Sacramento CA
Joined May 2005
I had a F5B Surprise 13 that would zoom to eye busting altitude in seconds. You could catch a 10 minute flight here and there if you were lucky, but having to do it in all four rounds when the announcer says launch, not very likely. We already have some pretty efficient planes in the Ava Pro E class type that will be as successful as anything IMHO. Time will tell, but an Explorer 4.0 E or Supra E might be the ticket when the wind kicks up a little. So far the contest days have been relatively calm, warm, and sunny. It will be interesting to see what works when the conditions are a little sketchy. Time will tell.
Davis, CA
Joined Oct 2006
"Importance of Duration and Landing task F5B is known for its high-speed flying of distance task, but the competition is won by the combined total of three tasks (distance, duration, and landing) so don't take these other two tasks lightly. Compared to the distance task, the duration task is relatively easy to score maximum points. Almost everyone scores within a few points of the maximum 600 points and also gets landing bonus points." quoted form here: http://www.airplanemaniac.com/english7.html My point: An f5b with a top notch pilot at the helm will always win at the ALES 10 minute task. But I don't think it is a soaring contest anymore. It is getting awfully close to a rocket with a paraglider style parachute. To heck with an F5b plane. Lets go with rockets and an rc pop out rc paraglider for a controlled return. This is not soaring! I would far prefer the Explorer or Supra. But I could still put a 5kW motor on either of them and smash you all even though I am not a good pilot. |
So how about restricting the power of the airframe to a certain number of watts per pound? This is something one can easily manage and enforce within certain tolerances. For example my F5B airframes produce about 1500 watts per pound and my F5J setup has about 600 watts per pound. I agree that with the current intent and vision of ALES both do not belong in that category unless you start grouping them based on climb performance.
I have two ALES airframes that produce about 75-100 watts per pound which is plenty for getting up to 200m in about 20 seconds. So how about restricting the amount of power based on weight? Just a thought. |
Re: more powerful E-planes being an unfair advantage in competition, the same argument can be made for TD planes now-adays. From personal experience the latest (and most expensive) designs have a clear advantage over others. I think thoughtful application of flying classes is the way to sort all this out. Unfortunately it may require more verification time and overhead for the CD and his/her team.
Davis, CA
Joined Oct 2006
This would definitely help and something like this is necessary in my opinion. The equivalent leveler in TD is that we all use basically the same winch and in F3J there is a line length limit and the 10 minute time window forces one to shorter and shorter time on the tow. Of course in TD someone will certainly come up with a new monster winch that uses modern motors and controllers and we might ultimately have to limit the winch power as well as is done in F3b. And, F3J has gone to quite an extreme too. JW talks about 120 lb tension he holds off for his sub one second launches. Still one must do 10 min and 15 min of soaring off of that 1 sec launch which is not very high if my view of Utube films of JW launching at the worlds is correct. |
Sacramento CA
Joined May 2005
"Do not hesitate to turn on the motor during the duration task. " this quote from the article reminds me that in F5B they turn the motor on as neccessary to stay up for 10 minutes. There is a deduction for time the motor is on but clearly different than one blast to 200M. Granted a few seconds can take it up hundreds of feet, but in ALES you cannot relight the motor without a DQ round.
Davis, CA
Joined Oct 2006
This is why I welcome the comment above to diasallow a zoom in ALES. I am glad that the powers that be have addressed the concern I have been laying out here in the SVSS group. |
So how will I notice that the power system was switched off by the limiter when doing a power climb to 200m? With low power systems the switch off is very easy to see but I could never notice it with my high power setup until I was way over the altitude limit.
I tested this a while back on one of my high power setups and noticed the loss of power only after gaining another 100 feet or more. With a F5B setup I bet you that it will go way higher than that without the pilot noticing that the limiter has kicked in. |
Davis, CA
Joined Oct 2006
| Thread Tools | |
| Discussion Here's Some Democratic Compassion for You - Elitist Corruption at its Finest | Park_Flyer | Life, The Universe, and Politics | 26 | Aug 13, 2011 12:08 AM |
| Discussion let's discuss adding ballast | atjurhs | Thermal | 15 | Oct 03, 2010 11:11 PM |
| Discussion Let's discuss a trashed Micro 4-Site - re-build options? | Grebs_59 | Foamies (Scratchbuilt) | 0 | Feb 16, 2010 08:43 PM |
| Discussion So It Is Christmas, Let's Discuss | Murocflyer | Life, The Universe, and Politics | 77 | Jan 01, 2007 02:15 PM |
| Discussion Let's Discuss The Sport Flyer Wasp | Slowdoc | Beginner Training Area (Aircraft-Electric) | 1 | Dec 08, 2006 01:24 PM |
