jefferson, GA
Joined Jul 2002
Rubber Servo Mount Bushings-Anyone Use Them?
Does anyone use the rubber servo mount bushings with the brass insert that comes with most servos?
Benefit?
I have on some and not on others, and can not tell a difference.
David J.
DavidJ is offline Find More Posts by DavidJ
Old Sep 10, 2003, 09:03 PM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
I do, but only becuase that's what I was taught. Can't see any good reason not to. They'll provide a little give and could lessen the likelyhood of stripping, and the weight is nill. Plus they look nice.
-Jim
Jim McPherson is offline Find More Posts by Jim McPherson
Old Sep 10, 2003, 09:15 PM
LcJ is offline
LcJ
Find More Posts by LcJ
LcJ
Forever TMWT Pilot #11
LcJ's Avatar
United States, LA, Monroe
Joined Mar 2003
I agree with Jim. I use them on the Pico and not on Hitec 55. Different size holes.
Orginally they were to protect the servo from the vibration of a gas engine.
LcJ is offline Find More Posts by LcJ
Latest blog entry: RC Logger's Eye One Xtreme Quad
10Thumbs is offline
Find More Posts by 10Thumbs
Motor Maniac
Orange County, CA
Joined Feb 2002
They also may be recommended for IC (slimer) planes due to the excess vibration. I think with electrics you can certainly get away without using them.
10Thumbs is offline Find More Posts by 10Thumbs
Old Sep 10, 2003, 11:30 PM
SlowRider is offline
Find More Posts by SlowRider
It's the last plane honey
SlowRider's Avatar
Granite Bay, CA USA
Joined Jul 2003
David,
They seem to compress to easy (maybe I'm tightening to much?) so I didn't use them. I did have to go to a larger screw because the supplied ones kept slipping out of the notch. They're nice and secure now.
Andy
SlowRider is offline Find More Posts by SlowRider
Old Sep 12, 2003, 12:56 AM
Grejen is offline
Find More Posts by Grejen
IAMCANADIAN
Grejen's Avatar
Canada, BC, North Vancouver
Joined Jul 2002
I don't use 'em. Figure with electrics you don't need the vibration protection and the servo needs to be held more positively to reduce the slop. Esp with the reduced arm travel on smaller servo's and control arms. 1mm of servo wiggling is not gonna make a difference on a .40 Kadet but it sure would on some of these higher performance parkies. SB etc.
Grejen is offline Find More Posts by Grejen
Old Sep 12, 2003, 01:07 AM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
United States, WA, Tacoma
Joined Jun 2001
I don't use them either, and what's worse, I save 'em. I don't know why, save all those extra servo arms too.
Got tons of both.
William A is offline Find More Posts by William A
Old Sep 12, 2003, 03:09 AM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
I use them on Pico bb servos only to decrease the size of the hole and make a screw slipping less likely. I typically don't use the little brass collars that come with them, though.
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Sep 12, 2003, 03:36 AM
drksyd is offline
Find More Posts by drksyd
MultipleCrashSurvivor
drksyd's Avatar
USA, HI, Honolulu
Joined Jan 2003
Only used them in my moth after I put a servo tray in it and needed to screw the servos down. All my other planes they're taped in so don't need em.
drksyd is offline Find More Posts by drksyd
Old Sep 12, 2003, 04:12 AM
LenBFP is offline
Find More Posts by LenBFP
It's a Great Day to Fly
LenBFP's Avatar
Melbourne Beach, Florida
Joined Jan 2002
If I use the grommets I also use the eyelets, they work as a system to keep everything in place. Usually I just tape the servo or put it in a hole cut to fit. Lately I have been using the HS55 servos and they don't have the grommets and eyelets.
Len
LenBFP is offline Find More Posts by LenBFP
Old Sep 12, 2003, 07:14 AM
Tim Jonas is online now
Find More Posts by Tim Jonas
Mr Mootsie
Tim Jonas's Avatar
Pepperell, MA, USA
Joined Jan 2001
I use the brass insert and the rubber....always did, it just seems to be part of my "scan pattern".
Tim Jonas is online now Find More Posts by Tim Jonas
Old Sep 12, 2003, 09:00 AM
redtiger is offline
Find More Posts by redtiger
who put that TREE there?!
redtiger's Avatar
Northern Westchester, NY
Joined Aug 2002
I use them, but on my MPjet gearboxes. Without the brass inset, it makes it very easy to adjust the motor's angle if I need to - just compress the grommet a bit more.
redtiger is offline Find More Posts by redtiger
Old Sep 12, 2003, 11:54 AM
FredN is offline
Find More Posts by FredN
Having Fun!!!
FredN's Avatar
Cary, North Carolina, United States
Joined Jun 2001
If the servo comes with the rubber grommets I used them. If
they don't (like the HS-55) I don't.
Fred
FredN is offline Find More Posts by FredN
Old Sep 12, 2003, 12:16 PM
farnboro flyer is offline
Find More Posts by farnboro flyer
farnboro flyer's Avatar
Farnborough, Hampshire, England.
Joined Jan 2002
I have used them in my MM Switchback but without the brass inserts.
The whole idea is to reduce vibration from the motor............in the case of IC , the vibration is an issue!
Ian
farnboro flyer is offline Find More Posts by farnboro flyer
Old Sep 12, 2003, 12:18 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Yep - I nearly always use them. My old slimer habits die hard.....
Question Poliques Li-Mn 3800 mH anyone use them? flo Batteries and Chargers 0 Apr 23, 2006 02:29 AM
Question Anyone use Stevensaero brushless motor mount on Formosa Gatorfan Power Systems 4 Jan 23, 2004 10:49 PM
Speed control fuses, anyone use them? KenV Parkflyers 2 Jan 13, 2003 01:13 PM
9.6V Nikko Packs....Anyone Use Them putt_13 Batteries and Chargers 1 Nov 11, 2002 09:29 PM
