Old Aug 28, 2011, 07:29 AM
rogerflies is offline
Find More Posts by rogerflies
rogerflies's Avatar
Thomasville, GA 31792
Joined Apr 2002
Winch drums..V-belt or flat belt brake...Which is better
I've been making winches since the early '90s, and I switched to flat belt brakes long ago. I've sold some winches and a bunch of drums with flat belt brakes over the years.
Which is better? Anyone have enough experience with both types to offer an informed opinion?
rogerflies is offline Find More Posts by rogerflies
Old Aug 28, 2011, 09:34 AM
theghosttanker is offline
Find More Posts by theghosttanker
United States, NY, Lewiston
Joined Apr 2011
If they work it doesn't matter....I have used both and never noticed any significant difference. Flat belts are probably easier to build with; v-belt drums might be cheaper/easier to obtain. To me , the decision would be driven by the drum design, not belt choice. Once you have a drum you like, use the belt that fits....if you have a free hand in the drum choice, I would use flat only because it's easier to put rivets in the end.
theghosttanker is offline Find More Posts by theghosttanker
Old Aug 28, 2011, 12:18 PM
RWCLOUD is offline
Find More Posts by RWCLOUD
RWCLOUD's Avatar
Fresno CA
Joined Jul 2006
I saw a winch that had a V-belt that was adjusted a little to aggressive. The drum would stop violently. He quite using it that day when the belt got ripped from its retainers.
Which brings up the second point of why I like flat belts better. Retainers are more reliable with flat belts. YMMV!
BTW : You make very nice winches! A friend and I were drooling over the pictures you posted last night! He called to discuss his first winch build and he appreciated you pictures!
Blue Skies................Tim
RWCLOUD is offline Find More Posts by RWCLOUD
Old Aug 28, 2011, 03:09 PM
lincoln is online now
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
Would old timing belts work? They're free. We used to use them as landing skids.
lincoln is online now Find More Posts by lincoln
Old Aug 28, 2011, 04:29 PM
rogerflies's Avatar
Joined Apr 2002
Timing belts have cogs to transmit torque, so the rubber compound might not be as grippy. I've never tried one, but I suspect it would probably work fine, though.
I have tried cutting the ribs down on a serpentine belt to get more rubber in contact with the aluminum. It didn't seem to make much difference.
How well the brake works is mostly a matter of adjustment. I try to have the part of the belt closest to the brake arm touch the drum first. That helps generate the force needed to pull the rest of the belt into contact. Having multiple attachment points on the arm helps in getting the adjustment right.
Thanks for the kind words about my winches.
Old Aug 29, 2011, 08:27 AM
IBWALT is offline
Find More Posts by IBWALT
W0X0F
IBWALT's Avatar
Joined Nov 2005
I've used both for years and am currently using the flat belt on my personal winch. The difference in the two for me at least is when the time comes to replace them. With the V belt you need to find a belt that fits the V groove in depth and width and unless you know exactly which belt you want (part #) the search can be frustrating. With the flat belt I only need to go to the local automotive repair facility and pick up a free one that is the proper width. Both properly adjusted work equally well.
IBWALT is offline Find More Posts by IBWALT
Old Aug 29, 2011, 09:19 AM
pazi is offline
Find More Posts by pazi
pazi's Avatar
Czech Republic
Joined Jan 2009
V belt makes more friction surface than flat belt with the same width. More friction surface => more braking power. So if you will take wider flat belt, it will be easier (for construction and replace as IBWALT said) and will make the same braking power.
pazi is offline Find More Posts by pazi
Old Aug 29, 2011, 12:28 PM
RWCLOUD is offline
RWCLOUD's Avatar
Fresno CA
Joined Jul 2006
First we need to understand the V-belt. The groves of the pulley are made a slightly different angle then the belt. As the belt is pulled in the grove it grips the pulley with more force, great for driving something! But for braking it becomes more difficult to adjust to get a nice smooth breaking action. It is possible to get to aggressive of a breaking action causing all sorts of problems
Kind of like waiting until the last possible second to apply breaks when coming to a stop sign. You wear out tires and breaks! Spill your coffee and the cake you were bringing for the office party hits the floor upside down.
Flat belts lend themselves to easier adjustments and get the cake to the party in one piece!
Old Aug 29, 2011, 01:16 PM
Mathelo is offline
Find More Posts by Mathelo
USA, CT, Stamford
Joined Jun 2006
Standard V belts are easy to find. My local hardware store stocks many lengths in the standard "A" size. I use these with a Chicago Die Cast pulley.
Louis
Mathelo is offline Find More Posts by Mathelo
Old Aug 29, 2011, 03:02 PM
rogerflies's Avatar
Joined Apr 2002
Thanks for all the replies. I've decided to make them all with flat belts from now on, unless someone wants to pay in advance for one with a V-belt groove. I'll continue to throw in a section of flat belt with the drums to make things easy for the buyers.
Old Sep 02, 2011, 12:23 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
I have never built a winch but my observation is that the V belts tend to be very grabby. I think they lead to more line breaks. When you are pulling back they tend to grab hard making the line very jerky.
The flat belts seem to provide a good drag that meets the need without being grabby.
Just my observation from my limited experience.
aeajr is offline Find More Posts by aeajr
Poll JTM v TAMJETS 90mm EDF which is better? & why? Boostoman Electric Ducted Fan Jet Talk 82 Aug 29, 2011 02:58 PM
Poll Mini V Vs. Mini Hydro Hull, Tenshock Clone,Which is Better? RChelisrule Racing Boats - Electric 22 Jun 03, 2011 06:05 PM
Discussion Your winch no longer needs a V-belt brake. rogerflies Thermal 21 Jun 01, 2009 09:37 AM
Discussion Which is better? KP or uppgraded NF front brake? dragbikebam Motorcycles 0 May 02, 2009 06:32 PM
Discussion V-tail Better on Flat or Dihedral wings? GreenAce92 Hand Launch 36 Jan 01, 2009 11:16 PM
