Old Aug 28, 2011, 12:19 PM
qwerty1000 is offline
Find More Posts by qwerty1000
qwerty1000's Avatar
Russia, Moscow, g. Moskva
Joined Sep 2007
F15E-Tetris, Bukvorez, 1800mm project.
Hi everyone!
Responses modelers yielded results. Draw, cut, glued.
Started F15E, length 1800mm, 86-98mm impellers. Estimated weight to 500gramm.
In this project, chose a slightly different approach to internal cutouts.
It is easier to form a canal impellers for different tasks.
Modeler has the ability to draw on occasion,
so the result is not quickly show promise.
qwerty1000 is offline Find More Posts by qwerty1000
Site Sponsor
Old Aug 28, 2011, 12:40 PM
SMorrisRC is offline
Find More Posts by SMorrisRC
You win again gravity!
SMorrisRC's Avatar
UK
Joined Jan 2010
Any chance of a 64mm - 70mm version?? (~1000mm-1200mm length)????
SMorrisRC is offline Find More Posts by SMorrisRC
Old Aug 28, 2011, 12:46 PM
qwerty1000's Avatar
Joined Sep 2007
traditionally would be the size of 1800, 1440, 1080mm
it was under the impellers 58-98mm, depending on the scale model.
Site Sponsor
Old Aug 28, 2011, 02:02 PM
SMorrisRC's Avatar
UK
Joined Jan 2010
Would a 64mm impeller fit inside the 1080mm??
Old Aug 28, 2011, 02:09 PM
qwerty1000's Avatar
Joined Sep 2007
the size of 1080mm, suitable impellers 58-68mm, depending on the task.
Site Sponsor
Old Aug 28, 2011, 02:42 PM
Ceeray is online now
Find More Posts by Ceeray
Finland
Joined Jul 2004
Yes! Finally!
Could you consider making this at 1,5-1,6 meter lenght? 1.44m means 64mm fans , but i would prefer having single 90mm bifurbicared. Could you try drawing 90mm single fan version? 1.8m is just too large to have at home, 1,5 would be pretty much perfect if single 90mm would fit with ducting. Also retracts would be much easier with single fan at Center.
My friend already ordered su-27 from you, I planned to get 1.4 m version too, but now Iwant this one.
When this is ready?
Ceeray is online now Find More Posts by Ceeray
Old Aug 28, 2011, 02:50 PM
qwerty1000's Avatar
Joined Sep 2007
yet it is hard to say. We are doing everything possible to quickly produce results. wait 2 weeks. clarify the timing of issuance of finished models.
Site Sponsor
Old Aug 28, 2011, 03:46 PM
qwerty1000's Avatar
Joined Sep 2007
http://bukvorez.ru/index.php?option=...d=36&Itemid=40
Site Sponsor
Old Aug 29, 2011, 02:37 AM
Finland
Joined Jul 2004
Qwerty , it looks like this plane does not have foam intake ducting designed...
So could you please make intake ductings from foam pieces--> they would be easy to glass over and use them as plugs for glass fiber ducting?
Especially for bifurbicated version the plug would be VERY handy and would speed up the building progress considerably!
Old Aug 29, 2011, 02:43 AM
qwerty1000's Avatar
Joined Sep 2007
experiment. ducts are not made in this release to allow the modeler to make their own, under the used impellers.
this is also reflected in the cost model.
Site Sponsor
Old Aug 29, 2011, 04:54 AM
benjo is offline
Find More Posts by benjo
Pointy end at the front.
benjo's Avatar
Joined Aug 2009
So, How much is this one going to be? $1300 dollars?
I might suggest the same. Single 90mm is about the biggest that will fit in most cars. Planes are pointless if you can't take them anywhere.
benjo is offline Find More Posts by benjo
Old Aug 29, 2011, 05:32 AM
qwerty1000's Avatar
Joined Sep 2007
I did not force. current prices are here:
Site Sponsor
Old Aug 29, 2011, 11:49 AM
delperena is offline
Find More Posts by delperena
Joined Feb 2006
This is a good size. Is this for two EDFs (I supposed)?
delperena is offline Find More Posts by delperena
Old Aug 29, 2011, 11:57 AM
qwerty1000's Avatar
Joined Sep 2007
tentatively. final size will be known after the first cut.
Site Sponsor
Old Sep 12, 2011, 11:33 AM
qwerty1000's Avatar
Joined Sep 2007
We decided to form a channel of air ducts. The model will have them.
Site Sponsor
Discussion SU-27, EDF, 1800mm, Tetris, Bukvorez qwerty1000 Foamy EDFs 230 Dec 01, 2015 12:42 PM
Discussion Tetris new project Boeing 747SP qwerty1000 Foamy EDFs 74 Jun 09, 2015 07:16 AM
Discussion SU-26, 1700, Tetris, Bukvorez qwerty1000 3D Flying 22 Nov 30, 2014 05:20 AM
New Product Airbus A320 at Tetris, Bukvorez. qwerty1000 Foamy EDFs 35 Apr 08, 2013 11:33 AM
Idea Tetris-Boats-Foam from Russia qwerty1000 Dock Talk 53 Oct 25, 2011 10:14 AM
